Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
icubob(at)newnorth.net Guest
Posted: Thu Dec 11, 2008 8:29 pm Post subject: icom ic-a200 |
hi all,
this is to anyone that has recently wired or looked at the installation manual for this radio.
i wired this radio over a year ago and everything tested out fine. today i was reinstalling all of my wiring for the last time and i noticed a wire was broken at the molex connector. actually it looks more like i cut it. i cant remember if i did cut it or why. the connector is pin R. pin R and pin 14 connect to the power feed from the bus. the schematic calls for the power to go to these 2 pins. anyone know of a reason to feed pin14 and not pinR ?
any input appreciated.
bob noffs
Sam
Posted: Fri Dec 12, 2008 5:03 am Post subject: icom ic-a200 |
Bob,
I just finished my IC-A210 installation and I do have pins R&14 connected. Except for getting my old GPSMap196 to talk to the A21, everything seems to be working. I have been corresponding with ICOM Tech Support and there is has been no mention of removing the wire at R.
Sam
On Thu, Dec 11, 2008 at 10:27 PM, bob noffs <icubob(at)newnorth.net (icubob(at)newnorth.net)> wrote:
[quote] hi all,
bob noffs
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
Sam
Bob,
Sam
[quote] hi all,
bob noffs
klehman(at)albedo.net Guest
Posted: Fri Dec 12, 2008 5:05 am Post subject: icom ic-a200 |
Bob
A few years ago I traced all those multiple power and also the ground,
and signal ground connections on my A200 and found that they were all
connected together inside the radio. Suspect they were encouraging
redundant connections but there is no actual need for them.
On another thread, I almost always start and shut down with power on
this radio and no problems so far after a couple of hundred hours. No
radio master switch but OTOH one real overvoltage event was trapped by
my overvoltage protection.
Ken
bob noffs wrote:
| Quote: | hi all,
bob noffs
gmcjetpilot
Posted: Sat Dec 13, 2008 1:05 am Post subject: icom ic-a200 |
I recall from the factory manual and internal schematic I got a hold of,
that the power and grounds are ganged internally, but its been a while.
It do recall it's redundant, but it has been a few years.
Please no offense Ken just my 0.02 worth, the manual cautions against
start and stop with power on. It's a long running debate....blaa blaa, but
to each his own, every one has a choice and if it works fine, if you error
on side of caution, good as well.
The IC-200 does not have internal OV protection. So I do suggest folks
use a **Transorb on the CB/fuse for the radio if you don't have a more
elaborate OV protection system on the ICOM.
** Transorb or Mosorb are commercial names for Transient voltage suppressors,
basically special zener diodes, small inexpensive OV devices that will break
down at a specific voltage (range) and trip the CB or fuse. I use a couple for
the few avionics like the IC-200a that do not have internal OV protection or
robustness. Many late model avionics (see your manual) have isolated
internal power supplies with ability to handle spikes, and if the worst should
occur the damage is limited to the power filter & don't use extra OV protection
for those components.
George
PS What OV was that Ken, what happened?
Subject: Re: icom ic-a200
Bob
radio master switch but OTOH one real over-voltage event was trapped by
my over-voltage protection.
Ken
Posted: Sat Dec 13, 2008 6:35 am Post subject: icom ic-a200 |
someone pointed out to me that a panel switch for the radio and intercom allows you to turn them on and the volume and squelch are then preset. good idea just for that reason. bob noffs
Posted: Sat Dec 13, 2008 12:58 pm Post subject: icom ic-a200 |
At 03:04 AM 12/13/2008, you wrote:
<snip>
Would you care to recommend a part number? The catalogs
are full of all manner of Transorbs. What voltage and energy
rating device do you recommend?
couple for
worst should
protection
Which devices might these be? I'm not plugged into
all that circulates into the aircraft accessories
equipment market. If there are specific devices vulnerable
to "spikes" it would be well that we know which products
they are . . . and what levels of abuse is dangerous
for them. If you have specifics to share, it would
be helpful.
( -Thomas Paine 1776- )
