pequeajim
Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
Posted: Mon Nov 03, 2008 6:21 pm Post subject: Fuel Filter |
What are you all using for a fuel filter with your Jabiru engines?
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
Lynn Matteson
Posted: Mon Nov 03, 2008 10:06 pm Post subject: Fuel Filter |
I use Purolator in-line fuel filters in each of the down-lines from
my two fuel tanks, and another just after the main shut-off valve.
These have a glass see-through housing, and replaceable filters.
Total of 3 filters. Aircraft Spruce has them, as well as some auto
parts outlets. They might not be available as Purolators any more,
but NAPA carries them in their own brand, and it is the same thing.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 587hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
aslsa.rng(at)gmail.com Guest
Posted: Tue Nov 04, 2008 4:43 am Post subject: Fuel Filter |
Lynn, et al, Be very cautious when buying the latest version of the "Clearview" type of fuel filter. They are now marketed by several companies, among them "Mr. Gasket". The design has been re-engineered to make them easier to manufacture and the result is no longer suitable for any vehicle application and certainly not aircraft IMHO.
The original Purolator filter (mine is circa 1994) had one end and the center section machined as one piece and the center section was round which yielded threads that gave a circular contact on the end that screwed on. Now the center section is a flat cast piece. The parting line runs through the center of the part and the two sides are MISALIGNED (!) so that the ends will not stay square to it when the filter is assembled. The result is that the o-rings get damaged and leak. In addition this new center section is only about 1/8" (3.2mm) thick so the area of thread engagement to the threads in the end pieces is very small.
In the original the barbed fittings were part of ends making for a bit of a PITA since you had to buy a specific size to match the fuel line used in the application. The new version has threaded ends and comes with a set of plastic barbed fittings so one size fits all, however, the ends are chromed and the "overspray" (for lack of a better term) into the first two threads makes it necessary to chase the threads if you wish to use metal fittings.
If you wish to investigate for yourself, I recommend you remove the filter from its packaging and inspect it right there on the store counter. If they make you buy it first at least you won't have to make a return trip to take it back.
Rick
On Tue, Nov 4, 2008 at 12:05 AM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote]--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I use Purolator in-line fuel filters in each of the down-lines from my two fuel tanks, and another just after the main shut-off valve. These have a glass see-through housing, and replaceable filters. Total of 3 filters. Aircraft Spruce has them, as well as some auto parts outlets. They might not be available as Purolators any more, but NAPA carries them in their own brand, and it is the same thing.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 587hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition system
[quote]--> JabiruEngine-List message posted by: "pequeajim" <pequeajim(at)gmail.com (pequeajim(at)gmail.com)>
[url=http://forums.matronics.com/viewtopic.php?p 12186#212186]http://forums.matronics.com/viewtopic.php?p 12186#212186[/url]
jcrowder(at)lpbroadband.n Guest
Posted: Tue Nov 04, 2008 6:11 am Post subject: Fuel Filter |
Rick,
What filters are you now using? I'm about to replace mine.
Jim Crowder
[quote] --
Posted: Tue Nov 04, 2008 5:34 pm Post subject: Fuel Filter |
I have a Clearview that was sitting in my Harley parts bin when I bought the Mr. Gasket POS, so the Mr.Gasket unit went back to the auto parts store and the Vibraglide filter went airborne.One more thing about fuel filters. If you live in a country subject to the Ethanol swindle as we are in the USA be careful NOT to use any kind of fuel filter with a paper element. If water should drop out of suspension it will coat the paper and, well, you might as well try to fly with the fuel valve closed. This isn't just my opinion, Rotax mentions this specifically in their manuals.
Rick
On Tue, Nov 4, 2008 at 8:11 AM, Jim Crowder <jcrowder(at)lpbroadband.net (jcrowder(at)lpbroadband.net)> wrote:
[quote] Rick,
Jim Crowder
[quote] --
Lynn Matteson
Posted: Wed Nov 05, 2008 5:48 am Post subject: Fuel Filter |
Rick-
I've got the "real" Purolator filters, but they *do* have the cast
center section as you say. But mine are leak-free and have been right
along. I know what you mean about the center section being kind of
crappy, machining-wise, and the old round one was a better design,
but like everything else, the "design be damned, we're gonna build it
cheap" school of thought has taken over.
I just removed the electric fuel pump from my fuel system, and in so
doing, I had to find another way to go from 5/16" fuel line down to
1/4" fuel line, so I just changed one end on my Purolator filter and
that was that....5/16" cap with the built-in barb on one end, and
1/4" cap with built-in barb on the other end. And these caps have the
nice smooth barb which is a joy to install and remove the fuel line
from. I've seen the multi-size end caps on the "non-Purolator"
filters, and they are crap...the "one size fits all" mentality at
work again.
Just for the record, before I removed the fuel pump and fuel pressure
gauge sending unit from my system, I measured the fuel flow right at
the carb, and it was 11.25 gallons per hour. With the fuel pump and
fuel pressure gauge sending unit removed, and 1/4" fuel line in it's
place, the flow was 13.6 gallons per hour. This was measured (with
about 5 gallons in each of the two wing tanks) by taking the float
bowl off and timing the flow of fuel through the carb (with the new
3.7mm float needle seat) for one minute, multiplied by 60. I can now
climb as steeply as desired, and the engine doesn't go lean or
stumble from lack of fuel.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 587hrs
Sensenich 62x46
system
On Nov 4, 2008, at 7:43 AM, Richard Girard wrote:
| Quote: | Lynn, et al, Be very cautious when buying the latest version of the
aircraft IMHO.
Rick
On Tue, Nov 4, 2008 at 12:05 AM, Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 587hrs
Sensenich 62x46
system
<pequeajim(at)gmail.com>
N369LM |
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Tue Dec 02, 2008 3:21 pm Post subject: Re: Fuel Filter |
I've never seen a fuel filter on any of the production aircraft I've owned or flown, just a gascolator backed up by drain points in the tanks. I haven't decided whether to install a filter or not. I wonder if it isn't just one more point of potential failure.
Flame away!
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Tue Dec 02, 2008 3:34 pm Post subject: Fuel Filter |
Well the Jabiru 3300 (hydraulic lifter) installation manual specifically
calls for one:
"11.2 Fuel Filtration
A Fuel filter capable of preventing the passage of particles larger than
0.1mm (100um) must
be installed between the fuel tank outlet and the fuel pump.
The filter must be present in the system for the fuel flow test. The size of
the filter should
give consideration to allow adequate flow with a used filter.
A Ryco Z15 or similar filter has been used successfully."
Rev 1, March 27, 2006, page 21 of 49.
I suppose if the mesh in the gascolator met those numbers they would be
happy.
-- Craig
Lynn Matteson
Posted: Tue Dec 02, 2008 4:37 pm Post subject: Fuel Filter |
No flames, but no failures either, in any of my three Purolator in-
line glass fuel filters in nearly 600 hours of operation....and no
gascolator, either. Just a header tank with the wing tanks feeding
it, and a sumping point at the bottom. This serves the same purpose
as a gascolator. It allows any crap that reaches the header tank to
settle to the bottom, where it is "sumped" away the next time fuel is
drained...the next day, hopefully. And unlike a gascolator, the
capacity of this tank below the fuel outlet port is almost a quart,
so you could get really lazy/inattentive and still not get any crap
in the outgoing fuel...unless you shook the airplane really
violently, then tried to fly it. Then you might get some floating
crap into the outlet port. Guess what? Downstream from this header
tank is the last of the three filters.
And just for the record, I've got 19 hose clamps and more than that
in potential points of leakage, if you count the barbed fittings that
are screwed into the tanks, valves, filters, firewall pass-through,
and carb. Oh, and by the way, this is a high-wing, gravity-flow system.
I just found the figures for fuel flow that I posted back on Nov 5,
and which I'll paste here:
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
also building a new pair of snow skis
On Dec 2, 2008, at 6:21 PM, Tim Juhl wrote:
Flame away!
______________
CFII
Champ L16A flying
Working on fuselage
http://forums.matronics.com/viewtopic.php?p 17404#217404
N369LM |
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Dec 03, 2008 7:55 am Post subject: Re: Fuel Filter |
The Aircraft Spruce filter P/N 05-01030 seems to be serving me pretty well so far. I want to add a word of caution about the comment of using a smaller gascolator filter. I have the Spruce gaslocator that has a single layer mesh screen in it. I e-mailed Spruce about the mesh size and got a reply that it is 120 microns. They told me that they have a 74 micron screen available, but that it was not listed in the current catalog. I went ahead and bought a couple thinking that I would just use the smaller screen and no filter.
I installed the new screen and performed and engine run. I could not accelerate past part-power and my fuel pressure at the engine was way low. I popped the old screen in and re-ran the engine without any problems. I threw the smaller screens out, added a filter into the system and never looked back. I could have spent some more time troubleshooting around the smaller screen but decided it was not worth the effort.
The stock 120 micron gascolator screen and the 05-01030 filter passes the flow test and has around 50 flight hours with no problems.
_________________ David Gallagher
Cincinnati, OH area |
