rene(at)felker.com Guest
Posted: Sat Dec 13, 2008 1:12 pm Post subject: Battery Size |
Some background. As I was building.........I was worried about the CG being
to far forward and thus I was not concerned about putting in a bigger
battery (Odyssey 925 at 24 LBS) and my O2 system behind the rear bulkhead.
In the end, that left my empty weight CG at 109.22, which is pretty far aft.
My first annual is due in Jan and thus I am considering options for moving
the CG forward. I have a little more interior work to do, but I do not
think it will have any affect.
One of the options I am considering in moving the battery from the normal
location behind the bulkhead and mounting it on the firewall. My rough
calculation is the empty weight CG will move to 107.58 a little forward of
the forward edge of the envelope. (this does not include some of the wiring
changes which will also move the CG a little forward also.....).
So here is the real question, anyone flying out there with just one PC680
battery? If so have you found it adequate? I am a little like Tim
Taylor....why use a 680 anmp battery when you can get a 925 amp battery, but
do I need all of that power.
I have a standby alternator (8 amp) and a backup battery for my Alamo
instruments (AS, Altimeter and ADI). So I am not to worried about the loss
of the primary altinator
Anybody have any other ideas?
Rene'
801-721-6080
carl.froehlich(at)cox.net Guest
Posted: Sat Dec 13, 2008 1:36 pm Post subject: Battery Size |
If it works for your CG, another option is to use two identical but smaller
batteries, one aft one forward. These would replace your one big battery
and your small backup battery. Run them in parallel for normal ops, split
if you have an problem on one side. PC-625s are more than adequate for
starting. My normal maintenance is to replace one battery every other year.
The old ones end up in law tractors and such - still going strong years
later.
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
kdbelue(at)charter.net Guest
Posted: Sat Dec 13, 2008 3:03 pm Post subject: Battery Size |
Rene,
I have 2 PC680 batteries in my RV10. One is for the main bus and the other
is backup and for the EFIS to boot on during start. I can switch in both
batteries for start if needed. My experience has been that 1 PC680 starts my
RV-6A just fine, but it's not really enough for the IO540. It will start it
but sometimes I have to use both batteries when it is cold and it still just
barely gets it started. I'm using a skytec PM starter, so I different
starter might help.
Kevin Belue
RV-6A Flying
RV-10 Flying
Kellym
Posted: Sat Dec 13, 2008 4:55 pm Post subject: Battery Size |
Skytec PM starters have about the highest current draw out there. The NL
series takes maybe 10-20% less, and the Kelly E-drive takes about 1/2
the current of the Skytec PM.
Kevin Belue wrote:
Rene,
other is backup and for the EFIS to boot on during start. I can switch
in both batteries for start if needed. My experience has been that 1
PC680 starts my RV-6A just fine, but it's not really enough for the
IO540. It will start it but sometimes I have to use both batteries
when it is cold and it still just barely gets it started. I'm using a
skytec PM starter, so I different starter might help.
Kevin Belue
RV-6A Flying
RV-10 Flying
KCHD |
