carlossa52(at)gmail.com Guest
Posted: Tue Nov 25, 2008 7:10 pm Post subject: machine screws |
Hello, all
I am looking for some information: I am using machine screws MS51959 6-32 thread ( http://www.aircraftspruce.com/catalog/hapages/ms51959.php ) to fasten an access panel to its frame.
The frame has several anchor nuts K-1100-06 ( near the bottom of http://www.aircraftspruce.com/catalog/hapages/anchornuts.php ).
I find that the Phillips head in general doesn't last long - I much prefer the ones with a square (Robertson drive) or hex hole.
Do such screws exist? (i.e., 82 degrees head, 6-32 thread with a square or hex head)
Thanks in advance
Carlos
CH601-HD, plans
Milestone: found a place for the right wing in the garage and hung it.
Left wing should join it before the holidays (yeah, right....)
wjones(at)brazoriainet.co Guest
Posted: Tue Nov 25, 2008 7:23 pm Post subject: machine screws |
Hi Carlos ,I bought some 6-32 square hole for counter sinking ,I do not know the degree of the head .You can call Brazos fasteners at 979-265-8631 they have a big stock .
Wade Jones South Texas
601XL Franklin 0-235
psm(at)att.net Guest
Posted: Tue Nov 25, 2008 10:34 pm Post subject: machine screws |
Hi Carlos,
I've been using some mil. spec. Phillips head screws for access panels to the forward cabin area. I have removed them several times and the screw heads don't show any damage at all.
Perhaps the steel in those mil. spec. screws are a lot harder than the hardware store ones that seem to get reamed out with just a little use.
I'm not sure if the screws I'm using are the same ones in your A/S link, but I think they are the same as the ones in the original XL drawings for inspection ports.
Paul
XL getting close
At 07:09 PM 11/25/2008, you wrote:
[quote]I am looking for some information: I am using machine screws MS51959 6-32 thread ( http://www.aircraftspruce.com/catalog/hapages/ms51959.php ) to fasten an access panel to its frame.
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Tue Nov 25, 2008 10:40 pm Post subject: machine screws |
Carlos
You might try Torx head screws. McMaster-Carr sells 6-32 pan head (I don't know what an 82° head is) for 7-15 cents, depending on material (SS or Zinc-plated steel). I have found Torx head to be more durable than Phillips head screws.
See p/n 96710A261
Terry
At 10:09 PM 11/25/2008 -0500, Carlos wrote:
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings
http://www.mykitlog.com/N47TP/ [quote][b]
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Gig Giacona
Posted: Wed Nov 26, 2008 7:25 am Post subject: Re: machine screws |
McMaster-Carr as Terry mentions has every screw on the planet. If they don't have it you don't need it.
I'm using some Torx head screws in several places because they don't slip as much and they look a lot like an installed rivet.
That said. I picked up a trick when fitting the canopy from, of all places, the Zenith build manual. A dab of valve grinding compound pretty much stops slipping screw drivers of all types.
601XL Under Construction
Posted: Wed Nov 26, 2008 9:48 am Post subject: machine screws |
Thank you all for the tips.
A correction: the head angle is 100 degrees, as can be seen in the anchor plate drawing at http://www.aircraftspruce.com/catalog/graphics/04-01724.gif
- not 82 degrees as I stated on my first note.
Carlos
CH601-HD, plans
slowly but surely, with emphasis on "slowly".
Posted: Wed Nov 26, 2008 4:11 pm Post subject: machine screws |
I did some research and found a couple of sources for flat head, 100 degrees (not 82 as I had incorrectly stated), Torx (or 6-lobed) screws (I couldn't find Robertson drive screws):
http://www.mutualscrew.com/subcategories.php?pid=1124
They sell in bulk (I think the minimum order is a full 18 wheeler) or packages (of 100). Of course, the 100 degrees is only available in bulk.
If I already had problems storing one wing, imagine a truckload of screws. No deal.
http://www.microfasteners.com/catalog/standard.cfm?Category=SSC&SubCategory=FCMXS
Microfasteners does not have a picture for this particular item, but the description is good enough. At $9.70 for 100 (6-32 x 0.5"), I'll probably give it a shot.
I did not try Brazos as their web site is not geared for on-line sales, so I skipped it.
I also found an interesting discussion on Matronics, regarding the strength of these screws. A little long, but educational. If you do a "find in page" on "machine screw" you will be taken to one of the last postings, which sums the whole thing up.
[/url][url=http://www.matronics.com/archive/archive-get.cgi?RV-Archive.digest.vol-pg]http://www.matronics.com/archive/archive-get.cgi?RV-Archive.digest.vol-pg
Thanks to all that replied, and happy building
Carlos
2008/11/25 Carlos Sa <carlossa52(at)gmail.com (carlossa52(at)gmail.com)>
[quote] Hello, all
