Posted: Tue Oct 28, 2008 8:27 pm Post subject: Fuel senders |
Does anyone remember getting a 1.5K resistor and a voltage adaptor in the box with the fuel senders which Van's sent to us? Someone is telling me they should have been in the box, but I have absolutely no recollection of these in the blue and black cardboard box the units came in.
JOhn G. 409 Do Not Archive
dlm46007(at)cox.net Guest
Posted: Wed Oct 29, 2008 1:29 am Post subject: Fuel senders |
No resistors. The only resistors associated with my senders is the variable
resistance through the unit when the arm is moved. The other area of
resistors is the resistor used to create the reference voltage, 5 volts IIRC
in the EIS circuit. This voltage is applied to the sender and the current
flows through it to ground and the arm movement varies unit resistance to
give a fuel level indication. Again no resistors in the box and the resistor
used to create the reference voltage cam from radio shack.
