Nosewheel bearing question
czechsix(at)juno.com
PostPosted: Mon Mar 20, 2006 9:16 pm    Post subject: Nosewheel bearing question Reply with quote
Guys (those of you with a nosedragger),
I still don't have my wheel fairings on. This weekend during preflight I
noticed some black goo, tar-like stuff oozing out around the rubber
bearing seals on my nosewheel. It did not appear until I had about a
dozen landings on the airplane. Since the grease that was in it
originally was the normal amber color I was a bit surprised to see this
color, and also a bit surprised to see it leaking out as it had been
perfectly clean up until this point. Anybody else seen such a thing?
I also checked the rolling friction of the tire and it is still REALLY
stiff to turn by hand. I know that when a wheel is properly installed
there should be enough load on the bearing to provide friction....i.e. it
should not continue to spin around freely after you give it a whirl by
hand. But from the first time I installed the nosewheel--properly
torqued per the plans with a calibrated wrench--it seemed excessively
stiff to me. I remember the plans said that it would be this way until
it was broken in a bit. I don't know how long that should take but I
checked the nosewheel on my hangar mate's new -7A (with fewer hours than
I have) and his wheel turned much easier. I tried loosening the nut on
the axle bolt and that made it turn more freely but then I noticed that
the spacers were spinning too. I torqued it back up and now it's
ridiculously stiff again. My hangar mate's -7A has the wheel pant
installed so I can't see whether the spacers are spinning on his. I
called Vans and Gus said that it's quite common for people to call and
complain that the spacers have been spinning instead of the bearing and
galling up the fork assembly. He suggested that I could put some screws
in through the fork into the spacer to keep them from spinning. This
would allow me to reduce the pressure/friction on the bearings, but he
cautioned against reducing the torque on the axle bolt too much since
Matco calls out 7-10 ft lbs for this assembly.
Personally I think the whole design is a bit iffy from the perspective
that there's a very small margin between having enough pressure to keep
the spacers from turning without so much pressure the that rotational
friction on the bearings/seals is excessive. It makes me wonder how many
people are flying around out there with the wheel pants on, completely
unaware that the spacers are spinning away while the bearings are doing
nothing. On the other hand, if the rotational friction is excessive it
*may* have contributed to some of the bent nose gear incidents that have
occurred in recent years. It's pretty scary watching the nosegear at
high speed, even during a good landing....the more rotational friction,
the further the gear is going to bend back/under when it first makes
contact at high speed. I think I'll disassemble the whole thing, check
the bearings for overheating, repack them, put screws in through the
fork/spacer assembly, and tighten it up until it feels "about right".
Any comments/experience from others with this assembly would be
appreciated. FWIW, I understand that the -6A's had a different design
(which some local RVators consider to be superior to the current
design...).
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D flying 15.8 hours
Charles Heathco
PostPosted: Mon Mar 20, 2006 9:41 pm    Post subject: Nosewheel bearing question Reply with quote
Mark, I would asume the dark stuff is grease. as for the tightness/spacers
spinning, I noticed the spacers spinning problem (I didn build the 6a)When
I took off the wheel at cond insp. I ended up adding a washer on one side of
spacer which allowed me to tighten the axel bolt properly without binding
the wheel. Charlie heathco
Hopperdhh(at)aol.com
PostPosted: Tue Mar 21, 2006 4:45 am    Post subject: Nosewheel bearing question Reply with quote
I had this same problem (spacers turning by the torque of the seals) when I
first flew my -7A. At first I was going to put in roll pins like a Cessna
150, but decided on a different solution which has worked very well.
I made a steel sleeve about 3/4 inch OD to put between the bearing spacers
on the axle bolt inside of the wheel. Once this sleeve was fine tuned to the
correct length, I could tighten the axle bolt to full torque without actually
having the bearings support the bolt tension. To support the sleeve while
taking the nose wheel on and off, I have a length of 3/8 inch rod that gets
pushed through when installing the axle bolt. This rod is a little shorter
than the distance between the forks.
Dan Hopper
RV-7A Flying 148 hours
SSoule(at)pfclaw.com
PostPosted: Tue Mar 21, 2006 5:04 am    Post subject: Nosewheel bearing question Reply with quote
Dan,
This sounds interesting. What did you use for the stock from which you made
the sleeve?
Steve Soule
Vermont
alexpeterson(at)earthlink
PostPosted: Tue Mar 21, 2006 5:25 am    Post subject: Nosewheel bearing question Reply with quote
SNIP
perspective that there's a very small margin between having
enough pressure to keep the spacers from turning without so
much pressure the that rotational friction on the
completely unaware that the spacers are spinning away while
the bearings are doing nothing. On the other hand, if the
incidents that have occurred in recent years. It's pretty
scary watching the nosegear at high speed, even during a good
landing....the more rotational friction, the further the gear
is going to bend back/under when it first makes contact at
through the fork/spacer assembly, and tighten it up until it
be appreciated. FWIW, I understand that the -6A's had a
different design (which some local RVators consider to be
superior to the current design...).
--Mark Navratil
Cedar Rapids, Iowa
Mark, am I correct in understanding that on the newer (non 6A) nosewheel
designs that the tapered roller bearings take the load from the axle bolt?
If so, this is a terrible design. The 6A has a stout, hollow aluminum tube
taking the load between the two larger hollow cylinders which directly touch
the fork. This is as Dan has described that he did on his 7A. On my 6A, I
could tighten the axle bolt until it breaks, and the wheel bearings will not
be affected.
Please tell me that the new design doesn't simply have the bolt mash the
bearings with nothing in between, although I heard this also from a local
builder. This simply isn't acceptable. Put a thrust tube in between, and
use some shim stock to tweak it in. Van makes the best product available,
but sometimes I feel they put more emphasis on hiring people with airplane
building experience and not engineering.
It is easy to imagine bad things happening when things in that assembly
deflect under load...
Alex Peterson
RV6-A N66AP 729 hours
Maple Grove, MN
PostPosted: Tue Mar 21, 2006 5:42 am    Post subject: Nosewheel bearing question Reply with quote
Steve,
The spacer is made of mild steel rod. Aluminum would be OK, I think.
Actually, I had help. The idea should be credited to a local craftsman named Carl
McCain. He first used the idea on an RV-9A. From another post I see that
the 6A used something similar, and that it is good engineering practice. Glad
to see I wasn't flamed right away!
Dan
RV-7A
N766DH
In a message dated 3/21/2006 8:05:02 A.M. Eastern Standard Time,
SSoule(at)pfclaw.com writes:
Dan,
the sleeve?
Steve Soule
Vermont
Mark Phillips in TN
PostPosted: Tue Mar 21, 2006 8:31 am    Post subject: Nosewheel bearing question Reply with quote
Mark, Charlie, Alex & Dan-
I've got the same problem as Mark on my -6A. Having to leave the nut on the
axle bolt looser than spec just so the wheel turns has "worked" for almost 300
hours, but still makes me nervous- grateful for this discussion! When Mark
sent the original post, I dragged out dwg. 62 from my preview plans and it
shows the older style Cleveland wheel- there is a long aluminum "axle" (U-609)
that is trapped between the fork halves and allows the bolt to be properly
tightened, and thus no side-load on the bearings. My nosewheel sounds just like
Mark's, with the separate spool on each side. Does anyone have the actual
drawing (not preview) that shows the current (Matco) configuration and does it show
a spacer between the two spools?
The way Dan fixed it almost sounds like a no-brainer and would explain a lot,
but I'm really wondering how many of us "sissies" are out there with a bogus
nosewheel arrangement because the design was changed and the prints were
either not updated or wrong? (spacer omitted?)
By the way, I just had to replace my nose tire due to wear (300 hours- does
this sound a bit soon?), which obviously is accelerated by the tire rotational
resistance. I've also been told I have occasional shimmy in my front gear
which is likely related as well. Carefully balancing the new wheel did seem to
help that problem considerably, though...
Mark Phillips
From The PossumWorks...
PostPosted: Tue Mar 21, 2006 8:50 am    Post subject: Nosewheel bearing question Reply with quote
Mark,
The shimmy problem is usually due to too free of swivel of the castoring
nose wheel. My gear leg had a problem that would lead to abnormal wear causing
this joint to become loose. The collar at the top was not square to the
bearing. I forget the exact arrangement right now, but I filed a long time
getting it to meet over the whole area. Part of the bend of the gear leg actually
went below the collar -- not a perfect situation! I have never had a shimmy
problem when the castor nut was tightened to spec. High tire pressure would
also aggravate shimmy. I run about 32 psi. This seems high but I have the
200 hp angle valve engine.
Dan Hopper
RV-7A Flying 149 hours
In a message dated 3/21/2006 11:34:10 A.M. Eastern Standard Time,
Fiveonepw(at)aol.com writes:
=04????=1Bmip://02bb2b68/default.html ????=1Bmip://02bb2b68/default.html =20=0E=E4=84=80
=0FQ=C3=80=13=01=14=15=17?
300
(U-609)
that is trapped between the fork halves and allows the bolt to be properly=20
like
it show
lot,
rotational
to
Mark Phillips
ronlee(at)pcisys.net
PostPosted: Tue Mar 21, 2006 9:33 am    Post subject: Nosewheel bearing question Reply with quote
rotational
seem to
I thought I had a nose wheel shimmy problem and tried many things to fix it.
It was not until I had someone videotape me taxiing that it led to the real
problem being an unbalanced nosewheel/tire assembly.
Ron Lee
Mark Phillips in TN
PostPosted: Tue Mar 21, 2006 9:54 am    Post subject: Nosewheel bearing question Reply with quote
In a message dated 3/21/06 10:53:19 AM Central Standard Time,
Hopperdhh(at)aol.com writes:
nose wheel.
After watching a guy in another -6A land at a gas stop a couple of years ago
with his nosewheel slamming furiously from stop to stop (he didn't even
realize it was happening!!) I'm pretty meticulous about the tension- it's been
checked several times with the fish scale and by "feel" anytime the nose it up and
has only been adjusted once since new. I WILL check squareness at top busing
as you suggest, but balancing the new tire seems to have helped the most-
also, I have no stiffeners on the leg, FWIW...
Thanks, Dan-
Mark
rv6(at)grandecom.net
PostPosted: Wed Mar 22, 2006 4:16 am    Post subject: Nosewheel bearing question Reply with quote
Quoting Hopperdhh(at)aol.com:
This is exactly what we have done on all the RV's we have built and it seems to
work very well.
Ted
the
actually
Dan Hopper
