Posted: Mon Dec 01, 2008 10:29 am Post subject: Monowheel Landing Gear Question? |
EuropaOwners has older mods, including Mod 26 under the Download section:
http://www.europaowners.org/dlman.php?func=select_folder&folder_id
I am pretty sure in the older newsletters (not sure if club, probably factory), probably downloadable from Europa Club there was an article about installing the dampeners, it helped a lot with preventing a bounce from turning into a prop strike.
Ron Parigoris
FWIW I was told you can replace the bungi from behind and below after you remove shock absorber and damper assemble. Adjustment is supposedly a bit hit and miss, but very dooable. I was also told to leave a tail on top on end of bungee, so if the bungee gets weak you can retension it.
Visit - www.EuropaOwners.org
