vk3eka(at)bigpond.net.au Guest
Posted: Fri Oct 24, 2008 2:14 pm Post subject: Mechanical Fuel Pump |
Hi Guys,
I am rebuilding an O-200 for experimental use.
The engine I have doesn’t have a mechanical fuel pump or the eccentric on the cam to drive one. Do I need a different cam or does the eccentric fit in between the cam end and the vacuum pump drive?
Any other ideas would be good?
Cheers
Peter.
| - The Matronics Continental-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Continental-List |
agustafson(at)chartermi.n Guest
Posted: Fri Oct 24, 2008 4:28 pm Post subject: Mechanical Fuel Pump |
Peter
I have the same engine in a Zenith 601 and I just used 2 Facet fuel pumps, one in each tank. It's a lot cheaper for sure. Do you even have the boss to mount a pump on. Mine did not.
Aaron
Posted: Fri Oct 24, 2008 4:46 pm Post subject: Mechanical Fuel Pump |
Aaron,
Thanks, I am also building a 601XL. The O-200 does have the place for a mechanical pump but nothing else. I have a copy of WW Corvair/601 book so may go with the double electric pump setup.
Peter
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Aaron Gustafson
Sent: Saturday, 25 October 2008 11:28 AM
To: continental-list(at)matronics.com
Subject: Re: Continental-List: Mechanical Fuel Pump
Peter
Aaron
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
