LED's
EMAproducts(at)aol.com
PostPosted: Mon Dec 22, 2008 12:18 pm    Post subject: LED's Reply with quote
Gentlemen:
I am not an electronics man, however I have been using LED's in our AOA systems for 14 years. Use caution and be aware just because the LED's come from the same supplier, they may NOT have the same intensity. They also have different dimming requirements for different colors. We have found that if using the Ultra-Bright LED's they must be individually paired (same colors and different) to insure they all dim the same. Not a big deal, but if you are looking for professional results best to take the extra time and compare them prior to soldering and saying darn I should have All except the Ultra bright by the same mfg. seem pretty good, but a large variance even in same order of 50 LED's ordered at same time.
Elbie Mendenhall
www.riteangle.com
One site keeps you connected to all your email:-dp&icid=aolcom40vanity&ncid=emlcntaolcom00000025">Try it now.
PostPosted: Mon Dec 22, 2008 2:30 pm    Post subject: LED's Reply with quote
At 02:16 PM 12/22/2008, you wrote:
Gentlemen:
Elbie Mendenhall
I've heard this before. A number of folks who supply
sunlight viewable dead-front annunciators have mentioned
a need for matching sets of leds for output to achieve
uniform appearance across the panel.
Bob . . . [quote][b]
