william(at)gbta.net Guest
Posted: Tue Dec 16, 2008 9:23 am Post subject: Pg. 13-3 step 2 (wing spar construction) |
Can anybody clarify the 2nd step on page 13-3 in the wing spar construction section?? I understand to countersink the nutplate attach holes but the section that reads "Machine countersink those rib to spar flange attach rivet holes that are in line with the nutplate attach rivet holes and are inboard of the most outboard fuel tank attach nutplate." just kinda all runs together.
Also, at what point do I need to start using a fuel tank dimple die instead of the regular 3/32 dimple die???
Bill
pascal(at)rv10builder.net Guest
Posted: Tue Dec 16, 2008 9:43 am Post subject: Pg. 13-3 step 2 (wing spar construction) |
As far as the die. if you bought it, use it on all of the fuel tank pieces, if you didn't don’t buy it. I did my whole fuel tank with a 3/32 dimple die, it worked fine.
Pascal
Sent: Tuesday, December 16, 2008 9:23 AM
Subject: Pg. 13-3 step 2 (wing spar construction)
Bill
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
