tomcostanza
Posted: Sat Nov 08, 2008 6:07 am Post subject: Alternator capacity |
Hi all,
What should I consider when I calculate the capacity of an alternator? I've read Bob's posts about never seeing a situation that couldn't be served by a 40A unit. But if I just add the requirements of each item, I get closer to 60A. Should I consider things like landing/taxi lights (I have 4 bulbs (at) 6.5A each), or count them as zero (since they will only be used for a few minutes before, during, and after landing)? What else am I missing?
Thanks.
_________________ Clear Skies,
Tom Costanza
-- in year 17 of a 3 year project |
nuckolls.bob(at)cox.net Guest
Posted: Sun Nov 09, 2008 5:55 am Post subject: Alternator capacity |
At 06:07 AM 11/8/2008 -0800, you wrote:
<Tom(at)CostanzaAndAssociates.com>
Hi all,
If you used landing and taxi lights intermittently
and for short periods of time, they do not become
high-energy loads that beg for continuous support
by the alternator. Do you use all four lights on
at any one time?
On my website at:
http://www.aeroelectric.com/PPS/Load_Analysis/
you will find a number of exemplar spread
sheets where members have conducted their
own detailed load analysis. You can take
one of these and consider it for how changes
to match your airplane would give you a clearer
picture of your operational energy requirements.
There is also a blank form at:
http://www.aeroelectric.com/PPS/Load_Analysis/Blank_Form.pdf
I use this format as the index page to my
wire-book products where the load analysis
becomes a list of all electrical sub-systems
in the airplane, indexes the page were wiring
for that sub-system can be found in the wire-book,
and discusses energy requirements for each
sub-system depending on how and when it is
used in the operation of the airplane. An
exemplar work-in-progress can be seen here:
http://www.aeroelectric.com/Reference_Docs/Misc_PDF/N820JPWB.pdf
Depending on how and in what combinations you
operate appliances in your aircraft, you may well
find that a 40A alternator has the necessary
overhead to run all needed equipment while holding
10A or so in reserve for the purpose of recharging
a battery.
( -Thomas Paine 1776- )
