Dennis.Kirby(at)kirtland. Guest
Posted: Mon Nov 03, 2008 12:40 pm Post subject: Scratches in Lexan Windshield |
Kolb Friends -
I have some fairly significant scratches on the polycarbonate windshield
of my Mark-3.
Not so much deep scratches, but many swirls of scratches. Similar to
what you'd expect if you took sand paper and wiped it across the
surface.
Do I need to replace the whole windshield, or can these be buffed out?
I've seen products designed to remove scratches from Plexiglas. Would
these same products work for Lexan?
Many thanks -
Dennis Kirby
N93DK, 912ul, "Magic Bike"
Cedar Crest, NM
The BaronVonEvil
Joined: 23 Jun 2006 Posts: 76 Location: Walla Walla, WA.
Posted: Mon Nov 03, 2008 1:46 pm Post subject: Scratches in Lexan Windshield |
Hi Dennis,
The best way to get rid of scratches would be to replace the lexan. That
being said you might try "Plexis" which comes in a aerosol can. It is
formulated for cleaning Plexiglas and will hide most minor scratches pretty
well.
An el-cheapo substitute is "Lemon Pledge" although I have heard it will
cause problems with lexan over time. This is what I have been using and so
far so good.
Polishing and buffing will eventually remove the scratches but it takes time
and if done wrong will create more problems than it will solve, dull hazy
view, distortion etc. There are kits available from aircraft supply houses,
"Micro Mesh" is one that comes to mind.
Hope this helps
Carlos G.
Dana
Posted: Mon Nov 03, 2008 2:02 pm Post subject: Scratches in Lexan Windshield |
At 03:39 PM 11/3/2008, Kirby, Dennis CTR USAF AFMC MDA/AL wrote:
| Quote: | I have some fairly significant scratches on the polycarbonate windshield
of my Mark-3.
surface.
Yes, they will work on any clear plastic. It takes a fair amount of elbow
grease, though. Just the other day I used Meguire's Plast-X from the local
auto parts store to make the clear face shield on my flying helmet usable
again... took about a half hour of vigorous polishing. It might be easier
with an electric drill with a buffing pad, I didn't try that.
One thing, don't ever use paper towels to clean your windshield! Paper is
abrasive and will make the kind of scratches you describe. Use only a soft
cotton cloth.
-Dana
The man who would be fully employed should procure a ship or a woman, for
no two things produce more trouble" - Plautus 254-184 B.C.
grantr
Posted: Mon Nov 03, 2008 3:34 pm Post subject: Re: Scratches in Lexan Windshield |
Also don't rub in circles. Rub in straight lines up and down that way if it scratches which it will over time it will not be as hard to see through.
Use only a soft cotton cloth to clean.
Steven Green
Posted: Mon Nov 03, 2008 5:56 pm Post subject: Scratches in Lexan Windshield |
Dennis
I use Kit paste car wax after I have cleaned mine. I usually wet a towel
and lay it on the windshield for a while to soften the bugs and not have to
scrub too hard. You might check with Travis, He had Mark 3 lexan on sale at
one time. Overstock I think. I keep a chamois in the plane for anytime
that I have to dry the windows.
Steven Green
_________________ Steven Green |
N111KX (Kip)
Posted: Mon Nov 03, 2008 6:11 pm Post subject: Re: Scratches in Lexan Windshield |
Plexus cleaner and an old t-shirt will do wonders! I love it so much I should buy the company...
Kip
_________________ Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta |
Posted: Mon Nov 03, 2008 6:27 pm Post subject: Scratches in Lexan Windshield |
Kit "scratch out" works great on automotive clearcoat. Should do ok
on lexan too.
More than once I have mentioned that GE sells a scratch resistant
polycarbonate called MR10.
-or did anyway. I have it on my MkIII and it still is as clear as new.
Don't know why nobody else has tried it?????
BB
On 3, Nov 2008, at 8:56 PM, Steven Green wrote:
<Kolbdriver(at)bellsouth.net>
Dennis
towel and lay it on the windshield for a while to soften the bugs
and not have to scrub too hard. You might check with Travis, He
had Mark 3 lexan on sale at one time. Overstock I think. I keep a
chamois in the plane for anytime that I have to dry the windows.
Steven Green
purplemoon99(at)bellsouth Guest
Posted: Mon Nov 03, 2008 6:33 pm Post subject: Scratches in Lexan Windshield |
If you ever replace the windshield , use MR 4000 Lexan by G E the MR stands
for mar- resistance......that is the best... Joe N101HD
Posted: Mon Nov 03, 2008 6:39 pm Post subject: Scratches in Lexan Windshield |
If your head or arm ever goes through it you won't love it it will cut the
shit out of you,very jaged, and very sharp,also the material will cause
infection. I know frist hand. Joe N101HD
Thom Riddle
Posted: Tue Nov 04, 2008 5:13 am Post subject: Re: Scratches in Lexan Windshield |
Dennis,
Here is what I've used with good results.
Novus Plastic polish #1 cleans and protects
Novus Plastic polish #2 restores and refinishes (removes fine scratches)
Novus Plastic polish #3 removes heavy scratches (aggressive polish)
Available from Aircraft Spruce.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
