Winter Hanger "Warm Box"
Rickey B.
PostPosted: Fri Oct 24, 2008 3:49 am    Post subject: Winter Hanger "Warm Box" Reply with quote
Dave,
Depending on how large the box, a 25 watt bulb should do
the trick, and I think that in a box two feet square, a 75 or 100 watt
bulb would be way too much heat. There won't be any breeze in the hangar
to alleviate the heat build up.
Just my $0.02.
Rick Beckman
Midwest Mudworks
729 MSL and sinking
Zodie Rocket XL 52EB
www.sharbo.us/thebird
Do not archive.
I am about to go through my first winter in a hanger. I have some
chemicals like cleaners, polishing compounds, etc. that have the
recommendation to not let freeze. I would rather keep these at the
hanger instead of trying to remember to haul them back and forth from
home. I remember hearing or reading a recommendation a while back about
building a box and putting a light bulb inside it. The idea is that the
bulb would provide just enough heat to keep things from freezing, but
not too much to cause a fire hazard.
I am on southern Ohio where we usually do get too terribly cold, as
compared to you Wisconsin guys, but do see plenty of days below
freezing. I was thinking of a plywood box lined with aluminum foil and
a 75 or 100 watt bulb. Any helpful hints or suggestions on box
construction, insulation and safety concerns?
David Gallagher
601 XL/Jabiru 3300
First flight 7/24/08
Phase I flight test complete 10/16/08
Al Hays
PostPosted: Fri Oct 24, 2008 4:17 am    Post subject: Winter Hanger "Warm Box" Reply with quote
Dave,
You might want to incorporate a little device called a Thermo Cube
which looks like a regular multiple outlet adapter but has a
thermostat in it which turns on at about 35 degree and off at about
45 degree. They're carried by Tractor Supply Co with SKU Number
2170275 for about 13 bucks. Handy for the heater pad under your
engine too.
Al Hays
601XL N5892H reserved
Do not archive.
On Oct 24, 2008, at 7:49 AM, Beckman, Rick wrote:
<Rick.Beckman(at)atk.com>
Dave,
hangar
Just my $0.02.
Rick Beckman
Midwest Mudworks
729 MSL and sinking
Do not archive.
about
that the
and
David Gallagher
601 XL/Jabiru 3300
DaveG601XL
PostPosted: Sun Oct 26, 2008 3:49 pm    Post subject: Re: Winter Hanger Reply with quote
Thanks for the ideas. The smallest bulb I had in the house was a 40 watt so that is what I powered my box with for now. I will check out the thermo cube at TSC later this week.
Should get chilly here this week.
David Gallagher
Cincinnati, OH area
kmccune
PostPosted: Sun Oct 26, 2008 4:09 pm    Post subject: Re: Winter Hanger Reply with quote
When growing up on the farm in NW Wisconsin, we had a pump house. There was a wind mill above that was disconnected from the well. And the electric pump was above ground, with the "house" not being insulated. My Dad made foam insulated box(the old white bead board type) that was about 18x24x24 inches. Dad had a 75 watt bulb in there and the bottom was the uninsulated cement. It never froze... well unless the bulb burned out, but Dad changed it every month to try to prevent this.
Hope it helps.
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
Trainnut01(at)aol.com
PostPosted: Mon Oct 27, 2008 3:07 am    Post subject: Winter Hanger "Warm Box" Reply with quote
Kevin
My Dad did the same thing for the pump house but he used two 100 watt bulb wired in series. They were dim but they still generated enough heat to keep the pump from freezing and they burned for years and years without being replaced.
Carroll
Play online games for FREE at Games.com! All of your favorites, no registration required and great gr82x1200689022/aol?redir= http://www.games.com?ncid=emlcntusgame00000001"> check it out!
notsew_evets(at)frontiern
PostPosted: Mon Oct 27, 2008 6:55 am    Post subject: Winter Hanger "Warm Box" Reply with quote
Speaking of 100 watt light bulbs..
I have a large supply of them in my hangar.
I ve been selling these on eBay and I still have more to offer.
Most went to chicken farmers..........
Instead of the $5.95/4 that people were offering I ll give them to you guys if you need them.
All I ask is that you pay shipping/handling....
Yep, there free ... just pay for a box and shipping costs.
100 watt bulbs are on the extinct list. Even hardware store dont sell too many of them.....
Steve
notsew_evets(at)frontiernet.net (notsew_evets(at)frontiernet.net)
numbskull
PostPosted: Mon Nov 01, 2010 8:22 am    Post subject: Re: Winter Hanger Reply with quote
(at)Trainnut01: Does the link you gave for the online games are virus free? Do you have any link for spanish games? I wanna download it also.
ronlee
PostPosted: Tue Nov 02, 2010 10:56 am    Post subject: Re: Winter Hanger Reply with quote
When I was in the work force as a welder we kept our welding rods in an old refrigerator with a light bulb for heat and to keep the moisture away. It didn't take but a 100 watt bulb to make the rods so hot you couldn't handle them with bare hands.
I do think one would have to have some kind of thermostat control to keep things from getting too hot.
Ron Lee
Tucson, Arizona
DaveG601XL
PostPosted: Tue Nov 02, 2010 1:16 pm    Post subject: Re: Winter Hanger Reply with quote
I kind of forgot about my box question from a few years back. To follow up, I made a simple 3'X3'X2' box out of plywood and lumber left over from my Zenith shipping crates. A 40 or 60 watt light bulb works great to keep the insides above freezing here is Ohio.
There is only one problem.....when the bulb burns out, it does not call me on the phone to say it burned out. Sad If you just leave it on 24/7, like I did, it takes two standard 2000 hour bulbs to last a winter. Since I have miss-judged the bulb replacement timing both winters, I froze everything in the box solid. I will still use it this winter, but have already taken the things sensitive to freezing home. I will not use them anyway in the winter, so why leave them there.
David Gallagher
Cincinnati, OH area
craig(at)craigandjean.com
PostPosted: Tue Nov 02, 2010 1:34 pm    Post subject: Winter Hanger "Warm Box" Reply with quote
String two bulbs is series. With half the voltage they should last forever.
Or use a CFL Wink
-- Craig
flyadive(at)gmail.com
PostPosted: Tue Nov 02, 2010 1:40 pm    Post subject: Winter Hanger "Warm Box" Reply with quote
Gaggle:
Take a LQQK in GRANGER or McMaster.
They have all sorts of heating elements and some even come with�thermostat�controls.
They are rated in WATTS and BTU's.
Something�like the TAPE PIPE WRAP can be mounted on ALL the�vertical�walls of the box and�surround�the items in heat; with an external temp control.
Barry
PostPosted: Tue Nov 02, 2010 1:41 pm    Post subject: Winter Hanger "Warm Box" Reply with quote
OR use a 220 Volt Bulb in a 110 line.
Barry
On Tue, Nov 2, 2010 at 5:29 PM, Craig Payne <craig(at)craigandjean.com (craig(at)craigandjean.com)> wrote:
[quote]--> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com (craig(at)craigandjean.com)>
Or use a CFL Wink
-- Craig
psm(at)att.net
PostPosted: Tue Nov 02, 2010 1:44 pm    Post subject: Winter Hanger "Warm Box" Reply with quote
Hi Guys,
I'm afraid the series circuiit doesn't really solve the problems. The CFL
doesn't either.
What actualy works is to use 2 25W bulbs wired in parallel. This gives you
plenty of heat and when one bulb burns out the other one still works for a
while. You just need to inspect the setup from time to time to find the
single burned out bulb and replace it.
I have used a similar setup for years to keep wood very dry for fancy box
and pen making. The light bulbs keep the box warm so it doesn't collect
condensation -- at least on the inside.
Good luck,
Paul
Camas, WA
