capsteve(at)iflyrv10.com Guest
Posted: Tue Nov 11, 2008 12:30 am Post subject: IFLYRV10.COM parts videos on youtube |
Hi Listers,
I've started posting small videos of some of the parts I'm making on
youtube to get a better look at them.
Also A couple Quick announcements...
IFLYRV10.COM has partnered up with Cleveland Aircraft Tool as a
distributor for most all our products. they are already stocking the most
popular items.
New RV10 seat handle extensions are available and can be viewed at
http://www.youtube.com/watch?v=IwsvkJAIm0U
New RV10 Front Axle assembly is now available and can be viewed at
http://www.youtube.com/watch?v=_EHoDdL_X28
both new products will be on the website within the next day.
thanks for all your support
Steven DiNieri
IFLYRV10.COM
Posted: Wed Nov 12, 2008 7:51 am Post subject: IFLYRV10.COM parts videos on youtube |
Steven C thanks for the video C it really helps.
I went to the Cleveland web site and did not find the front axle parts listed. Can you direct me to them.
Thanks C
JOhn G.
Quote: | From: capsteve(at)iflyrv10.com
Subject: IFLYRV10.COM parts videos on youtube
Date: Tue C 11 Nov 2008 03:15:17 -0500
--> RV10-List message posted by: "Steven DiNieri" <capsteve(at)iflyrv10.com>
Hi Listers C
popular items.
Steven DiNieri
IFLYRV10.COM
Posted: Wed Nov 12, 2008 9:41 am Post subject: IFLYRV10.COM parts videos on youtube |
Hi John,
the seat handle extensions and wheel axle assemblies are going to be added to iflyrv10.com today (tonight- after 7pm). Cleaveland might take a few extra days to add it to their site..
steve
Sent: Wednesday, November 12, 2008 10:50 AM
Subject: RE: IFLYRV10.COM parts videos on youtube
Steven, thanks for the video, it really helps.
JOhn G.
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
toaster73(at)embarqmail.c Guest
Posted: Wed Nov 12, 2008 2:36 pm Post subject: IFLYRV10.COM parts videos on youtube |
Just wondering has there been reports of the newer Van's Al spacers spinning? Just finished installing nose wheel per plans.
Chris Lucas
#40072
effectus(at)rogers.com Guest
Posted: Wed Nov 12, 2008 3:02 pm Post subject: IFLYRV10.COM parts videos on youtube |
Chris,
A fellow who has a '10 at my home airport has had constant problems with
his seals being damaged by the new aluminum spacers. He has been quite
frustrated.
Dave Hertner
Chris wrote:
[quote] Just wondering has there been reports of the newer Van's Al spacers
Chris Lucas
#40072
Posted: Wed Nov 12, 2008 3:45 pm Post subject: IFLYRV10.COM parts videos on youtube |
If you install them and torque them I was under the impression it will still gall the bearing, the spacer needs to be staked or secured against rotation from all I've read.
Rick S.
40185
Posted: Wed Nov 12, 2008 8:21 pm Post subject: IFLYRV10.COM parts videos on youtube |
Rick, the main issue is not allowing the big aluminum axle from tightening
down between the forks. the axle spacers and hub/bearing assembly should
measure several thou longer than the main axle itself. according to ken at
vans, when torqued down the load should be between the forks and bearing,
basically the axle should float a bit between the forks. if the axle was
left short then the preload on the bearing and spacer collar would prevent
it from spinning.
I took the same idea and simply made the contact surface area against
the fork larger. instead of a collar against the fork I use the full surface
area of an end cap design. I cut the axles to be 1/16 shorter than the sum
of the rest of the parts insuring proper bearing preload.
with the end cap design, it can also be pinned easily to the fork for
anti rotation if the builder so requires.... (during my testing of the
design I took 12" channel locks and could not spin the end caps, so I don’t
think pinning will be necessary, but the option is there)
steve dinieri
iflyrv10.com
Sent: Wednesday, November 12, 2008 6:44 PM
Subject: Re: IFLYRV10.COM parts videos on youtube
Rick S.
40185
