Smcm75(at)aol.com Guest
Posted: Wed Nov 26, 2008 8:34 am Post subject: RV series belly/wing tank/cargo pod |
Gentleman and Ladies:
I have developed the mold and plug for a fiberglass removable belly/wing tank or cargo pod. It is shaped like a WWII P-38 wing tank with a laminar flow cross section and is 52" long by 12" in diameter and holds 14 gals and is fabricated of either fiberglass or carbon fiber. I am soliciting interest to see where I go from here with production plans. This tank/pod with fit on practicall any experimental aircraft high or low wing.
Please let me know your interest level.
Scott Morrow
Life should be easicid=aolcom40vanity&ncid=emlcntaolcom00000002">Try the NEW AOL.com.
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
ghfrost(at)earthlink.net Guest
Posted: Wed Nov 26, 2008 8:47 am Post subject: RV series belly/wing tank/cargo pod |
What kind of hard points and plumbing will be required and what do you think the price will be? It sounds like a good idea to extend range and reserve safety in IFR conditions. It seems it would be useful for cargo as well but not likely the same unit. What kind of cost for both? Could the hard points work for a ski container as well? Gross weight is of course a factor when using these.
On Nov 26, 2008, at 11:33 AM, Smcm75(at)aol.com (Smcm75(at)aol.com) wrote:
[quote] Gentleman and Ladies:
Scott Morrow
Quote: |
href="http://www.matronics.com/Navigator?RV6-List">http://www.matronics.com/Navigator?RV6-List
Posted: Wed Nov 26, 2008 9:05 am Post subject: RV series belly/wing tank/cargo pod |
In a message dated 11/26/2008 11:48:09 AM Eastern Standard Time, ghfrost(at)earthlink.net writes:
Quote: | What kind of hard points and plumbing will be required and what do you think the price will be? It sounds like a good idea to extend range and reserve safety in IFR conditions. It seems it would be useful for cargo as well but not likely the same unit. What kind of cost for both? Could the hard points work for a ski container as well? Gross weight is of course a factor when using these.
I have a RV-6A and would be attaching the hard points to the main spar using the tie down ring hole and a doubler and attach point in the rear spar. If it is to be hung under the fusalage it can be mounted to the front and rear spar. I will not be supplying the attachments or plumbing just the tanks/pods
Life should be easier. So shcom40vanity&ncid=emlcntaolcom00000002">Try the NEW AOL.com.
Posted: Wed Nov 26, 2008 9:09 am Post subject: RV series belly/wing tank/cargo pod |
The pricing will be directly related to volume of units/interest
Life should be easier. =aolcom40vanity&ncid=emlcntaolcom00000002">Try the NEW AOL.com.
Posted: Wed Nov 26, 2008 9:38 am Post subject: RV series belly/wing tank/cargo pod |
Let me know when things move along.
On Nov 26, 2008, at 12:09 PM, Smcm75(at)aol.com (Smcm75(at)aol.com) wrote:
[quote] The pricing will be directly related to volume of units/interest
Posted: Wed Nov 26, 2008 9:54 am Post subject: RV series belly/wing tank/cargo pod |
In a message dated 11/26/2008 12:39:25 PM Eastern Standard Time, ghfrost(at)earthlink.net writes:
Quote: | Let me know when things move along.
Wilco
Life should be easier. So slcom40vanity&ncid=emlcntaolcom00000002">Try the NEW AOL.com.
