tshank(at)core.com Guest
Posted: Wed Mar 08, 2006 6:18 pm Post subject: Unstable Tach |
I remember this being discussed in the past but I have not been able to
locate anything with the search engine. I have a Status Suburu and a VDO
tach. Above 3000 RPM's the tach become unstable, jumping 1000 RPM's or
more at a time. I have tried some filtering on the line with no success.
When I switch the tach to the secondary ignition it is stable. I was
hoping someone had solved this before, so I have to cart my Tectronics
scope out to the shop and try to track this down.
Tim Shankland
thilo.kind(at)gmx.net Guest
Posted: Wed Mar 08, 2006 8:32 pm Post subject: Unstable Tach |
Hi Tim,
I had a similar experience with my Micro Tach 100 on a Rotax 912. Finally
installed a resitor in the sensing wire - problem solved. I'm not home right
now, but I think it was 47 K.
Good luck
Thilo Kind> --- Ursprngliche Nachricht ---
| Quote: | Von: Tim & Diane Shankland <tshank(at)core.com>
An: Zenith List <zenith-list(at)matronics.com>
Betreff: Unstable Tach
Datum: Wed, 08 Mar 2006 21:11:29 -0500
Tim Shankland
"Feel free" mit GMX FreeMail!
Monat fr Monat 10 FreeSMS inklusive! http://www.gmx.net
frank.hinde(at)hp.com Guest
Posted: Thu Mar 09, 2006 6:58 am Post subject: Unstable Tach |
Sometimes (quite often actually) the coils go bad (low resisatnce on the
primary side...It usually frys the $300 ignitor chip too so you need to
check this out before your next flight).
I could how this might cause it...Check your primary coil resistance,
should be about 1.1 ohms I believe.
Try swapping just the coils and see if the problem follows the coil.
Frank
Posted: Thu Mar 09, 2006 6:52 pm Post subject: Unstable Tach |
Thanks for the suggestions, I all ready have tried resistors, either no
effect or no tach, I'll check the coil although the engine only has
about 6 hours on it and I haven't flown it yet. And I will check for
inductive coupling and maybe swap the coils.
Tim Shankland
Frank
Posted: Fri Mar 10, 2006 7:20 am Post subject: Unstable Tach |
The good thing is there aren't many things it can be. You know it is not
the tach, so it has to be something to do with an ignition component.
Just a thought Tim, are you using a changeover switch between one
ignition system and the other?
If you have you do realise you have just connected the ignitions
together. It is not impossible for that switch to short to ground and it
could ground out both your ingitons and stop you engine running.
Likely?...No, but it is generally not a good idea to rely on a single
component in a critical application.
Frank
Posted: Fri Mar 10, 2006 5:19 pm Post subject: Unstable Tach |
I am using a switch to change the tach form one ignition to the other,
true a shorting of the switch could cause the selected one to fail. I
guess I could include a 1 or 2 K resistor in series with those lead to
protect from that possibility.
Frank
Posted: Thu Mar 16, 2006 8:01 pm Post subject: Unstable Tach |
This is just a continuation of my previous posts. As suggested I checked
for inductive couplings etc. No repositioning of the wiring made any
difference. It was time for the big guns, I carted my Techtronics 4
channel rack mount scope out to the plane, it might have handles but it
is not very portable. Anyway the normal wave form is a 10 msec step down
to about -10 volts followed by an upward step to + 20 volts for 5 msec
then back to 0. There is some ringing on both ends of the 20 volt step.
The problem appears to be rather high voltage (15-20 volt) high
frequency (5-10 microsec) noise that occurs above 3000 RPM usually in
the middle of the -10 volt step. Since there was a significant frequency
difference between the good and bad signal I constructed a filter, a 10K
resistor connected to one end of two 12 volt zener diodes back to back
with the other end to ground and a 0.2 uF capacitor across the the
diodes. Checked it out today and all tack operation is smooth.
TIm Shankland
rdewees(at)mindspring.com Guest
Posted: Fri Mar 17, 2006 5:40 am Post subject: Unstable Tach |
Wow Tim,
You really got into the guts of the problem didn't you? Thanks so
much. One nagging question tho-- my tach is unstable (inoperative)
below 1000 rpm. Any ideas what's going on? Voltage too low as opposed
to too high? Suggestions?
Ron DeWees
Tim & Diane Shankland wrote:
TIm Shankland
JAPhillipsGA(at)aol.com Guest
Posted: Fri Mar 17, 2006 8:31 am Post subject: Unstable Tach |
Tim, for dim fellow like myself with the same tac problem how do I fix it,
again??? You got a drawing or some photos ? Hope to hear from you, Bill of
Georgia N505WP 601XL-3300
Posted: Fri Mar 17, 2006 8:56 am Post subject: Unstable Tach |
Are we sure the coil on this ignition system is not going south...there
have been a number of failures of the IC107 coil used extensively on
Subaru powered airplanes.
Frank
Posted: Fri Mar 17, 2006 5:15 pm Post subject: Unstable Tach |
Ron,
It's really hard to tell without looking at the signal, that's why I
used the scope. (Funny I looked at a portable scope at Osh. last year in
the consignment test and almost bought it, carting the big one out makes
me wish I had.) As I described the tach, at least in my case sees a
square wave at each plug firing and the amplitude did not change
significantly with RPM. If you do not get any tach operation below 1000
it could mean that you have a problem with your tach. If it is a
problem with insufficient signal it will be much more difficult in
that an active addition ( amplifier) would be necessary rather than a
simple passive filter.
Tim Shankland
ron dewees wrote:
Wow Tim,
Ron DeWees
>TIm Shankland
Posted: Fri Mar 17, 2006 5:44 pm Post subject: Unstable Tach |
Frank,
As I mentioned in an earlier post the airplane has not flown yet. It
would seem though if there is a problem that it would be with the
ignition module. The extra noise pulse comes right in the middle of the
-10 volt excursion. but doesn't effect the level. That is I have a
straight line at -10 volts with the noise pulse in the middle but still
a steady straight level after it. Since it occurs exactly at 3000 RPM
every time I'm wondering if it has something to do with the centrifugal
spark advance? The information I have on the engine gives me lost of
info about the cooling system but nothing about the spark advance. I
guess I could use a timing light to determine when the spark advance
starts to see if there is any relationship.
Tim Shankland
Frank
It's a real simple circuit, I'll draw it up and post it. It might take a
day to get to it.
Tim Shankland
JAPhillipsGA(at)aol.com wrote:
Posted: Sat Mar 18, 2006 9:09 am Post subject: Unstable Tach |
Are U running the standard Sooby ignition chip? (I think you said you
have a Stratus right?) If so they are notoriously feeble. Normally they
either work or they don't though.
I've junked mine in favour of the TP45 NAPA unit.
Frank
Posted: Sat Mar 18, 2006 7:22 pm Post subject: Unstable Tach |
Frank,
Yes, I'm running a Stratus, so far the standard ignition starts and
runs. As I mentioned in a previous post my current working theory is a
vibration in the centrifugal advance. I do notice what seemed to be a
slight roughness that occurs with the tach instability. I'm going to put
the prop back on and run the engine up to a higher RPM to see if the
roughness is just in the mid range. If my theory is correct it will end
when the centrifugal advance hits it's high end stop.
Frank
Posted: Mon Mar 20, 2006 7:45 am Post subject: Unstable Tach |
Check to see how much side play you have on the distributor shaft and if
it might be coming into contact with the pick up...Or indeed could be
getting too far away. There should be very little side play (None!) but
the reality is a lot of them do. I'm thinking you could be hittng a
resonance frequency that pulls the shaft to one side.
Have you swapped the coils just for fun?...If you have a leaky low
tension side then this could in effect be grounding out the chip...It
would would be a quick test in any case if only to discount the theory.
Frank
Posted: Mon Mar 20, 2006 6:52 pm Post subject: Unstable Tach |
Frank,
I had previously checked the shaft for play and found none, and it
doesn't appear to be coming into contact with the pickup. I did put the
prop back on yesterday and ran up the engine. I have my filter on now so
the tach is steady at all speeds. Engine smooth at 4000 RPM's and up
maybe a little roughness between 3000 and 4000, hard to say. Ran up to
5400 RPM, going to have to add a little pitch in the prop, I still had
some throttle left. I looked into swapping coils, but I didn't want to
have to dig into that wiring at this point. I might if I get some other
things done.
Frank
