		ron.mcgann(at)baesystems. Guest
				 Posted: Wed Dec 03, 2008 2:30 pm    Post subject: Access under front seats |
				G'day all,
 Painting is finished, so I am in the process of final tidy up in the cabin.  I really just need to finish wiring the sticks and install the seats.  I have a terminal block located under the front seats to connect the stick wiring to.  Can someone please advise what access is available to the under seat area once the seats are installed?  Eg do the seats slide all the way back to provide access to the under seat area, or do you need to remove the seats completely to gain access to the area under the seat pans?
 Thanks in advance
 Ron
 -187 maybe the BEST Xmas present ever???   [quote]"Warning:
 The information contained in this email and any attached files is
 confidential to BAE Systems Australia. If you are not the intended
 recipient, any use, disclosure or copying of this email or any
 attachments is expressly prohibited.  If you have received this email
 in error, please notify us immediately. VIRUS: Every care has been
 taken to ensure this email and its attachments are virus free,
 however, any loss or damage incurred in using this email is not the
 sender's responsibility.  It is your responsibility to ensure virus
 checks are completed before installing any data sent in this email to
 your computer."
		drfred(at)suddenlinkmail. Guest
				 Posted: Wed Dec 03, 2008 2:56 pm    Post subject: Access under front seats |
				Ron;
 I've had to take the flap cover off before I could try to remove the
 seats.  Haven't tried to get to the back screws of the cover plate yet
 with the seat in place.  You might be able to slide the seats back and
 forth to get to the individual screws and then get access.  Either way,
 it only takes a couple minutes to pull the flap cover screws to get the
 seat out of your way.  You can go ahead and install the seat rails
 without any problem.
 Hope this helps.
 Dr Fred.
 McGANN, Ron wrote:
  G'day all,
  Thanks in advance
  Ron
  "Warning:
  your computer."
		bcondrey
				 Posted: Wed Dec 03, 2008 3:04 pm    Post subject: Access under front seats |
				Another technique is to cut down the front part of the nylon (or
 whatever material it is) slides by about 3/4".  This then allows the
 seats to be tilted up and will clear the flap tube covers.
 Bob
 N442PM
		avu1(at)md.metrocast.net Guest
				 Posted: Wed Dec 03, 2008 6:04 pm    Post subject: Access under front seats |
				You can't slide the seats back far enough without taking the side handles
 off.  Once those handles come off you might as well take the seats off.
 Anh
 N591VU-flying
  	  | Quote: | 	 		   G'day all,
  the seat pans?
  Thanks in advance
  Ron
  "Warning:
  your computer."
