Found it at last-Coil feed wires not crimped on
cffd(at)pgrb.com
PostPosted: Fri Oct 31, 2008 8:21 am    Post subject: Found it at last-Coil feed wires not crimped on Reply with quote
Clive,
I noticed the harness loom tubing had melted at the connection from the alternator. I think the connectors I used were not compatible with the ones from the alternator. I cut off the connectors and soldered the wires, everything is "cool" now. This had been a common problem in the past.
Chuck D.
N701TX
