jonboede(at)hotmail.com Guest
Posted: Sun Nov 09, 2008 8:54 pm Post subject: CJ brake adjustment |
I have a CJ that doesn't like to turn left.
Tested brake pressure at both left and right wheels = about 150 psi.
Changed brake drums and that seemed to help. Was going to change brake pucks but in looking at the current ones C the new ones were exactly the same thickness.
Is there an adjustment to make the brake grab better? Does this mean that the left bladder is going out? How does one check that?
Thanks C
jon
dougsappllc(at)gmail.com Guest
Posted: Mon Nov 10, 2008 9:51 am Post subject: CJ brake adjustment |
Jon,
You most likley have a problem in your QS2 valve. Bladders can be checked by submersion in water to check if it's leaking. I't not impossible that you have a leaking bladder but If you did it would be the first one I have seen. My money is on the hunch that you have a QS2 valve which needs to be replaced or overhauled.
Please contact me off list if you need to order parts.
Always Yakin,
Doug
On Sun, Nov 9, 2008 at 8:54 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
| Quote: | I have a CJ that doesn't like to turn left.
Changed brake drums and that seemed to help. Was going to change brake pucks but in looking at the current ones, the new ones were exactly the same thickness.
jon
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
cjpilot710(at)aol.com Guest
Posted: Mon Nov 10, 2008 9:52 am Post subject: CJ brake adjustment |
In a message dated 11/9/2008 11:55:14 P.M. Eastern Standard Time, jonboede(at)hotmail.com writes:
jon,
You may have a bladder leaking.
Pappy
jon
://www.matronics.com/contribution">http://www.matronics.com/contribution
="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
.matronics.com/">http://forums.matronics.com
AOL Search: Your one stop for directions, recipes and all other Holiday needs. [url=http://pr.atwola.com/promoclk/100000075x1212792382x1200798498/aol?redir=http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=emlcntussear00000001 ]Search Now[/url].
Posted: Mon Nov 10, 2008 2:50 pm Post subject: CJ brake adjustment |
Doug,
If he has equal pressure of 150 PSI on both sides, why would the brake differential valve be the problem?
I'm wondering if a there was/is a bad rear grease seal on the drum which allowed the grease from the rear bearing to be slung out over the brake pucks. If that's the case and I have seen this before, the brake pucks will not grab as well on the one side. Evidence of the grease would be all over the backing plate behind the drum. Remove the pucks and clean them in avgas. The avgas dries rapidly and leaves no oily film on the pucks. Reinstall the pucks and lightly sand them with 60-80 grit sandpaper. Reassemble the wheel assembly and try it out.
Dennis
petervs(at)knology.net Guest
Posted: Mon Nov 10, 2008 3:10 pm Post subject: CJ brake adjustment |
I had this same problem and it was exactly what Dennis described. I was missing the inner felt grease seals and the pucks were contaminated.
Beware, the brakes will be awesome if this was your problem, so go easy on the brake lever the first few flights or you’ll be flat spotting tires.
Pete
__|__
__|__ ----=(*)=---- __|__
----=(*)=---- __|__ ----=(*)=----
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Monday, November 10, 2008 4:50 PM
To: yak-list(at)matronics.com
Subject: Re: CJ brake adjustment
Doug,
Dennis
----- Original Message -----
Sent: Monday, November 10, 2008 11:50 AM
Jon,
Always Yakin,
Doug
jon
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-Listhref="http://forums.matronics.com">http://forums.matronics.com | | 01234567890123456789
Posted: Mon Nov 10, 2008 3:25 pm Post subject: CJ brake adjustment |
Sometimes the QS2-09 rubber seal will devolop a problem and become intermitant. But you do have a point and this bad grease seal (or lack of) should be checked out. Back in the days before I had these seals in constant stock many guys either went without or made their own.
Doug
On Mon, Nov 10, 2008 at 2:49 PM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
[quote] Doug,
Dennis
Posted: Mon Nov 10, 2008 3:36 pm Post subject: CJ brake adjustment |
I changed out the felt seals when I changed the drums. Didn't change the pucks. I suppose what we'll do is change the pucks and dump all the old pucks in a bucket of #1 aviation solvent (that's 100LL for those in Rio Linda) and see if that fixes things.
Anybody have a brake bladder they'd like to sell? Doug is out of stock right now.
Jon
Date: Mon C 10 Nov 2008 15:18:16 -0800
Doug
On Mon C Nov 10 C 2008 at 2:49 PM C A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
[quote] Doug C
If he has equal pressure of 150 PSI on both sides C why would the brake differential valve be the problem?
I'm wondering if a there was/is a bad rear grease seal on the drum which allowed the grease from the rear bearing to be slung out over the brake pucks. If that's the case and I have seen this before C the brake pucks will not grab as well on the one side. Evidence of the grease would be all over the backing plate behind the drum. Remove the pucks and clean them in avgas. The avgas dries rapidly and leaves no oily film on the pucks. Reinstall the pucks and lightly sand them with 60-80 grit sandpaper. Reassemble the wheel assembly and try it out.
Dennis
maggieannya
Posted: Tue Nov 11, 2008 2:14 am Post subject: Re: CJ brake adjustment |
This is Maggie from Xi'an LiChuang Electronics,
We have the hot offer parts as following:
DZ-5 spark plugs,
LS2-10 Brake drums,
LS2-13 Brake Ring,
LS2-70 brake plate
CQ-409 brake chambers
If you have any other requirement,pls feel free to contact me.
Thank you very much.
Yours sincerely,
Maggie
_________________ This is Maggie from Xi'an ATO Electronics.
We are Chinese aircraft parts trader in China |
yakplt(at)yahoo.com Guest
Posted: Tue Nov 11, 2008 8:05 pm Post subject: CJ brake adjustment |
A common problem with older Pilots. Rubber underwear helps to conceal this embarrassing problem, that and not turning left.
From: "cjpilot710(at)aol.com" <cjpilot710(at)aol.com>
Sent: Monday, November 10, 2008 12:52:24 PM
jon,
Pappy
jon
