PFolbrecht(at)starkinvest Guest
Posted: Tue Mar 21, 2006 7:00 am Post subject: Rudder Trailing Edge Countersinking |
Well, I do hate to have to ask another question on the heels of my last
one (un-fluting), but here goes.
Countersinking the rudder (9A) TE last night (R-916), it became apparent
after a couple holes that the holes are enlarged by the CS. There is no
way to CS to the correct depth without enlarging the holes. I've been
trained that countersinking should *never* cause the hole to enlarge -
if it does, the material is too thin - but this seems to be a special
case (piece sandwiched between two skins for double-flush riveting).
The instructions don't speak to the issue. Am I doing this correctly?
Paul
9A QB #1176
HS, VS done
peter(at)mather.com Guest
Posted: Tue Mar 21, 2006 7:41 am Post subject: Rudder Trailing Edge Countersinking |
Paul
It sounds like you may have the wedge slightly too far forward into the rudder so that you have drilled very slightly too close to the thin edge. I didn't see any significant enlargement when I did it although it is very marginal. Given the double headed rivets it probably doesn't matter if the hole is slightly enlarged although it is obviously important that the dimples in both skins sit cleanly into the wedge. Do use the tank sealant to glue the edge before rivetting and let it set properly with every hole clecoed onto a straight edge.
Best regards
Peter
Posted: Tue Mar 21, 2006 8:04 am Post subject: Rudder Trailing Edge Countersinking |
Too far forward? No, the edge was prepunched #40 and then was
match-drilled. The holes are just where they're supposed to be.
Well, then, I'm entirely confused about this because, as I said, there
is NO WAY to countersink to the proper depth without enlarging the holes
some - and it's not a trivial amount, either. They are quite noticeably
larger - although the countersinks are done just right - the skin
dimples do fit perfectly.
Thanks for the response.
gerf(at)gerf.com Guest
Posted: Tue Mar 21, 2006 8:28 am Post subject: Rudder Trailing Edge Countersinking |
The wedge was pre-punched ? I'm assuming only the skins were
pre punched and you match drilled into the wedge. I think what
Paul is saying is that you need to re-position the wedge
further AFT relative to the skins, that way you will be
countersinking into the thicker section of the wedge. Which
may necessitate you replacing the wedge.
I had a a similar issue although perhaps not as pronounced. I
bonded my trailing edges with T-88 epoxy which made them a lot
stronger. Maybe post a picture ?
g
<PFolbrecht(at)starkinvestments.com>
dan(at)rvproject.com Guest
Posted: Tue Mar 21, 2006 8:43 am Post subject: Rudder Trailing Edge Countersinking |
| Quote: | Too far forward? No, the edge was prepunched #40 and then was
Was the AEX wedge drilled from the factory, or did you match drill it using
the holes in the skin? If the wedge itself came drilled from the factory,
then you're right...not much choice in the matter. If the wedge had no
holes in it when you started, then it's possible you located it too far
forward when you drilled it...which shifts the holes toward the thin end of
the wedge...but it's NOT a huge deal.
Take a look at the flap brace on the RV-7/8 and you'll see that it gets
countersunk between the dimpled wing skin and the untouched flap hinge.
Those c-sink'd holes end up huge. It's OK because that layer is sandwiched
between other layers.
Take a look at the left elevator rear spar, trim tab spar, etc. Same deal.
Stuff gets c-sunk and enlarged, and it's OK because it's sandwiched between
at least two other layers that don't have enlarged holes.
I may be mistaken, but I believe Van's mentions this scenario in the
construction manual. In any case, your rivet's manufactured & shop heads
are both bearing against un-enlarged material. My 2 cents is, rivet that
sucker and press on. If you have any doubts, call Van's Builder's
Assistance (503-678-6545, no wonder how I can just spout that from
*memory*!) and they'll probably tell you the same thing.
At least that's my 2 cents...hope it puts you at ease.
)_( Dan
RV-7 N714D
http://www.rvproject.com
Posted: Tue Mar 21, 2006 8:56 am Post subject: Rudder Trailing Edge Countersinking |
Yes, the wedge was indeed pre-punched.
I've only done 3 holes so, even if I've screwed-up this far (and now I
don't think that I have), it's not likely a loss. I have been told
enlargement of the holes is indeed inevitable here.
rv7(at)b4.ca Guest
Posted: Tue Mar 21, 2006 9:07 am Post subject: Rudder Trailing Edge Countersinking |
On 8:55:33 2006-03-21 "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
wrote:
| Quote: | I've only done 3 holes so, even if I've screwed-up this far (and now I
Another option is to flush rivet one side and leave the other side
square-headed. It's less pretty, but it's going to be a lot stronger. If
you're countersinking both sides of that wedge and finding that the
countersinks are meeting each other, you'll have a knife-edge around the
hole, which isn't condusive to long rivet life.
On the Elevator, at least, you could put the square heads on the underside.
-Rob
Posted: Tue Mar 21, 2006 9:15 am Post subject: Rudder Trailing Edge Countersinking |
Thanks, Dan. These were mostly my thoughts as well (both rivet heads
are secure and the TE is just squeezed in) but I thought I should ask.
(Having finally ruined my first part recently (and a skin at that), I
think I may be "erring" hard on the side of caution lately.)
This section of the instructions doesn't speak to this issue, and, I
just reviewed section 5 as well, on countersinking, and didn't see it
addressed there either. Perhaps it is in there somewhere. Or maybe
this is something that's assumed to be obvious. :-}
Paul
Posted: Tue Mar 21, 2006 10:28 am Post subject: Rudder Trailing Edge Countersinking |
Well, what I'm running into, everybody should be running into.
I'd like to hear from other builders who have done the rudder recently
(or just remember it well). Did you notice the TE holes significantly
enlarged by the countersinking?
dwight(at)openweave.org Guest
Posted: Tue Mar 21, 2006 11:37 am Post subject: Rudder Trailing Edge Countersinking |
Paul,
Well ... I don't want to -swear- to it, but I do believe I had a bit of
hole enlargement when I c'sunk mine. I just did it a few months ago, even
though I'm close to finishing my fuselage, because I got my original small
rudder replaced by Van's ... but at the time was busy with other things and
just stuck it on the shelf until a good time to assemble it. That "good time"
finally arrived back in November.
At the time my thinking was (a) the holes are pre-punched so I can't make
any adjustments there and (b) it is going to be tightly sandwiched between
the two skins and (c) it'll be held firmly in place with proseal for added
measure. Thus ... I didn't give it much thought.
If in doubt, call Van's. (I need to give 'em a call on another issue myself
sometime today or tomorrow.)
-- Dwight
On Tue Mar 21 13:24:39 2006, Folbrecht, Paul wrote :
| Quote: | Well, what I'm running into, everybody should be running into.
lsbrv7a(at)yahoo.com Guest
Posted: Tue Mar 21, 2006 11:58 am Post subject: Rudder Trailing Edge Countersinking |
My holes were enlarged, but it looked like the skins nearly meet and fill the void. I glued mine Saturday and plan on squeezing the rivets with a hand squeezer with a set ground to a matching angle. (Someone on the list mentioned he did his that way, and it worked well.)
Sherman Butler
RV-7a Empennage
Idaho Falls
Bring photos to life! New PhotoMail makes sharing a breeze.
Posted: Tue Mar 21, 2006 12:10 pm Post subject: Rudder Trailing Edge Countersinking |
It seems I probably worried about this a bit too much.
(But, when you're new to metal working, and you read things like how
failing to debur can cause stress cracks that can bring your airplane
down hundreds of hours later, you want to make sure all the t's are
crossed and so forth... :-})
P.S. Yes I realize no single crack is going to cause a structural
failure unless it goes unchecked for a very long time...
Hopperdhh(at)aol.com Guest
Posted: Tue Mar 21, 2006 12:12 pm Post subject: Rudder Trailing Edge Countersinking |
Sherman,
Are you going to alternate the direction of the rivets? That seems like a
good method. In fact mine would look awful if I hadn't done that because I
didn't use any adhesive. That was a mistake. As it is, I have a slight "sine
wave" if you look closely at the rudder. It isn't that bad but it could be
better. If I hadn't alternated the rivets it would be curled about 4 inches!
I set the rivets with a squeezer as far as possible, then finished with the
gun -- a flush set against my back riveting plate. It seems to me like a
squeezer with dies ground to that angle would tend to bend the rivets.
Good luck,
Dan Hopper
RV-7A Flying since July '04 -- 145 wonderful hours
In a message dated 3/21/2006 2:59:40 P.M. Eastern Standard Time,
lsbrv7a(at)yahoo.com writes:
"Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com> wrote: --> RV-List
message posted by: "Folbrecht, Paul"
Sherman Butler
RV-7a Empennage
Idaho Falls
Posted: Tue Mar 21, 2006 12:19 pm Post subject: Rudder Trailing Edge Countersinking |
Grinding the dies to match the angle is a great idea. I'll do that.
Hopefully the elevators are a close match and the same dies can be used.
retasker(at)optonline.net Guest
Posted: Tue Mar 21, 2006 1:02 pm Post subject: Rudder Trailing Edge Countersinking |
This method works great. I used my pneumatic squeezer and some rivet
sets I made myself that were ground to the correct angle.
However, make sure that you use a straight die to start the rivets,
otherwise the rivet may bend as noted in another post.
Basically, start all the rivets - squash them as far as you can without
the flat rivet set hitting the skins - and then finish them with the
angled rivet set.
Don't let the angled set rotate .
Dick Tasker
Albert Gardner
Posted: Tue Mar 21, 2006 3:26 pm Post subject: Rudder Trailing Edge Countersinking |
You might the RV-9 List archives also. This issue comes up from time to
time. The RV-9 wedge comes prepunched and countersinking will enlarge the
holes. I match drilled the wedge holes into a piece on 1/8" al strip that I
bought at Ace Hardware. I put clecos in about ever 10th or 12th hole to keep
it in place and the strip provided a hole for the countersink pilot. Flip
the wedge and do the other side then clamp the wedge, pull the clecos and
csk the remaining holes. On the other side of those holes you can csk by
hand. You will have the same problem on the main spar for the tank attach
screw nutplates but you can just use a short piece attached with clecos thru
the #40 nutplate attach holes and the strip will provide a pilot hole.
Albert Gardner
RV-9A N872RV
RV-10 30%
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
truflite(at)yahoo.com Guest
Posted: Tue Mar 21, 2006 3:28 pm Post subject: Rudder Trailing Edge Countersinking |
No way to get around enlarging the hole. Work slowly
and it should work out okay. As long as the skins sit
down well in the countersink, you are good to go.
Move on.
Dave
--- "Folbrecht, Paul"
running into.
the rudder recently
holes significantly
George McNutt
Posted: Tue Mar 21, 2006 6:41 pm Post subject: Rudder Trailing Edge Countersinking |
Hi Paul
Just a thought, - are you using a 100 degree aviation countersink and
not 82 degree hardware store type??
George in Langley BC
Jim Carlton
Posted: Tue Mar 21, 2006 7:20 pm Post subject: Rudder Trailing Edge Countersinking |
On Tuesday 21 March 2006 03:19 pm, Folbrecht, Paul wrote:
I wish I had a picture of the wedge, but I chucked the microcage to the
drillpress, made a jig out of a couple of blocks of wood and fed the
predrilled wedge thru, keeping the work perpendicular to the bit. I didn't
notice much enlarging of the holes, but maybe I set the microstop too
shallow? Dunno, but I clecoed everything up and the dimpled skin set in fine.
I was so pleased with the fit I decided to try using epoxy instead of proseal
After mixing up a batch of West Systems with a slow hardener and making a
slurry with Cabosil to a thick consistency, I used a small brush and painted
it on to the skins at the trailing edge. I layed the skin onto the bench with
the wedge clecoed to the trailing edges and followed the steps spelled out in
the plans. Yes, I did this by myself where the directions call for an assist
to fold the skins over while you reach in to rivet the clips to the ribs or
stringers. I used a "sky hook" to hold the top skin overhead while I slowly
lowered it into place and proceeded with the blind rivets. Yep, it was a
handful, but kinda fun and I didn't get too much epoxy all over!
After I finished up the riveting, I clecoed the whole trailing edge, very
little oozed out needing cleanup, and weighted the rudder down to let it dry
overnight. Next morning it was rock solid, clecoes easily popped out and I
cleaned up the holes.
I back riveted the whole length against a length of 1 1/4 angle iron clamped
to the edge of the workbench. Except for my overzealous gun work, (really
dislike those little smilies!) in a spot or two, it came out really great. I
may spot fill the shop heads and lay a layer of glass over the edge and
really clean it up smooth. Anybody think I should worry about smoking rivets
working through?
Jim
Posted: Tue Mar 21, 2006 7:26 pm Post subject: Rudder Trailing Edge Countersinking |
Certainly using the correct tools.
The job (c-sinking) is done now and turned out well. I now check each hole after c-sinking; each rivet sits just a hair under flush.
Quit a bit early tonight after reading the "instructions" for mixing proseal. Sounds like a blast.
From: owner-rv-list-server(at)matronics.com on behalf of G McNutt
Sent: Tue 3/21/2006 8:44 PM
To: rv-list(at)matronics.com
Subject: Re: Rudder Trailing Edge Countersinking
Hi Paul
