toaster73(at)embarqmail.c Guest
Posted: Thu Dec 11, 2008 4:40 pm Post subject: Engine mounting ear nut torque |
Checked the archives with no luck, can't seem to find any info in engine documentation, therefore does anybody know the torque required for the nuts which hold the ears on the IO-540-D4A5 ? Its a 3/8 stud so does the usual torque number apply?
Chris Lucas
#40072
Posted: Fri Dec 12, 2008 5:49 am Post subject: Engine mounting ear nut torque |
You can look in the Engine Overhaul Manual if you have one and if it isn't specified then you use the general table of torque values for the engine. I have one, but don't have access to it right now. I'll look later if someone else hasn't already helped you by then.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Dec 11, 2008, at 7:39 PM, Chris wrote:
| Quote: | Checked the archives with no luck, can't seem to find any info in engine documentation, therefore does anybody know the torque required for the nuts which hold the ears on the IO-540-D4A5 ? Its a 3/8 stud so does the usual torque number apply?
Chris Lucas
#40072
| Quote: | http://www.matronics.com/contribution
Posted: Fri Dec 12, 2008 1:51 pm Post subject: Engine mounting ear nut torque |
Thats what I need but don't have one yet...figured someone on the list may have one at their finger tips. I wasn't sure I would want to use the standard torque since the stud is in Al housing. Other folks are checking so if I hear from my local builder friends I'll let you know.
-Chris
Posted: Fri Dec 12, 2008 2:20 pm Post subject: Engine mounting ear nut torque |
I have one...just not at my fingertips. In a few hours I may be able to get you the value.
Rick Sked
40185
jump2(at)sbcglobal.net Guest
Posted: Sat Dec 13, 2008 2:01 pm Post subject: Engine mounting ear nut torque |
The torque will be in your maintenace manual. If it is different it will be indicated as such. Don't forget your maintenance overhaul manual composes also of SB, SL and SI. as stated in the front of your maintenance book.
And when you do your mags repair don't forget section 8 of the unison/slick manuals. Otherwise you really are experimenting. Right Tim.
Pat Thyssen
--- On Fri, 12/12/08, Chris <toaster73(at)embarqmail.com> wrote:
[quote]From: Chris <toaster73(at)embarqmail.com>
Subject: Re: Engine mounting ear nut torque
Date: Friday, December 12, 2008, 3:51 PM
-Chris
