icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Mon Nov 03, 2008 12:43 am Post subject: 912uls and MAP |
I've seen a few references to MAP while discussing a 912uls. How can a normally aspirated engine have intake manifold pressure? Or are the references to MAP something else? Thanks,
_________________ Scott
www.ill-EagleAviation.com
do not archive |
Posted: Mon Nov 03, 2008 2:35 am Post subject: 912uls and MAP |
icrashrc wrote:
Scott
Scott
there is always pressure in the manifold but its usually less then
ambient atmospheric. No such thing as negative pressure btw, pressure is
either zero (vacuum) or positive.
Graham
rampil
Posted: Mon Nov 03, 2008 2:29 pm Post subject: Re: 912uls and MAP |
When you drive a variable pitch prop, the MAP is the correlate of
engine power you you to control the throttle.
