Colin K.
Posted: Sun Nov 16, 2008 1:46 pm Post subject: Nose wheel forks and axle |
Section 38 of the manual says
"5.Locate the phenolic nose fork spacers (see photo below) and the AN3-26A bolts, AN960-10 washers (one washer under head and another under nut) and AN365-1032A nylocks."
Even with the washer under the head removed, not enough threads protrude through to secure the nut. Should I get longer bolts or sand the phenolic spacers?
The nose wheel axle bolt shank is too short to pass though both forks, such that the threaded portion is passing through the second fork. Do I need a bolt with a longer shank, or is this acceptable?
By making the axle spacers the right length, I can make the wheel bearings ride on the shank.
Colin K.
OK
Lightning # 52 under construction.
http://www.mykitlog.com/cojaken
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
_________________ Colin K.
OK |
jeynon2
Joined: 25 Oct 2007 Posts: 24 Location: Southern Illinois
Posted: Sun Nov 16, 2008 3:27 pm Post subject: Nose wheel forks and axle |
Colin,
As I recall, I needed longer bolts for the nose fork assembly, and the stop bolt. �I think the spacer blocks are a little larger now then they were originally, which changed the required hardware. �I'm pretty sure I used the original axle bolt though.
John Eynon
( Purveyor of Quality Correspondence Since 1983 )
Colin K.
OK
Quote: |
href="http://www.matronics.com/Navigator?Lightning-List">http://www.matronics.com/Navigator?Lightning-List
| [b]
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
