graham(at)gflight.f9.co.u Guest
Posted: Tue Mar 21, 2006 2:14 am Post subject: Europa-List Digest: 13 Msgs - 03/19/06 |
ime: 09:32:32 PM PST US
Subject: Aileron deflection angle
When attaching the ailerons to the wing, the manual calls for 25-deg up
and 22-deg down (for a final travel of 23.5-deg up and 20-deg down).
I don't have any problem with the 22-deg down, in fact, mine goes down
as far as 35-deg. But the up-swing is only about 20-deg. This is after
drilling holes for the anchor nuts to enter the leading edge of the
aileron.
Andrew
you need to start by setting the aileron upward deflections by adjusting the short pushrod at the aileron to give 24 degrees or so. Then adjust the long wing pushrod to make the quick connect bellcrank on the wing vertical when the aileron is neutral. Then continue with the rest of the adjustments.
Graham
