		nuckolls.bob(at)cox.net Guest
				 Posted: Mon Nov 10, 2008 10:34 am    Post subject: crimp connectors with built-in shrink   tubing? |
				At 09:42 AM 11/10/2008 -0800, you wrote:
 Hey all -
 I'm sure the Connection mentions something about this, but I don't
 have it in front of me (i should know better than to leave it at
 home!) and as I was getting ready to order some shrink tubing, I ran
 across these crimp connectors with shrink tubing already on them.
 They're
 here:  http://cableorganizer.com/heat-shrink/heat-shrink-connectors.html
 What's the deal with these?  Are they awesome?  If not, why not?
 Also, is there a recommended material type for shrink tubing?  Sorry,
 I feel like I could be looking these things up in the Connection, but
 as I said, I'm sitting here daydreaming instead of working.
 any help would be appreciated!
    You won't find them in the book . . . for several reasons.
    These are but one example of many that are offered in
    the marketplace and I have no personal experience with
    them or knowledge about them. I've tried similar products
    from various sources over the years and discarded all of
    them. They tended to be bulkier and/or less secure in the
    wire grip than the PIDG butt splices I stock and use most.
    These are a bit different so I'll get some, see what
    they look like installed and how well they work. Two
    packages of 50 pcs + shipping comes to $37 so they're
    37-cents each at this quanity.
    They tend to be expensive on a joint-for-joint basis
    compared to simply adding heat shrink to less expensive
    or more compact techniques. I can't tell you that these
    particular products are bad or to be avoided. But you'll
    need very few of them to assemble your airplane. In
    terms of performance, they'll work no "better" than
    the process described here:
 http://www.aeroelectric.com/articles/PM_Solder_Sleeve/PM_Solder_Sleeve.html
    I'll give them a try and report back.
         ( . . .  a long habit of not thinking   )
         ( appearance of being right . . .       )
         (                  -Thomas Paine 1776-  )
		schamber(at)glasgow-ky.co Guest
				 Posted: Mon Nov 10, 2008 6:33 pm    Post subject: crimp connectors with built-in shrink   tubing? |
				Bob,
 When I first saw this "comic book" I thought it looked like a lot of
 trouble.  As with everything you suggest I tried it anyway and it was a lot
 of trouble-the first couple of times!!  After that it became my joint of
 choice.  (The rest of you who grew up in the 60s can stop laughing now!)  I
 liked it so much I replaced most of the other splices in my Long-EZ while I
 was installing Dynon units.
 Sam Chambers
 Long-EZ N775AM
