		trumanst(at)netins.net Guest
				 Posted: Mon Mar 20, 2006 7:46 am    Post subject: UV Light |
 I was making my third flight in my Tri Q 200 this past Sat. I noticed that
 every time I presses the mic remote key switch, the OV light would come on.
 Nothing is connected to ships power at this time. Using nine volt on
 intercom, and a new IC-A6 with it's own battery. Ever heard of anything like
 this before? I did not have the ships antenna hooked up either. Rubber ducky
 only.
 I did not notice it on the first two flights, but may have not been aware of
 it. Had other tasks on my mind.
 Thanks for all you do.
 Kevin Boddicker
 Luana, Iowa
 Tri Q200 N7868B
 Flying!!!! 2.6 HRS
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		nuckollsr(at)cox.net Guest
				 Posted: Mon Mar 20, 2006 9:21 am    Post subject: UV Light |
				At 09:45 AM 3/20/2006 -0600, you wrote:
 only.
    Who's OV light?
  	  | Quote: | 	 		  I did not notice it on the first two flights, but may have not been aware of
    At first blush, it sounds like the OV sensor is sensitive
    to RF.  Hand-helds with rubber duck antennas can be the
    worst antagonists with respect to cockpit mounted accessories.
    In fact, I used my hand-held as a quick-looksee for RF susceptibility
    for hardware on the bench.
       < What is so wonderful about scientific truth...is that >
       < the authority which determines whether there can be   >
       < debate or not does not reside in some fraternity of   >
       < scientists; nor is it divine. The authority rests     >
       < with experiment.                                      >
       <                            --Lawrence M. Krauss       >
		sportav8r(at)aol.com Guest
				 Posted: Mon Mar 20, 2006 9:33 am    Post subject: UV Light |
				Dang, I was expecting to read something interesting about applied fluorescence technology or day-glo instruments in the cockpit...  apparently the UV in the header is actually OV??
				 Posted: Mon Mar 20, 2006 4:08 pm    Post subject: UV Light |
				on 3/20/06 11:16 AM, Robert L. Nuckolls, III at nuckollsr(at)cox.net wrote:
  <nuckollsr(at)cox.net>
 > Bob,
 > only.
  Who's OV light?
 B&C Specilaties.
 The light comes on steady when the mic is keyed.
 Today, while doing a cowl off inspection, I noticed that the small stranded
 wire from the large post to the small post on the S701-1 contactor was
 burned in two. I did have a OV trip a few months back while taxi testing,
 but figured it was a nuisance trip. Without the small wire the alternator
 has been functioning. The battery seems to have full charge. Did not use
 tester it was at home. Just looked at the volt meter. Turning the master on
 did not bring up the LV sensor light.
  to RF. That is what we thought also but I was curious.     Hand-helds with
  	  | Quote: | 	 		   worst antagonists with respect to cockpit mounted accessories.
				 Posted: Tue Mar 21, 2006 4:23 pm    Post subject: UV Light |
 I will try this again. The first time I tried to snip. Didn't work.
 The OV/UV sensor came from B&C.
 The light comes on steady when the mic is keyed. We aslo thought if might be
 RF.
 wire from the large post to the small post on the S701-1 over voltage
 dissconnect contactor was burned in two. I did have a OV trip a few months
 back while taxi testing, but figured it was a nuisance trip. Without the
 small wire the alternator has been functioning. The battery seems to have
 full charge. Did not use a tester it was at home. Just looked at the
 voltmeter. Turning the master on did not bring up the LV sensor light.
 Any ideas?
 Kevin Boddicker
 Luana, Iowa
 Tri Q200 N7868B 2.6 HRS
 Flying!!!!
 > Bob,
 > only.
  Who's OV light?
		lhelming(at)sigecom.net Guest
				 Posted: Wed Mar 22, 2006 4:37 am    Post subject: UV Light |
				Check your wiring.  When I turn on the master without the engine
 running/alternator producing energy, the LV light is blinking.  I can also
 get the LV light to blink at low rpms with heavy load, i.e., all the lights
 on ( I have an 30 amp alt.)
 If your wiring checks out, I'd call B&C to see what they think about
 possibilities that you have a bad regulator.
 Indiana Larry, RV7 "SunSeeker" 90+ hours flying
 "Please use the information and opinions I express with responsibility, and
 at your own risk."
				 Posted: Wed Mar 22, 2006 5:20 am    Post subject: UV Light |
				Thanks for the reply.
 The documentaion that came with my unit states " A flashing light indicates
 a bus voltage greater than 15.5 volts DC. Steady light indicates bus voltage
 below 12.5 volts DC."
 Mine too will ack as yours at low RPM. Must be just at the LV set or below.
 Increasing 50 RPM or so will make it disappear.
 Kevin Boddicker
 Luana, Iowa
 Tri Q200 N7868B
 Flying!!!!
 on 3/22/06 6:31 AM, LarryRobertHelming at lhelming(at)sigecom.net wrote:
  <lhelming(at)sigecom.net>
  at your own risk."
