aslsa.rng(at)gmail.com Guest
Posted: Tue Nov 25, 2008 8:16 am Post subject: RV-12 as a True E-LSA |
21.191 Experimental certificates.
Experimental certificates are issued for the following purposes:
(i) Operating light-sport aircraft. Operating a light-sport aircraft that—
(2) Has been assembled—
(i) From an aircraft kit for which the applicant can provide the information required by §21.193(e); and
(ii) In accordance with manufacturer's assembly instructions that meet an applicable consensus standard;
21.193 Experimental certificates: general.
An applicant for an experimental certificate must submit the following information:
(e) In the case of a light-sport aircraft assembled from a kit to be certificated in accordance with §21.191(i)(2), an applicant must provide the following:
(1) Evidence that an aircraft of the same make and model was manufactured and assembled by the aircraft kit manufacturer and issued a special airworthiness certificate in the light-sport category.
(2) The aircraft's operating instructions.
(3) The aircraft's maintenance and inspection procedures.
(4) The manufacturer's statement of compliance for the aircraft kit used in the aircraft assembly that meets §21.190(c), except that instead of meeting §21.190(c)(7), the statement must identify assembly instructions for the aircraft that meet an applicable consensus standard.
(5) The aircraft's flight training supplement.
(6) In addition to paragraphs (e)(1) through (e)(5) of this section, for an aircraft kit manufactured outside of the United States, evidence that the aircraft kit was manufactured in a country with which the United States has a Bilateral Airworthiness Agreement concerning airplanes or a Bilateral Aviation Safety Agreement with associated Implementation Procedures for Airworthiness concerning airplanes, or an equivalent airworthiness agreement.
Notice that there is no provision for the amount of work done by the builder. As far as the FAA is considered, the manufacturer can leave off a single knob that the "builder" then installs.
That being said, the burden of proving that the aircraft qualifies for an experimental certificate as an amateur built under 21.191(g) would be on the builder.
Rick
On Tue, Nov 25, 2008 at 6:50 AM, <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:
[quote] 11/25/2008
Hello Rick, You wrote: "...present the airplane to the FAA exactly as Van's designed it, get your
E-LSA airworthiness certificate....."
I am interested in knowing on what basis you feel that a kit built RV-12 can be built, registered, and certified as a true E-LSA instead of as an amateur built experimental that meets LSA criteria.
Please see the exchange of emails copied below. Thank you.
'OC' Says: "The best investment we can make is the effort to gather and understand knowledge."
PS: I am not yet receiving the RV-12 list digest for some reason even though I have recently subscribed. Would you please include both me and the RV-12 list as addressees when you respond? Thanks.
| - The Matronics RV12-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV12-List |
robertrv607(at)yahoo.com Guest
Posted: Tue Nov 25, 2008 4:56 pm Post subject: RV-12 as a True E-LSA |
HI: Have a question, one is L_SA, which I pressume is a Light, s.a..
is there any other, kind? (Single Engine etc.. no?
is only the Light Sport Aircraft, which the Rv12 is...
thanks
robert
--- On Tue, 11/25/08, Richard Girard <aslsa.rng(at)gmail.com> wrote:
[quote] From: Richard Girard <aslsa.rng(at)gmail.com>
Subject: Re: RV-12 as a True E-LSA
To: bakerocb(at)COX.NET, rv12-list(at)matronics.com
Date: Tuesday, November 25, 2008, 11:16 AM
purposes:
(i) *Operating light-sport aircraft. *Operating a
the following
information:
kit to be
following:
was manufactured
special
procedures.
instead of meeting
section, for an
evidence that the
United States has
a Bilateral
Procedures for
airworthiness
agreement.
done by the
can leave off a
qualifies for an
builder.
Rick
On Tue, Nov 25, 2008 at 6:50 AM, <bakerocb(at)cox.net>
wrote:
> 11/25/2008
a kit built RV-12
you.
some reason even
Posted: Tue Nov 25, 2008 8:07 pm Post subject: RV-12 as a True E-LSA |
Bert, Light Sport Aircraft are defined in FAR 1.1
Rick
On Tue, Nov 25, 2008 at 6:56 PM, bert murillo <robertrv607(at)yahoo.com (robertrv607(at)yahoo.com)> wrote:
[quote]--> RV12-List message posted by: bert murillo <robertrv607(at)yahoo.com (robertrv607(at)yahoo.com)>
thanks
robert
--- On Tue, 11/25/08, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
> From: Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)>
> To: bakerocb(at)COX.NET (bakerocb(at)COX.NET), rv12-list(at)matronics.com (rv12-list(at)matronics.com)
> purposes:
> the following
> information:
> kit to be
> following:
> was manufactured
> special
> procedures.
> instead of meeting
> section, for an
> evidence that the
> United States has
> a Bilateral
> Procedures for
> airworthiness
> agreement.
> done by the
> can leave off a
> qualifies for an
> builder.
> Rick
> wrote:
> > 11/25/2008
> a kit built RV-12
> you.
> some reason even
bakerocb
Posted: Tue Nov 25, 2008 8:47 pm Post subject: RV-12 as a True E-LSA |
11/25/2008
Hello Rick, Thank you for your quick, detailed, and authoritative response.
However as Dick Koehler pointed out in his email it still is not possible,
at this time, to build a true E-LSA from a kit -- even an RV-12 kit.
Here is why in my opinion.
1) From 14 CFR 21.191 I quote from your email below:
"(ii) In accordance with manufacturer's assembly instructions that meet an
applicable consensus standard;"
2) From 14 CFR 21.193 I quote from your email below:
"(e) In the case of a light-sport aircraft assembled from a kit to be
following:
aircraft that meet an applicable consensus standard."
Both of these 14 CFR extracts require that the kit provider must provide
".......assembly instructions for the aircraft that meet an applicable
consensus standard." for the kit builder to follow during constuction of the
kit.
To my knowledge no such "applicable consensus standard" exists. If no such
standard exists then Vans cannot possibly be providing assembly instructions
for the RV-12 kit that meets that standard.
It may be possible that some day such a standard will exist. It may even be
possible that the Vans assembly instructions for the RV-12 kit may
retroactively (or is it future-istically?) meet that yet to exist standard.
It may be possible that Van's instructions for assembly of the RV-12 kit may
be the forerunner / standard creator for that forthcoming standard.
But as it stands right now today, I still maintain that it is not possible
to build a true E-LSA from a kit, even a Vans RV-12 kit.
Your response is?
Then you wrote: "That being said, the burden of proving that the aircraft
qualifies for an
builder."
I don't understand your point here. The whole object of this discussion is
to NOT build, register, and certify an amateur built experimental airplane
that would be subject to the burden of having either the repairman for that
specific airplane or an A&P required to perform the annual condition
inspection. Instead the object is to build a true E-LSA that could be sold
to subsequent owners who could annually inspect the airplane after going
through a 16 hour training course. Perhaps you did not understand?
bakerocb
Posted: Wed Nov 26, 2008 7:24 am Post subject: RV-12 as a True E-LSA |
11/26/2008
Hello Rick, Thanks for your quick response. You wrote:
1) "So the answer to your question is, no, at this time there is no way to
build an E-LSA without having a registration issued before 1-31-2008, and
that only last until the expiration of the extension on 1-31-2010."
We both agree on the above.
2) "Per the above, the FAA accepted ASTM standard is F2536-06."
http://www.astm.org/Standards/F2563.htm
I stand corrected -- the instruction standard does exist. And I feel that if
Vans instructions for assembling the RV-12 kit meet that standard then,
eventually when the other LSA boxes are appropriately filled by Vans, then a
kit built RV-12 should be able to be built, registered, and certified as a
true E-LSA. I thank you for educating me.
AV8ORJWC
Posted: Wed Nov 26, 2008 9:41 am Post subject: RV-12 as a True E-LSA |
To add to this important discussion, it is my understanding that the
RV-12 kit "in its entirety" has not yet been FAA blessed. Further,
under the ARC 51% perspective by the FAA participants, there is a small
but real risk that it might not be without some healthy attitude change
by the FAA on what constitutes - 51%. Your comments (forwarded to the
FAA) prior to the final/final deadline of December 15th could have a
compelling impact. Can anyone advise?
John Cox
Apik
Posted: Fri Feb 06, 2009 3:58 am Post subject: Re: RV-12 as a True E-LSA |
Yeah, the RV-12 meets the certification standards of the Light Sport Aircraft category. Extensive and thorough testing has demonstrated compliance with LSA performance and structural requirements. It is what we say it is and does what we say it does, and we have the test data to prove it! Extensive testing means the RV-12 is not the first LSA kit on the market, but it might be the best understood.
_________________ used rv sale |
Apik
Posted: Sun Feb 15, 2009 10:27 pm Post subject: Re: RV-12 as a True E-LSA |
HI, I have got the following response to my post by email, I have replied, if you have any other suggestions ,or just another point of view you can post in this thread :Thanks for your input. But there is still no registered and certified
copy
of an RV-12 as an S-LSA is there?
I do not understand what your relationship is to the RV-12 kit
production
and testing or the point that you are making below. Can you please
educate
me? I am not a member of the RV-12 forum so please respond direct if
possible. You may include a copy of anything that I transmit to the
forum if
you wish.
Below your email is an exchange of emails that pertain. It appears that
as
of today there are still two stumbling blocks to actually registering
and
certifying a kit built RV-12 as a true E-LSA: 1) The builder convincing
the
FAA that the kit meets the major portion rule; and 2) The fact that no
registered and certified S-LSA version of the RV-12 exists.
Do you agree or do you have anything else to offer on this subject?
deej(at)deej.net Guest
Posted: Mon Feb 16, 2009 9:05 am Post subject: RV-12 as a True E-LSA |
Apik wrote:
Quote: | of today there are still two stumbling blocks to actually registering
and
the
Re: #1 above, the 51% rule only applies if you want to register it
as an amateur built experimental. 51% does not apply to the E-LSA category.
Re: #2, you will not be able to register it as an E-LSA until there
is a registered and certified S-LSA version available, which I believe
has to be done by Van's. Until they do so, you'd have to register the
RV-12 as an amateur built experimental, in which case you'd then need to
prove that the kit meets the 51% rule...
IMHO you should give Van's a call and ask how to proceed.
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ KR-2 Builder N770DJ
http://deej.net/sportsman/ http://deej.net/kr-2/
"Many things that are unexplainable happen during the construction of an
airplane." --Dave Prizio, 30 Aug 2005
Posted: Mon Feb 16, 2009 9:12 am Post subject: RV-12 as a True E-LSA |
This is really pretty simple. If Vans didn't give you a letter of compliance, maintenance and inspection manual, flight training supplement, evidence that Vans was issued an S-LSA certificate for the RV-12 and operation instructions, the FAA will not register your RV-12 as an E-LSA (FAR 21.191i(2) and 21.193e(1-5)).
Rick
On Mon, Feb 16, 2009 at 12:27 AM, Apik <lily_f(at)auswww.com (lily_f(at)auswww.com)> wrote:
[quote] --> RV12-List message posted by: "Apik" <lily_f(at)auswww.com (lily_f(at)auswww.com)>
copy
production
educate
forum if
you wish.
as
and
the
http://forums.matronics.com/viewtopic.php?p=230457#230457
" target="_blank">http://www.matronics.com/Navigator?RV12-List
MS -
e -
Posted: Mon Feb 16, 2009 8:38 pm Post subject: RV-12 as a True E-LSA |
I would ask Van's, period. He would know the answer no?
--- On Mon, 2/16/09, Richard Girard <aslsa.rng(at)gmail.com> wrote:
Quote: |
Subject: Re: Re: RV-12 as a True E-LSA
To: rv12-list(at)matronics.com
Date: Monday, February 16, 2009, 12:09 PM
Rick
Quote: | --> RV12-List message posted by: "Apik" <lily_f(at)auswww.com (lily_f(at)auswww.com)>
copy
production
educate
forum if
you wish.
as
and
the
[url=http://forums.matronics.com/viewtopic.php?p 30457#230457]http://forums.matronics.com/viewtopic.php?p 30457#230457[/url]
MS -
e -
