info(at)flylightning.net Guest
Posted: Fri Nov 14, 2008 2:17 pm Post subject: Elevator Balance modification. |
To group,
We have just completed flight testing on a modification to the elevator balance. With the development of the SLSA Lightning and the mission of the aircraft changing slightly, a need to make a change to the pitch force required was noted. With the standard wing the roll to pitch force was well harmonized at maneuvering speed and below. With the addition of the long wing tips the roll forces increased but the pitch stayed the same. This resulted in a some what unbalanced feel on the stick. There are two options, lighten the ailerons, or heavy up the pitch. While the first seems the better to get a nice light stick, the over all the mission of the aircraft with the long wing tip is going to be Light sport. So with this in mind and the typical pilot than being a newer light sport pilot or those who have not flown for a while due to a medical or other issue, the thought of making the pitch heavier to harmonize the controls was the better option. We have removed the aerodynamic balance from the elevator completely. The resulting change has increased the stick pull required by a good amount. In our 2008demo the stick force required with the balance to accelerate 1g was 2.5lbs, this is measured with a digital scale on the stick in flight and not a guess. With the balance removed the stick pull required in the same situation was 4.75lbs. This with the longer wing now provides a good feel between both roll and pitch, and I feel this is better for most pilots. An additional side benefit is the elimination of the “soft” spot in the center of pitch, anyone with enough time in a lightning has most likely noticed a small spot in the middle 1” of throw on the stick were its kinda dead, so that’s gone. This is not to say with a short wing that the pitch would too be heavy if one made the modification as well, I think that it would still have good stick feel. I have updated the builders manual online to incorporate this change, it is in section #19 on balance modification. Those of you asking if the roll can be lighten up to match the light pitch feel with the balances, well still working on that but should have a solution in due time.
Thanks for reading my book.
Nick Otterback
Arion Aircraft, LLC
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
dashvii(at)hotmail.com Guest
Posted: Fri Nov 14, 2008 3:42 pm Post subject: Elevator Balance modification. |
Nick C
Ah man C I liked being able to fly with one finger on top of the stick and still be able to manuever. Seriously though I think this will be a good thing for the general aviation community C especially those with low time or more standard aircraft time. Good job and good thinking. Another example of how Arion continues to make improvements to the product in order to make the plane safer C easier C and more enjoyable to fly! Brian W.
To: lightning-list(at)matronics.com
Subject: Elevator Balance modification.
Date: Fri C 14 Nov 2008 16:19:12 -0600
.ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass span.EC_EmailStyle17 {font-family:Arial;color:windowtext;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
To group C
We have just completed flight testing on a modification to the elevator balance. With the development of the SLSA Lightning and the mission of the aircraft changing slightly C a need to make a change to the pitch force required was noted. With the standard wing the roll to pitch force was well harmonized at maneuvering speed and below. With the addition of the long wing tips the roll forces increased but the pitch stayed the same. This resulted in a some what unbalanced feel on the stick. There are two options C lighten the ailerons C or heavy up the pitch. While the first seems the better to get a nice light stick C the over all the mission of the aircraft with the long wing tip is going to be Light sport. So with this in mind and the typical pilot than being a newer light sport pilot or those who have not flown for a while due to a medical or other issue C the thought of making the pitch heavier to harmonize the controls was the better option. We have removed the aerodynamic balance from the elevator completely. The resulting change has increased the stick pull required by a good amount. In our 2008demo the stick force required with the balance to accelerate 1g was 2.5lbs C this is measured with a digital scale on the stick in flight and not a guess. With the balance removed the stick pull required in the same situation was 4.75lbs. This with the longer wing now provides a good feel between both roll and pitch C and I feel this is better for most pilots. An additional side benefit is the elimination of the “soft” spot in the center of pitch C anyone with enough time in a lightning has most likely noticed a small spot in the middle 1” of throw on the stick were its kinda dead C so that’s gone. This is not to say with a short wing that the pitch would too be heavy if one made the modification as well C I think that it would still have good stick feel. I have updated the builders manual online to incorporate this change C it is in section #19 on balance modification. Those of you asking if the roll can be lighten up to match the light pitch feel with the balances C well still working on that but should have a solution in due time.
Nick Otterback
Arion Aircraft C LLC
ww.matronics.com/contribution
st">http://www.matronics.com/Navigator?Lightning-List
ronics.com
| Stay up to date on your PC C the Web C and y19462413/direct/01/' target='_new'>Click here [quote][b]
EAFerguson(at)AOL.COM Guest
Posted: Fri Nov 14, 2008 7:58 pm Post subject: Elevator Balance modification. |
In a message dated 11/14/2008 6:43:01 P.M. Eastern Standard Time, dashvii(at)hotmail.com writes:
To group,
Nick Otterback
Arion Aircraft, LLC
Nick,
I like the light control forces, and don't think they are a problem for low time pilots. Certainly not for wrinkles like me who have lost medicals.
So I have two other suggestions.
The obvious one (but a major mod) is to lengthen the main wing and move the aileron out, then shorten the tip but include the winglet. This keeps the same wing area, but provides a little more aileron control. A clean solution, but a major re-tooling.
The other suggestion is less obvious, but easier. Reduce the wing tip length keeping the winglets. To keep the Light Sport stall speed, use the VG's on the outboard wing to provide better stall characteristics (the inner wing will stall first). My guess is that VGs in front of the ailerons would be all you would need.
The VG's they do reduce the stall speed and so do the winglets. The only objection to the VGs in that configuration would be minor inconvenience when washing the bird. The combination should work and keep the light roll control force. I had to reduce stall speed by 2 knots from the clean wing on mine for Light Sport, and the full wing VGs did exactly that. I've since taken off the inner 4 on each side with no measurable change in stall speed, but a slight improvement in stall warning. We could test this suggested mod on my LS Lightning (hint, hint).
BTW, To me the increased roll control force is more of a distraction than the lack of harmonizing (matching) the pitch and roll forces. I don't think I will like the increased pitch effort. As you know, I kept some bungees on my pitch control with the new trim tab. With the right amount of bungee the stick balances nicely on the ground, and reduces required up trim in flight.
Soft spot in the center of pitch? Not a problem in my Lightning. Maybe I'm numb, but I haven't noticed this effect in 250 hours. If it's there it certainly isn't objectionable.
My 2c worth.
Earl Ferguson
Get the Moviefone Toolbar. Showtimes, theaters, movie news & more!
wb2ssj(at)frontiernet.net Guest
Posted: Sat Nov 15, 2008 4:54 am Post subject: Elevator Balance modification. |
Earl, My vote would be for lighter stick forces also. When flying more precise movements and control are possible. Get in a J3 cub and you find out what heavy is like. No thank you
jhausch
Posted: Sat Nov 15, 2008 6:51 am Post subject: Re: Elevator Balance modification. |
I have only a demo flight in the lightning, but if (when) I build my plan was to figure out a a way to increase the forces in pitch - long wing tips or not.
I think I know what the mod looks like - I assume the counterbalance horn has gone from full length, to half-length, and now to no horn at all.
J Dupont
Posted: Sat Nov 15, 2008 10:35 am Post subject: Re: Elevator Balance modification. |
| info(at)flylightning.net wrote: | To group,
An additional side benefit is the elimination of the “soft” spot in the center of pitch, anyone with enough time in a lightning has most likely noticed a small spot in the middle 1” of throw on the stick were its kinda dead, so that’s gone. [b] |
This is a very big improvement to me . To me it's 10 times more important than stick forces. When I get my aircraft, it is one of the 5 most important criteria I will check.
I have limited flying experience but I have been racing cars before and operating heavy machineries and cranes of all kinds and the response of the controls is crucial in any precision task.
Can't wait to try it when I find time to finally go see the Lightning.
Janin Dupont
Canada
N1BZRich(at)AOL.COM Guest
Posted: Sat Nov 15, 2008 5:05 pm Post subject: Elevator Balance modification. |
In a message dated 11/15/2008 7:55:43 A.M. Eastern Standard Time, wb2ssj(at)frontiernet.net writes:
| Quote: | | Get in a J3 cub and you find out what heavy is like. |
What's the matter Tex, no muscles in your right arm? Yes the Cub is way heavier than the Lightning, but you haven't felt heavy until you try to fly a Saratoga in a missing man formation fly by. I had to borrow a Saratoga last week for a "missing lady" formation fly by. My airplane was at another airport and weather had kept me from changing out airplanes, and there was no way the Cub was going to keep up with a Cirrus and two other fast homebuilts. Anyway, the Saratoga was like a truck - a large dump truck. My Cub really felt light after that flight. But hey, everyone said the formation looked great - so you make do with what you have to work with.
Buz
Posted: Mon Nov 17, 2008 6:56 am Post subject: Elevator Balance modification. |
I would like to make one more comment I did not earlier.
Even with the balance removed it is still possible to rig back in the sensitivity if you wish. Since we have already got the rigging set to make it heavier with the mod in place it can be rigged out to get the pitch light if you have the short wing….so what ever you like.
nick
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Brian Whittingham
Sent: Friday, November 14, 2008 5:42 PM
Subject: RE: Lightning-List: Elevator Balance modification.
Nick,
Ah man, I liked being able to fly with one finger on top of the stick and still be able to manuever. Seriously though I think this will be a good thing for the general aviation community, especially those with low time or more standard aircraft time. Good job and good thinking. Another example of how Arion continues to make improvements to the product in order to make the plane safer, easier, and more enjoyable to fly! Brian W.
Date: Fri, 14 Nov 2008 16:19:12 -0600
To group,
Nick Otterback
Arion Aircraft, LLC
| Quote: | | ww.matronics.com/contributionst">http://www.matronics.com/Navigator?Lightning-Listronics.com |
Stay up to date on your PC, the Web, and y19462413/direct/01/' target='_new'>Click here 0123456789 | Quote: | | ww.matronics.com/contribution | 0 | Quote: | | ww.matronics.com/contribution | 1 | Quote: | | ww.matronics.com/contribution | 2 | Quote: | | ww.matronics.com/contribution | 3 | Quote: | | ww.matronics.com/contribution | 4 | Quote: | | ww.matronics.com/contribution | 5 | Quote: | | ww.matronics.com/contribution | 6 | Quote: | | ww.matronics.com/contribution | 7 | Quote: | | ww.matronics.com/contribution | 8
Posted: Mon Nov 17, 2008 7:04 am Post subject: Elevator Balance modification. |
Just to let everyone know because I think I have scared everyone…the pitch force being 4.75lbs per g is less than half of your normal Cessna. Cessnas are not light but they aren’t dump trucks either.
nick
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Tex Mantell
Sent: Saturday, November 15, 2008 6:55 AM
Subject: Re: Lightning-List: Elevator Balance modification.
That is correct.
nick
Posted: Mon Nov 17, 2008 7:06 am Post subject: Elevator Balance modification. |
Good read earl some ideas too. I am sending a set of standard tips to peter Discher in Australia. Him and a friend are going to work out a set of winglet equipped standard tips…something to watch I think.
Nick
Do the wrinkles help for LSA and slow you down? You now aerodynamic breaking?
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of EAFerguson(at)AOL.COM
Sent: Friday, November 14, 2008 9:57 PM
To group,
Nick Otterback
Arion Aircraft, LLC
Nick,
My 2c worth.
Earl Ferguson
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Lightning-List">http://www.matronics.com/Navigator?Lightning-List
selwyn
Posted: Mon Nov 17, 2008 6:10 pm Post subject: Re: Elevator Balance modification. |
Hi Nick,
Nothing like timing, I just finished my elevator mods on Sunday!
A couple of questions though:
- Could we have more information on the rigging changes?
- What effect does the balance change have on trim effectiveness? Given that the thing was already marginal on nose up trim in landing config what is it like with these changes?
| info(at)flylightning.net wrote: | I would like to make one more comment I did not earlier.
nick
_________________ Cheers, Selwyn
Kit 66 VH-ELZ |
Wayne Lenox
Joined: 07 Jan 2008 Posts: 75 Location: Arizona in the winter
Posted: Sun Jan 04, 2009 11:58 am Post subject: Re: Elevator Balance modification. |
Nick
I have just completed the modification to the elevator balance on N123WL. I think the elevator feel is much better then before. It is by no way heavy and much more balanced with the aileron's. I like the modification, it helps the Lightning fly much easier in turbulence.
I will try to attach pictures.
Wayne
N123WL
pequeajim
Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
Posted: Sun Jan 04, 2009 1:38 pm Post subject: Elevator Balance modification. |
Thanks Wayne for the update on the elevator modification. Do you think that
the elevator is less responsive in the middle range now, (maybe less
touchy)?
Wayne Lenox
Posted: Sun Jan 04, 2009 1:57 pm Post subject: Elevator Balance modification. |
Jim
I have only flown with the change for 0.8 hrs, and like the changes. It is less touchy at all speeds. As far a the elevator being less responsive, I am not sure, but it has way more elevator then needed.
Wayne
N123WL
-- "Jim Langley" <pequeajim(at)gmail.com> wrote:
--> Lightning-List message posted by: "Jim Langley" <pequeajim(at)gmail.com>
touchy)?
pequeajim
Posted: Sun Jan 04, 2009 2:02 pm Post subject: Elevator Balance modification. |
I think less touchy was what I meant. Well, that is a good thing then…
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Wayne Lenox
Sent: Sunday, January 04, 2009 4:55 PM
Subject: RE: Re: Elevator Balance modification.
Jim
Wayne
N123WL
touchy)?
jhausch
Posted: Mon Jan 05, 2009 3:26 am Post subject: Re: Elevator Balance modification. |
Thanks for posting those pics and providing your impressions of the change.
Are you going to do any testing for flutter near Vne?
Wayne Lenox
Posted: Mon Jan 05, 2009 6:39 am Post subject: Elevator Balance modification. |
I think I will leave that to Nick.
Wayne
-- "jhausch" <jhausch(at)charter.net> wrote:
--> Lightning-List message posted by: "jhausch" <jhausch(at)charter.net>
http://forums.matronics.com/viewtopic.php?p=222934#222934
========================bsp; - The Lightning-List Email Forum -
[url=_blank]Click for VA loan resources and rate quotes.[/url]
Posted: Mon Jan 05, 2009 10:11 am Post subject: Elevator Balance modification. |
Wayne,
Great I was waiting to here on the mod....At least you have good weather to
fly!
Nick
Posted: Mon Jan 05, 2009 10:21 am Post subject: Elevator Balance modification. |
I have had the prototype to Vne several times with the balance mod done and
it is not a problem...with attempts to induce flutter none was found.....
nick
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
