		clrprop
				 Posted: Thu Oct 23, 2008 7:25 am    Post subject: wing attachment hardware |
				What kind of hardware are you all using for your wing attachment?
 Most of mine are the clevis pins w/ cowling safety clips. Some are too short to get a washer on underneath the clip. This doesn't look very safe to me. Are these ok or is it better to go with bolts and castle nuts?
 Keath T
 Mk III C
				 Posted: Thu Oct 23, 2008 7:57 am    Post subject: wing attachment hardware |
				Keath
 That's the way most all are. I personally use the ring type safety clips
 because long grass has been known to pull the cowl clips off. Others have
 said the ring clips might work their way out but I doubt it. Some people
 that don't fold their wings have used bolts with lock nuts. Some even have
 used bushings/spacers that lock the wing attachments together. There is no
 reason why you can't use castle nuts. What ever you use be sure it is AN
 hardware for the pins or bolts.
 Also always check the safety clips on preflight for wear.
 Rick Neilsen
 Redrive VW powered MKIIIC
		Dana
				 Posted: Thu Oct 23, 2008 8:41 am    Post subject: wing attachment hardware |
				At 11:25 AM 10/23/2008, clrprop wrote:
  	  | Quote: | 	 		  What kind of hardware are you all using for your wing attachment?
 I don't think it's an issue; I've never heard of a failure (has
 anybody?).  I don't have washers under the clips on any of mine.  Since I
 fold the wings every time I fly each connection gets checked anyway.  If I
 weren't folding every time I'd probably go with bolts and locknuts, though.
 -Dana
   In England, the cops say, 'Halt or I'll say halt again!'
		JetPilot
				 Posted: Thu Oct 23, 2008 9:35 am    Post subject: Re: wing attachment hardware |
				There have been cases where the safety pin has been undone on the tail wire attachment on the bottom of the rudder due to long grass.  I use a castle nut with cotter pin that you permanently bend in place for that attachment, and nylock nuts on the wings since I do not fold my wings.   If you must fold, I like the key chain type circlips, rather than the safety pin type which are more easily knocked open.
 Mike
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		by0ung(at)brigham.net Guest
				 Posted: Fri Oct 24, 2008 7:05 am    Post subject: wing attachment hardware |
				If the pins are too short to put on a washer....  get longer pins.    Or go
 with bolts and nuts,,,  remember some areas are not designed to be tightened
 down with lots of torque on the bolts... I would tighten so that you could
 still easily  rotate the bolt by hand.
 Boyd Young
 Kolb MKIIIC
 Keath T
 Mk III C
		olendorf
  Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
				 Posted: Fri Oct 24, 2008 9:34 am    Post subject: Re: wing attachment hardware |
				What purpose does the washer provide in this case? The FAA inspector that gave me the airworthiness inspection also recommended I put washers under the cowling pins. I can only assume it would cut down an pin wear if the clevis pin was rotating.   I didn't add the washers.  I have the cowling pin in my hand twice every time I fly. If it was worn out I'd know it.
  _________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
		Steven Green
				 Posted: Fri Oct 24, 2008 3:17 pm    Post subject: wing attachment hardware |
				The Kolb plans do not call for washers on the pins.  I would not put them on
 due to the washers being free to spin and cause significant wear to the cowl
 pin.  I have seen a washer on a loose bolt spinning at approximately 120 rpm
 just being driven by the vibration of the machine.  It's the hula hoop
 affect just smaller and faster.  I also would not use "key chain" rings as
 they are not made to any quality standard.  I guess I just have a lot of
 faith in the design that Homer came up with.  If I didn't fold and trailer I
 would probably use AN bolts and castle nuts.
 Steven Green
 MK3 912S
 560 hrs with washerless cowl pins.
 But not the same ones, they are replaced at least annually.
  _________________ Steven Green |
		Dana
				 Posted: Fri Oct 24, 2008 3:35 pm    Post subject: wing attachment hardware |
				At 07:16 PM 10/24/2008, Steven Green wrote:
  	  | Quote: | 	 		  The Kolb plans do not call for washers on the pins.  I would not put them
 on due to the washers being free to spin and cause significant wear to the
 cowl pin.  I have seen a washer on a loose bolt spinning at approximately
 120 rpm just being driven by the vibration of the machine.  It's the hula
 hoop affect just smaller and faster.  I also would not use "key chain"
 rings as they are not made to any quality standard.  I guess I just have a
 lot of faith in the design that Homer came up with.  If I didn't fold and
 trailer I would probably use AN bolts and castle nuts.
 I agree, I use the AN pins with no washers, except at one location:  The
 UltraStar plans DO call for a ring cotter (the plans call it a "safety
 circlip") at one location, the pin that holds connects the elevator horns
 to the control arm in the back of the boom tube (done differently on the
 later Kolbs, I believe?).  I bought a package from the marine store, but I
 didn't trust the "tail" that's supposed to make it easy to install, looks
 like it'd make it easy to come loose, as well... a friend who flies a GT400
 gave me some without the tail; that's what I use now.
 -Dana
   Democracy is three wolves and a sheep voting on what to have for lunch.
