patreilly43(at)hotmail.co Guest
Posted: Sun Nov 23, 2008 6:05 pm Post subject: 582 Coolant routing |
582 drivers C I have a grey head 582 and see pictures of blue heads with what appears as an external coolant pump that routes coolant to the head via a hose. My grey head has an elbow into the water pump at the base of the engine and I assume coolant routes to the head thru passageways inside the engine. Am I seeing this right? Is this a difference between the blue and grey head 582? Also C what is the brand name of the expansion chamber for the 582?
Thank You
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
aerobatics(at)aol.com Guest
Posted: Sun Nov 23, 2008 6:21 pm Post subject: 582 Coolant routing |
hi Pat Rockford? I am in Champaign area
Yes Grey and Blue are different. The additional hose I believe was a
bypass to help prevent shock cooling... are u close to flying urs?
Dave
KF 2
Posted: Sun Nov 23, 2008 6:30 pm Post subject: 582 Coolant routing |
Dave
KF 2
Posted: Sun Nov 23, 2008 6:37 pm Post subject: 582 Coolant routing |
Dave C Should be ready to fly early spring.
Pat Relly
Mod 3 582 Rebuild
Rockford C IL
| Quote: | To: kitfox-list(at)matronics.com
Subject: Re: 582 Coolant routing
Date: Sun C 23 Nov 2008 21:30:31 -0500
--> Kitfox-List message posted by: aerobatics(at)aol.com
Dave>=========
Posted: Sun Nov 23, 2008 7:34 pm Post subject: 582 Coolant routing |
great lets keep in touch if I can help.... I have about 450 hours
behind mine plus lots of good exp here from the group...
I fly to Morris for sun am breakfast often and flown to osh...
Dave
Guy Buchanan
Posted: Sun Nov 23, 2008 9:23 pm Post subject: 582 Coolant routing |
At 06:04 PM 11/23/2008, you wrote:
| Quote: | Is this a difference between the blue and grey head 582?
Yes, it's the primary difference. When the thermostat closes the blue
head simply by-passes the radiator and continues to circulate flow
through the pump and cylinders. When the thermostat closes on a grey
head all flow stops. I guess I should assume you're going to ask if
it's necessary or desirable to change and my answer will be no. The
great peril for the 582 is and was cold seizure, where after a
low-throttle descent the thermostat is closed and the water in
outside the engine is nice and cold. Suddenly you need full throttle,
the engine heats, the thermostat opens, and all that nice cold water
dumps into the cylinders. This causes the cylinders to contract
faster than the pistons and the engine seizes. The blue head
mitigates this somewhat by mixing the incoming cold water with
circulating warm water. (You could still cold seize if you had a lot
of really cold water in the radiator, though.) The answer for the
grey-headers is: DON'T DO THAT. Meaning never do long descents
throttle off with the thermostat closed, (water temp < 134F,) and
then put yourself into a situation where you'll have to hammer the
throttle. Either descend throttle-on, or when you get to the bottom,
gingerly open the throttle, as you would during warm-up, to about
3000 rpm until the thermostat opens.
| Quote: | Also, what is the brand name of the expansion chamber for the 582?
Rotax. (Unless you go after-market. See http://www.paraflite.net/muffler.htm)
Guy Buchanan
San Diego, CA
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
msm_9949(at)yahoo.com Guest
Posted: Mon Nov 24, 2008 9:17 am Post subject: 582 Coolant routing |
Also, you can (and should) install Lowell's dandy rad shutter which, when closed, will help keep water temps up during low-throttle descents.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1
--- On Mon, 11/24/08, Guy Buchanan <bnn(at)nethere.com> wrote:
| Quote: | From: Guy Buchanan <bnn(at)nethere.com>
Date: Monday, November 24, 2008, 12:10 AM
| Quote: | --> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com>
Yes, it's the primary difference. When the thermostat closes the blue head
simply by-passes the radiator and continues to circulate flow through the pump
and cylinders. When the thermostat closes on a grey head all flow stops. I guess
I should assume you're going to ask if it's necessary or desirable to
change and my answer will be no. The great peril for the 582 is and was cold
seizure, where after a low-throttle descent the thermostat is closed and the
water in outside the engine is nice and cold. Suddenly you need full throttle,
the engine heats, the thermostat opens, and all that nice cold water dumps into
the cylinders. This causes the cylinders to contract faster than the pistons and
the engine seizes. The blue head mitigates this somewhat by mixing the incoming
cold water with circulating warm water. (You could still cold seize if you had a
lot of really cold water in the radiator, though.) The answer for the
grey-headers is: DON'T DO THAT. Meaning never do long descents throttle off
with the thermostat closed, (water temp < 134F,) and then put yourself into a
situation where you'll have to hammer the throttle. Either descend
throttle-on, or when you get to the bottom, gingerly open the throttle, as you
would during warm-up, to about 3000 rpm until the thermostat opens.
Guy Buchanan
San Diego, CA
Posted: Mon Nov 24, 2008 4:02 pm Post subject: 582 Coolant routing |
Guy C I will call Paraflite and ask about their exhaust. Thanks for the info. Have any of you 582 drivers had any experience with the Paraflite tuned exhaust or any other tuned exhaust?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
| Quote: | Date: Sun C 23 Nov 2008 21:10:06 -0800
Yes C it's the primary difference. When the thermostat closes the blue
great peril for the 582 is and was cold seizure C where after a
outside the engine is nice and cold. Suddenly you need full throttle C
the engine heats C the thermostat opens C and all that nice cold water
of really cold water in the radiator C though.) The answer for the
throttle off with the thermostat closed C (water temp < 134F C) and
throttle. Either descend throttle-on C or when you get to the bottom C
gingerly open the throttle C as you would during warm-up C to about
Guy Buchanan
San Diego C CA
K-IV 1200 / 582-C / Warp / 100 Archive Search & Download C 7-Day Browse C Chat C FAQ C
Posted: Mon Nov 24, 2008 4:23 pm Post subject: 582 Coolant routing |
Marco C I am rebuilding a Fitt shutter assembly presently to fit my twice as tall radiator as his regular kit. Probably be a good idea to think of the shutters as similar to a carb heat function on the air cooleds. When you cut power for decent close shutters same as putting on carb heat.
Pat Reilly
Mod3 582 Rebuild
Rockford CIL
Date: Mon C 24 Nov 2008 09:17:00 -0800
Also C you can (and should) install Lowell's dandy rad shutter which C when closed C will help keep water temps up during low-throttle descents.
Marco Menezes N99KX
Date: Monday C November 24 C 2008 C 12:10 AM
Yes C it's the primary difference. When the thermostat closes the blue head
seizure C where after a low-throttle descent the thermostat is closed and the
water in outside the engine is nice and cold. Suddenly you need full throttle C
the engine heats C the thermostat opens C and all that nice cold water dumps into
lot of really cold water in the radiator C though.) The answer for the
with the thermostat closed C (water temp < 134F C) and then put yourself into a
throttle-on C or when you get to the bottom C gingerly open the throttle C as you
would during warm-up C to about 3000 rpm until the thermostat opens.
| Quote: | Also C what is the brand name of the expansion chamber for the 582?
Guy Buchanan
San Diego C CA
K-IV 1200 / 582-C / Warp / 100% done C thanks mostly to Bob Ducar.
Posted: Mon Nov 24, 2008 4:38 pm Post subject: 582 Coolant routing |
Dave C Thanks for the advice offer. Wow C you have alot of Kitfox seat time. Which model C options and engine have you got. Wish you lived a little closer. Morris would be a good meeting point. I still have to get my liscense. I flew an ultralite for 3 years 20 years ago and was taking lessons in an Aeronca Champ a year ago until the club lost it's insurance so I haven't got any flying time in this year. What about the e-mail address...aerobatics? do you have experience with aerobatic manuvers?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: RE: 582 Coolant routing
Date: Sun C 23 Nov 2008 22:28:51 -0500
&g============
