AV8ORJWC
Posted: Mon Oct 27, 2008 8:08 am Post subject: Weighing prior to DAR paperwork |
I am assuming that your definition of "level" was with a digital level
(indicating to the 0.1 degree) and not a bubble level. Just like in
hand grenades and bombs.
Level both fore and aft and port to starboard. The hangar doors need to
be closed to wind effects as well, in a normal weight environment.
John Cox - RV10 N49CX =Dreaming of Living the Dream
jcumins(at)jcis.net Guest
Posted: Mon Oct 27, 2008 8:24 am Post subject: Weighing prior to DAR paperwork |
Ok I have a max gross weight question. How are boilers able to change the
max gross weight for there 10. I thought the published max gross is
2700lbs, but I see here they range from 2700 to 2850.
How are they able to do that??
Van's RV-10 Ted French C-FXCS Lycoming IO-540 260
76" MT 3-blade Composite CS 49.58" 1557 2700 1143 60
783
Van's RV-10 Tim Olson N104CD Lycoming IO-540 260 80"
Hartzell 2-blade Aluminum CS 108.67" 1685 2700 1015 60
655 100% Complete right down to the ...
Van's RV-10 Gary Specketer N204GS Lycoming IO-540 260 78"
AeroComposites 2-blade Composite CS 0.06" 1699 2700 1001 60
641 Full IFR Upholstery, Dual Altena...
Van's RV-10 Chuck Stuhrenberg N300WC Lycoming O-540 300 72"
Hartzell 2-blade Aluminum CS 106.98" 1615 2900 1285 60
925
Van's RV-10 Rene Felker N423CF Lycoming IO-540 260 80"
Hartzell 2-blade Aluminum CS 109.22" 1698 2800 1102 60
742 Full IFR, 2 Alt, full interior
Van's RV-10 Bob Condrey N442PM Lycoming IO-540 260 80"
Hartzell 2-blade Aluminum CS 108.2" 1632 2700 1068 60 708
All electric, dual batteries, du...
Van's RV-10 David McNeill N46007 Lycoming IO-540 260 80"
Hartzell 2-blade Aluminum CS 109.13" 1630 2700 1070 60
710
Van's RV-10 Anh Vu N591VU Lycoming IO-540 260 80" Hartzell
2-blade Aluminum CS 106.99" 1625 2700 1075 60 715
Datum is 99.44" forward of wing ...
Van's RV-10 vic Syracuse N64VC Lycoming IO-540 310 72"
MT 3-blade Composite CS 89.59" 1665 2850 1185 75 735
CG limits are aft of leading edg...
Van's RV-10 Russell Daves N710RV Lycoming IO-540 260 76"
MT 3-blade Composite CS 108.05" 1584 2700 1116 60
756
Van's RV-10 BARRY MARZ N789AB Lycoming IO-540 260 80"
Hartzell 2-blade Aluminum CS 108.73" 1648 2700 1052 60
692
Van's RV-10 Albert Gardner N991RV Lycoming IO-540 310 78"
AeroComposites 3-blade Composite CS 110.35" 1634 2800 1166
60 806
Van's RV-10 Dave Emond ZU - RVD Lycoming IO-540 260
80" Hartzell 2-blade Aluminum CS 108.33" 1631 2700
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
AV8ORJWC
Posted: Mon Oct 27, 2008 8:51 am Post subject: Weighing prior to DAR paperwork |
Ball point pen with the ink above 212 degrees F. DAR approval after
cool down. FAA acceptance upon receipt. "Cause it is - Experimental".
I will listen for those using more than VAN's tested and approved 2700
lbs. for the Static Load to Gross Weight Testing results. Maybe the
jettison Max Fuel Load for Landing back to 2700 prior to emergency
touchdown?
As more of the Van's fleet sustained collapsed nose gear incidents (not
with the RV-10 Fleet), my attention became perked.
John
rene(at)felker.com Guest
Posted: Mon Oct 27, 2008 9:03 am Post subject: Weighing prior to DAR paperwork |
At the risk of being flamed. Adjusted g limits of my airplane based on a
set of assumptions derived from the Vans number. In other words, my
airplane is not rated for 3.8g at its max gross weight of 2800. Now, in
reality, I will have trouble getting my airplane up to 2800 pounds. During
testing, I loaded it out at 2780 putting it at the aft CG. I just could not
fit any more sand bags in the front seat... .
Now, with the 2800 lbs I will not get caught being overweight during ramp
check or accident investigation, but like I said, I will have trouble
getting there anyway......and still staying within the aft CG.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
dlm46007(at)cox.net Guest
Max gross weight is established by the manufacturer; you are the
manufacturer, not Vans. That said it is good judgment to keep your stated
gross close to Vans since they have done the structural testing on the
airframe. Because I did not ever want to have Pssin match with an insurance
company over whether I was at 2700 or 2710 or 2723, I set mine for the
record to 2800.
AV8ORJWC
Posted: Mon Oct 27, 2008 10:27 am Post subject: Weighing prior to DAR paperwork |
This is some good stuff!
Now, can I conclude from David's post that insurance underwriters may
actually accept an "Approval of Claim" rather than the more typical
"Denial of Claim" when the VANs factory, a large number of builders and
Dick V placed the hard gross weight at =<2700 lbs max for the RV-10
insurance pool and then the builder/claimant uses a higher arbitrary
number? Can I conclude from Rene, that use of sandbags above 2700lbs is
not to demonstrate the wing spars will take the static weight "In
Flight" but is a rather a ground load test on the fuselage construction,
the leg attachment and the wheels/tires? Can a builder disregard the
3.8 Positive and the negative G factors when submitting to DAR
paperwork? At 3.8G that requires 5130 pounds of sand "Per Wing" or
10,260 GW for Wing Loading of the total Aircraft if exceeding the
factory recommendation.
Are the planes signed by the DAR to Normal, Utility, Aerobatic or a new
category - based on specific Positive/Negative G forces? What can we do
to make an RV-10 capable of legal aerobatic maneuvers? What fuel load
reduction is required for a 3.8 Normal to go to Utility Flight or
Aerobatic Flight? Does Maneuvering Speed change with higher Gross
Weight entries into the POH?
Is there more than Pen & Ink involvement?
What is the Testing Practice (prior to DAR) when going "off the
reservation"?
No flame intended. This remains Good Stuff. John Cumin is to be
commended for extracting Dan Checkoway's data. And Thanks to those
honest enough to post on this important subject. Michael, I am missing
your wit here.
John Cox
Aurora State
msausen
Posted: Mon Oct 27, 2008 11:43 am Post subject: Weighing prior to DAR paperwork |
I'm pretty much witless here. This is one of those subjects much like politics, everyone is very passionate about their opinion but many don't actually have any real data behind their choices.
It's of course very true that we are all the manufacturers and as such we can make any changes or set any limits that we deem applicable (and I hope safe) without having to produce the data to backup what we do. The Fed or DAR is there to make sure we haven't done anything stupid in a big way but unfortunately it's all the stupid little things that usually stack up on each other to bite us in the arse at the worst possible time.
As to increasing your gross weight I can understand the argument of what if you are ramp checked and happen to be at 2701#. Then there is also always the liability issue with a higher than normal gross and selling the aircraft. Even if you never plan on going over 2700# it doesn't mean the guy that buys it won't if you published higher. I guarantee that's one you won't win when you are asked to produce the data for the increase by the prosecution. Setting your gross at something higher would protect you from being violated for a minor oversight but how much is too much? Sure you could be like the big boys and set a max landing weight of say 2700# and a max takeoff of 2800# and 1.5g's but that still leaves you with a big grey area on performance of the actual aircraft and every component unless you have tested it to failure.
As to beating out the insurance should you need to collect, I think that is pretty easy to sum up. Insurance companies and the FAA prefer to interpret things how they see fit without much concern for what is written. Even if your policy says you are covered, I'll bet you a doughnut and coffee that if you put in your gross as more than 2700# and you still call it an RV-10, they won't pay out if you show up at the site of the incident over 2700#. If you really want to jack up your gross, call it something else and make sure you fly it at gross and at your various CG and G limits during your testing phase to be sure you don't crack a spar or do a tail slide when you are out showing your QB buddy how great this thing stalls with his center and offensive line buddy in back.
Anyway to each his own. It is an Experimental after all isn't it. And as such you are in this for your own education and entertainment aren't you. Right?!? Just make sure you complete the experiment part before you load up with your family or sell it on down the road.
Michael
State of Delusion
Posted: Mon Oct 27, 2008 12:36 pm Post subject: Weighing prior to DAR paperwork |
My DC10 gas a gross of 2800.
Posted: Mon Oct 27, 2008 12:58 pm Post subject: Weighing prior to DAR paperwork |
Just a note from the Vans site.
"Part 23 requires that the wing support 1.5 times the limit load of 3.8G
(i.e.: 5.7G) for 3 seconds in all conditions. It allows the use of a
different test article for each condition. We used the same test article to
test for all conditions. Ours is a more severe test, because the wing could
be weakened by one test before the next is run. As full load is reached, the
wing creaks and groans and wrinkles run like heavy seas across the top
skins. Engineers start using some strange body English and holding their
lips all funny. When the last few shot bags are loaded, the atmosphere can
be pretty tense. We were very pleased to find that our calculations had been
correct and the wing passed all the requirements of Part 23."
The wing passed all three tests use the same fixture. Manufacturers are
allowed to use a new wing for each test. Likewise the FAA permits certified
aircraft less than 12500# to operate at 115% of certificated weight in
Alaska. I believe this is due to engine power availability rather than
structural strength of the airframe. So I am not worried that a 4% increase
in gross weight will compromise safety.
Kelly McMullen
Posted: Mon Oct 27, 2008 2:52 pm Post subject: Weighing prior to DAR paperwork |
Please note the reg cited does NOT allow any and every pilot to
operate every plane at 115% of gross in Alaska. It requires specific
approval for a specific operation and is in no way generic. It is more
like getting a ferry permit for oceanic flights for extra fuel. Yes,
you generally do have more power and lift available, as only in the
heat of summer do you get to ISO or above conditions.
| Quote: | aircraft less than 12500# to operate at 115% of certificated weight in
A&P/IA, EAA Tech Counselor
KCHD |
