thesupe(at)hotmail.com Guest
Posted: Tue Dec 09, 2008 2:58 pm Post subject: first flight on skis this year |
Hi all C well I put new skis on the plane yesterday C finished the bungees for them today. We have about 6" of snow on the ground with more on the way so I taxied a bit C and then poured the coals to it and commited aviation. I love flying in the winter! Landed at a local lake C couldn't tell when I was on the ground (lake) it was so smooooooth. Of course no one there to see it! Had to get back to help the wife start supper as she wasn't feeling very good so had just a 40 minute flight C but it was nice. Temps were about +8 F but the heater helped and I was fine. Take care all C Jim Chuk Avid MK IV Jabiru northern MnSend e-mail anywhere. No map C no compass. Get your HotmailŽ account now. [quote][b]
Lynn Matteson
Posted: Tue Dec 09, 2008 5:16 pm Post subject: first flight on skis this year |
Well, ya beat me to posting, but I got my first ski flight last
Friday, Jim. I flew to a couple of nearby grass airports with a
pretty good south wind. I landed so slow and short at Brooklyn,
Michigan, (6G8) that when I took off, I just had to turn back and
look at my tracks. The wind was so strong, that it helped me do a
*real healthy* wingover bank. I figured it was time to put it away,
and headed for home....122 mph ground speed with 90 airspeed. Had to
land with this wind....quite a bit less at ground level...coming
directly from my left, but not a problem. On Sunday, I made a 1.3
hour day of it, landing at 5 different snow-flecked grass
strips...not enough snow to warrant my "wheels-penetrate-too-far-
skis" , but too much for just wheels. Work continues on my new skis,
with bending/laminating tests underway on Okoume plywood for the
bottoms, and the learning of TIG-welding starting today. I just
bought a Miller Diversion 165 TIG machine, and am brushing up/
learning this skill.
By the way, Jim, the prop came in, and it's a beauty. I got the old
one off, drilled the prop bushings out to 5/16" as well as the crush
plate, and it's ready to install. Our snow pretty much went away
today as a result of all day rain, but there's cold coming, and more
precip.
Lynn Matteson
Jabiru 2200, #2062, 593hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
On Dec 9, 2008, at 5:55 PM, Jim_and_Lucy Chuk wrote:
| Quote: | Hi all, well I put new skis on the plane yesterday, finished the
with more on the way so I taxied a bit, and then poured the coals
at a local lake, couldn't tell when I was on the ground (lake) it
so had just a 40 minute flight, but it was nice. Temps were about
+8 F but the heater helped and I was fine. Take care all, Jim
Send e-mail anywhere. No map, no compass. Get your HotmailŽ account
============================================================ _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Tue Dec 09, 2008 5:35 pm Post subject: first flight on skis this year |
Hey, Jim, what size are your skis? The ones I'm building are going to
be about 600 sq. inches for each ski, unless somebody talks me out of
that large a size. My present skis are about 470 sq. inches. I'm
building these so that the wheel doesn't penetrate so far and cause
so much drag. I'm also making them so that no lifting of the plane is
necessary to install, and no ski area right behind the wheel so no
"cheese slicer" action will take place. I'm hoping this design will
allow for less drag, and more staying on top of the snow, instead of
submarining below it. Mine will be 4130 tubing with plywood bottoms
and nylon-ish wear bars. Eventually I'm going to make some fiberglass
tops to enclose the tubing and provide a smooth upper surface so the
snow won't accumulate there. That will be a vacuum bagging operation,
which I'm also going to build and learn on.
Lynn Matteson
Sensenich 62x46
system;
N369LM |
akflyer
Posted: Tue Dec 09, 2008 6:41 pm Post subject: Re: first flight on skis this year |
Mine are 13.5 X 60... 810 squares. In deep powder you want all you can get!
I got mine installed a few days ago, but 40 mph winds and heavy freezing fog kept me grounded for the last few days. Now it is off to work so it will be a couple weeks before I get to try them out.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Posted: Tue Dec 09, 2008 9:35 pm Post subject: first flight on skis this year |
Hi Lynn C my skis are 9" wide and 60" long. They are just straight skis C not wheel penetration skis. I built them out of aluminum and the bottoms are 3/16" UHMW plastic. I think they weigh about 10 or 12 lbs each. Take care C Jim Chuk Avid Mk IV Jabiru Mn
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: Kitfox-List: first flight on skis this year
Date: Tue C 9 Dec 2008 20:34:22 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Hey C Jim C what size are your skis? The ones I'm building are going to
be about 600 sq. inches for each ski C unless somebody talks me out of
necessary to install C and no ski area right behind the wheel so no
allow for less drag C and more staying on top of the snow C instead of
snow won't accumulate there. That will be a vacuum bagging operation C
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 593hrs
Sensenich 62x46
flying again after rebuild C and new Electroair direct-fire ignition
system;
> ========== _-
Send e-mail faster without improving your typing skills. Get your HotmailŽ account.
Float Flyr
Posted: Wed Dec 10, 2008 9:42 am Post subject: first flight on skis this year |
Lynn I think you will have to have some floatation behind the wheel and a
lanyard to stop the ski tips form coming up too far on landing.
Have you considered letting a bit of air out of your tires and putting a
sheet of aluminium under the wheel and then pumping the tire up again to
hold the plate in place... That will increase your floatation in snow. You
only have to land on a pond or river to remove the plates before landing on
a paved runway again.
If you have ever seen a set of hydraulic convertible skis that is the same
thing without the expense... or convenience.
Noel
Noel Loveys
AME Intern, RPP
Kitfox III-A,
Aerocet 1100 floats
Newfoundland, Canada
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Wed Dec 10, 2008 10:25 am Post subject: first flight on skis this year |
Thanks, Jim. So you have 540 sq. in, minus whatever curves up on each
end if any. My proposed set is going to be about 600 sq. in., most of
which will be flat, with some of it curving up at the front and
back...a bit at the back to facilitate pulling it back into the
hangar. I shot a picture of some Federal (now Wipair) skis at Oshkosh
this year, and they had a pretty wide area in front of the wheel.
Those skis were hydraulically operated to reposition the ski in
relation to the wheel. I'm not going for the reposition aspect, but I
do want the larger area. I got almost hung up in 9" of snow last
year, and I'm hoping that the larger area will prevent that. Mine are
now tubing with UHMW bottoms, and the new ones will be plywood
bottoms, with two 4" wide UHMW "wear bars". I did a test of bending
and gluing together two layers of Okoume plywood, and that came out
well. Next is a test of applying some fiberglass to enclose the
plywood, which needs sealing and protecting from the weather. If I
can stand on the bent section and jump up and down on it, and it
holds, I'll progress to actually making the ski bottoms, then weld up
the framework of 4130. If the ply fails, I'll just use UHMW all the
way with the tubing frames, and test that. The difference between the
old skis and the new design will then be the lesser wheel penetration
and the wider area, and the elimination of the "cheese slicer" area
behind the wheel. I really need the wheels to stay on the plane to
facilitate ground handling when the snows down south here (Lower
Michigan, near Ohio) don't materialize, and for getting the plane in
and out of the hangar. I need/want to be able to fly into grass and
paved landing strips, and that is the reason for the wheel penetration.
Lynn Matteson
Sensenich 62x46
system;
On Dec 10, 2008, at 12:33 AM, Jim_and_Lucy Chuk wrote:
| Quote: | Hi Lynn, my skis are 9" wide and 60" long. They are just straight
skis, not wheel penetration skis. I built them out of aluminum and
or 12 lbs each. Take care, Jim Chuk Avid Mk IV Jabiru Mn
> Subject: Re: first flight on skis this year
> Date: Tue, 9 Dec 2008 20:34:22 -0500
> To: kitfox-list(at)matronics.com
going to
out of
plane is
fiberglass
operation,
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> system;
account
> > ========== _-
HotmailŽ account._-
N369LM |
Lynn Matteson
Posted: Wed Dec 10, 2008 10:37 am Post subject: first flight on skis this year |
That's my thinking too, Leonard. And if we get enough ski hanging out
there it might just add some lift, if it was shaped aerodynamically
enough. Of course, if we get TOO much area, it might convert to
friction on the snow, and that would not be good. It sounds like from
what I've found so far that there's a happy medium. I'm presently
looking for an article by a Canadian gent, and or the National
Research Council of Canada, who wrote a paper or book or something
about 'the effect of snow on aircraft skis'. I googled the subject,
and Amazon.com is looking for that info after I queried them.
Lynn Matteson
Sensenich 62x46
system;
On Dec 9, 2008, at 9:41 PM, akflyer wrote:
can get!
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
As done as any plane will ever be.... cause now the tinkeritis
takes over.
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 18585#218585
N369LM |
gary.algate(at)sandvik.co Guest
Posted: Wed Dec 10, 2008 1:36 pm Post subject: first flight on skis this year |
Lynn'
if you really want to get fancy take a look at the wheel skis that the Canadian Challenger dealers are offering for the Challengers. They have a small electric/hydraulic cylinder that moves the ski back and forward. This allows the wheel to actually rid up on top of the ski when landing on snow and then when the skis moved back it drops down to penetrate the ski.
Drop down is really the wrong term as it just basically compresses the tire as it moves back and forward.
Neat set up, and the little electric pump is actually integral in each cylinder
Gary
Gary Algate
SMC, Exploration
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to [url=Arial]UNICEF Australia[/url]. We wish you a safe and happy Christmas".
Sent by: owner-kitfox-list-server(at)matronics.com
11/12/2008 05:14 AM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Re: Re: first flight on skis this year
Lynn Matteson
Sensenich 62x46
system;
> --> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com>
> can get!
> DO NOT ARCHIVE
> Leonard Perry
> Soldotna AK
> Avid "C" / Mk IV
> 582 IVO IFA
> Full Lotus 1260
> takes over.
> http://forums.matronics.com/viewtopic.php?p=218585#218585
Lynn Matteson
Posted: Wed Dec 10, 2008 2:42 pm Post subject: first flight on skis this year |
Hi Noel-
The proposed design for the skis I'm building has a 6" wide section
of ski running parallel to the wheel for the full length of the
ski...about 60"...but not right behind the ski. So yes, there is ski
to the rear of the wheel, just not right BEHIND the wheel. It is just
like the Federal.Wipair hydraulic-repositional wheel-penetration ski
that I saw at Oshkosh. And of course I have not only one, but two
1/8" safety cables(redundancy)......that prevent the ski from tipping
up beyond 5° at the front of the ski, per the ski rigging
instructions at the rear of 43.13-2A (Advisory Circular) which I'm
sure you are all familiar with. These safety cables also prevent the
ski from tipping up too far during flight. I have thought of the
plate that slips under the wheel, but this is not a good safety
measure if you consider needing to land at a dry paved strip under
emergency conditions. And around here with the lakes not frozen over
yet, that type of emergency landing (the frozen river or pond) is out
of the question at this point. I feel that I need the wheel to be
operational at all times for the conditions that I fly in. That type
of operation...the sliding plate...is only safe if you are flying in
totally frozen conditions.
I will also utilize two restraint cables and two bungies at the
front...redundancy again (and to please my mentor/flight
instructor)...including crust-cutters so that the bungies don't get
within 8-12" of the nose of the ski, as pointed out in 43.13. I
already have these features installed on my present skis.
Lynn Matteson
Sensenich 62x46
system;
and a
putting a
again to
snow. You
landing on
the same
Noel
Noel Loveys
AME Intern, RPP
Kitfox III-A,
Aerocet 1100 floats
N369LM |
Lynn Matteson
Posted: Wed Dec 10, 2008 2:50 pm Post subject: first flight on skis this year |
Other than the expense of the hydraulic system, the "repositionable"
aspect of those skis is supposedly against the Sport Pilot
regulations. I'm sure that if I felt that was an option, I'd say
screw the rules and go that way, but I think the wheel only
penetrating by about 1/2" (new design), I'll be fine. It should be
far better than the 1-1/2" to 2" penetration that I employ now.What
you point out, Gary, is exactly the method that those Federal/
Wipair's that I saw at Oshkosh use.
Lynn Matteson
Sensenich 62x46
system;
On Dec 10, 2008, at 4:35 PM, gary.algate(at)sandvik.com wrote:
Lynn'
each cylinder
Gary
Gary Algate
SMC, Exploration
have made a contribution to UNICEF Australia. We wish you a safe
11/12/2008 05:14 AM
Please respond to
To
cc
Subject
Lynn Matteson
Sensenich 62x46
system;
> can get!
> DO NOT ARCHIVE
> Leonard Perry
> Soldotna AK
> Avid "C" / Mk IV
> 582 IVO IFA
> Full Lotus 1260
> takes over.
N369LM |
patreilly43(at)hotmail.co Guest
Posted: Wed Dec 10, 2008 3:01 pm Post subject: first flight on skis this year |
Lynn C What about curving the edge behind the wheel up similar to the front of the ski to eliminate the "cheese cutter effect?
Pat Reilly
Mod 3 582 rebuild
Rockford C IL
Subject: Re: Re: first flight on skis this year
Date: Wed C 10 Dec 2008 17:50:01 -0500
Other than the expense of the hydraulic system C the "repositionable"
regulations. I'm sure that if I felt that was an option C I'd say
screw the rules and go that way C but I think the wheel only
penetrating by about 1/2" (new design) C I'll be fine. It should be
you point out C Gary C is exactly the method that those Federal/
Lynn Matteson
Sensenich 62x46
system;
On Dec 10 C 2008 C at 4:35 PM C gary.algate(at)sandvik.com wrote:
> Lynn'
> Neat set up C and the little electric pump is actually integral in
> each cylinder
> Gary
> Gary Algate
> SMC C Exploration
> addressees. Any review C dissemination C distribution C or copying of
> recipient is prohibited. If you have received this e-mail in error C
> This year C instead of sending you a Christmas card in the mail C we
> 11/12/2008 05:14 AM
> Please respond to
> To
> cc
> Subject
> That's my thinking too C Leonard. And if we get enough ski hanging out
> there it might just add some lift C if it was shaped aerodynamically
> enough. Of course C if we get TOO much area C it might convert to
> friction on the snow C and that would not be good. It sounds like from
> looking for an article by a Canadian gent C and or the National
> Research Council of Canada C who wrote a paper or book or something
> about 'the effect of snow on aircraft skis'. I googled the subject C
> Lynn Matteson
> Sensenich 62x46
> system;
> > can get!
> > I got mine installed a few days ago C but 40 mph winds and heavy
> > DO NOT ARCHIVE
> > Leonard Perry
> > Soldotna AK
> > Avid "C" / Mk IV
> > 582 IVO IFA
> > Full Lotus 1260
> > takes over.
> > Read this topic online here:
Posted: Wed Dec 10, 2008 3:38 pm Post subject: first flight on skis this year |
Good point Pat - on my first set of skis the trailing edge of the ski was parallel with the main ski body. Whenever I tried to pull my plane backwards that son of a b- - - - would just tip down and dig in. My next set had a graceful curve at the rear and I could spin the plane or pull it back with no problems
Gary
Gary Algate
Classic 4 Jab 2200
patrick reilly <patreilly43(at)hotmail.com>
11/12/2008 09:41 AM
Please respond to
kitfox matronics <kitfox-list(at)matronics.com> cc
Subject
RE: Re: first flight on skis this year
Lynn, What about curving the edge behind the wheel up similar to the front of the ski to eliminate the "cheese cutter effect?
Pat Reilly
Mod 3 582 rebuild
Rockford, IL
> Date: Wed, 10 Dec 2008 17:50:01 -0500
> Lynn Matteson
> Sensenich 62x46
> system;
> > Lynn'
> > each cylinder
> > Gary
> > Gary Algate
> > SMC, Exploration
> > 11/12/2008 05:14 AM
> > Please respond to
> > To
> > cc
> > Subject
> > Lynn Matteson
> > Sensenich 62x46
> > system;
> > > can get!
> > > DO NOT ARCHIVE
> > > Leonard Perry
> > > Soldotna AK
> > > Avid "C" / Mk IV
> > > 582 IVO IFA
> > > Full Lotus 1260
> > > takes over.
Lynn Matteson
Posted: Wed Dec 10, 2008 4:06 pm Post subject: first flight on skis this year |
That's a good idea, Pat. I hadn't thought about doing that since I
decided to just eliminate the portion of ski right behind the wheel.
Doing this serves two purposes....it eliminates the cheese cutter,
and eliminates the area that tends to collect snow...two birds, one
stone. : )
I saw a picture of a skiplane that had the rear of the ski bent up,
and I was able to do that mod on mine (like Gary said), but didn't
really think of the area right behind the wheel at that time. Even
now, I have to hook up the winch to drag mine back into the hangar
after first shoveling the snow from behind it. My new skis will have
the rear portion bent up a bit more.
Lynn Matteson
Sensenich 62x46
system;
On Dec 10, 2008, at 5:59 PM, patrick reilly wrote:
| Quote: | Lynn, What about curving the edge behind the wheel up similar to
Pat Reilly
Mod 3 582 rebuild
Rockford, IL
N369LM |
Float Flyr
Posted: Thu Dec 11, 2008 7:50 am Post subject: first flight on skis this year |
I'm with you on the redundancy! This is a case where more is better.
The plate I was talking about is more of an install plate than a sliding
plate. The first skis I ever installed were manual hydraulic sliding
plates. The skis were mounted on springs that allowed the ski to be
displaced an inch or so as the plate was actuated in flight. It was
reasonable complex and added weight but gave a lot more flotation to the
skis for use in powder snow. The guy who flew the plane said he only ever
closed the plate when he expected deep powder.
As with most things there is the element of compromise. Your light plane
doesn't need the flotation that an overloaded Super Cub in ten feet of
powder snow would need.
Don't forget to post a few pictures of the new skis once they are
christened.
Noel
Kitfox III-A
Float Flyr
Posted: Thu Dec 11, 2008 7:58 am Post subject: first flight on skis this year |
Gary:
The guy I bought my plane from only flew it on skis... No one has flown the bird on wheels yet J . He built a set of back up points that slid under the skis and were held in place with bungee chords. He used to tow the plane to a bog behind his snowmobile for takeoff. Only thing he mentioned to me was to be extremely careful to remove the reverse tips before taking off.
If you want I’ll dig them out and take a couple of pictures.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of gary.algate(at)sandvik.com
Sent: Wednesday, December 10, 2008 8:08 PM
Subject: RE: Re: first flight on skis this year
Gary
Gary Algate
Classic 4 Jab 2200
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to UNICEF Australia. We wish you a safe and happy Christmas".
11/12/2008 09:41 AM
Please respond to
To
cc
Subject
Pat Reilly
Mod 3 582 rebuild
Rockford, IL
> Lynn Matteson
> Sensenich 62x46
> system;
> > Lynn'
> > each cylinder
> > Gary
> > Gary Algate
> > SMC, Exploration
> > 11/12/2008 05:14 AM
> > Please respond to
> > To
> > cc
> > Subject
> > Lynn Matteson
> > Sensenich 62x46
> > system;
> > > can get!
> > > DO NOT ARCHIVE
> > > Leonard Perry
> > > Soldotna AK
> > > Avid "C" / Mk IV
> > > 582 IVO IFA
> > > Full Lotus 1260
> > > takes over.
Gifts!)
href="http://www.matronics.com/contribution">[b]http://www.matronics.com/contribution
-Matt Dralle, List Admin.
href="http://www.matronics.com/Navigator?Kitfox-List">[b]http://www.matronics.com/Navigator?Kitfox-List
FORUMS -
href="http://forums.matronics.com/">[b]http://forums.matronics.com
=========== | Quote: | | http://www.matronics.com/contribution | 01234567890123
Kitfox III-A
Float Flyr
Posted: Thu Dec 11, 2008 8:08 am Post subject: first flight on skis this year |
Lynn:
Do you use a tail ski? A lot of the bush pilots I've talked to say the use
of a tail ski only throws off the balance of a light plane. Heavier planes
like the DHC-3 Otter really need a tail ski. I seem to remember seeing
pictures of a DC-3 on skis with a tail ski.
Noel
Kitfox III-A
Lynn Matteson
Posted: Thu Dec 11, 2008 9:12 am Post subject: first flight on skis this year |
Will do, Noel.
Every time I look at pictures of skis, I get another idea...I just
looked again at the Wipaire skis, and noticed they bend the outer
edges of the ski up a slight amount, like a spray rail on a boat, I'd
imagine. I'm back to the drawing board.......: )
Lynn Matteson
Sensenich 62x46
system;
On Dec 11, 2008, at 10:50 AM, Noel Loveys wrote:
sliding
to the
only ever
plane
christened.
Noel
N369LM |
Lynn Matteson
Posted: Thu Dec 11, 2008 9:13 am Post subject: first flight on skis this year |
Please do, Noel...for Gary AND me.
Lynn Matteson
Sensenich 62x46
system;
On Dec 11, 2008, at 10:57 AM, Noel Loveys wrote:
| Quote: | Gary:
If you want Ill dig them out and take a couple of pictures.
Noel
N369LM |
Lynn Matteson
Posted: Thu Dec 11, 2008 9:17 am Post subject: first flight on skis this year |
I was thinking of using one, but I'm not committed to it yet. That
was one of the things that I thought might help with the "getting (un)
stuck in 9" of snow" problem that I had last year.
So far I've been ok without one, but......
Lynn Matteson
Sensenich 62x46
system;
On Dec 11, 2008, at 11:07 AM, Noel Loveys wrote:
Lynn:
the use
Heavier planes
seeing
Noel
N369LM |
