Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 139 Location: Huntley, Illinois 60142
Posted: Wed Dec 17, 2008 10:47 am Post subject: Static System Assembly |
Dear List ...
I'm rebuilding my static system and am looking for "how did you do it"
suggestions.
Specifically:
How did you attach the tubing to the Van's static port rivet tails?
Glue, RTV or ... ?
Did any of you find a clamp that would work with such a small diameter and
short rivet tail?
What method does not work or will not hold together between condition
inspections?
Thanks, Jerry
rice737(at)msn.com Guest
Posted: Wed Dec 17, 2008 12:17 pm Post subject: Static System Assembly |
Hey Jerry C
I bought some rivets with the same head but a longer grip and used a little sealant and a zip tie. I didn't like that the vans rivets had such a short shank to clamp to.
Paul Rice
RV8 Flying Siren
130 hours
| Quote: | From: jerry(at)mc.net
To: rv-list(at)matronics.com
Subject: Static System Assembly
Date: Wed C 17 Dec 2008 12:37:31 -0600
--> RV-List message posted by: "Jerry Grimmonpre" <jerry(at)mc.net>
Dear List ...
suggestions.
Specifically:
Glue C RTV or ... ?
short rivet tail?
inspections?
Thanks========
jfogarty(at)tds.net Guest
Posted: Wed Dec 17, 2008 1:09 pm Post subject: Static System Assembly |
RV's Builders, I used a silicone and the rivets in the kit from Van's. Is there any problem with using silicone on the aluminum skin or ribs? Silicone works well for holding parts in place, however, will it effect the skin over time? Thanks for any input.
Jim
RV9a
rv9jim(at)juno.com Guest
stein(at)steinair.com Guest
Posted: Wed Dec 17, 2008 1:47 pm Post subject: Static System Assembly |
It won't necessarily affect the skins, but if you use it externally it'll likely make it near to impossible to ever get a paint job to stick to it...even with it visibly cleaned. Silicone (or an product with silicone in it) is a big no-no for external use on airplanes as it doesn't play nicely with paint.
Stein
[quote] -----Original Message-----
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jim Fogarty at Lakes & Leisure Realty
Sent: Wednesday, December 17, 2008 3:09 PM
Subject: Re: Static System Assembly
Jim
RV9a
pbesing(at)yahoo.com Guest
Posted: Wed Dec 17, 2008 2:37 pm Post subject: Static System Assembly |
Not sure if they still sell them, but Cleveland tool makes some machined static ports which are very nice. Just be sure and mount them to the OUTSIDE of the skin...otherwise the static port will be caught in the boundary layer, and will not be accurate..ask me how I know....
Paul Besing
Sent: Wednesday, December 17, 2008 2:47:27 PM
Subject: RE: Static System Assembly
.hmmessage P { PADDING-RIGHT:0px;PADDING-LEFT:0px;PADDING-BOTTOM:0px;MARGIN:0px;PADDING-TOP:0px;} BODY.hmmessage { FONT-SIZE:10pt;FONT-FAMILY:Verdana;} It won't necessarily affect the skins, but if you use it externally it'll likely make it near to impossible to ever get a paint job to stick to it...even with it visibly cleaned. Silicone (or an product with silicone in it) is a big no-no for external use on airplanes as it doesn't play nicely with paint.
Stein
Jim
RV9a
gyoung
Joined: 09 Jan 2006 Posts: 155 Location: Republic of Texas
Posted: Wed Dec 17, 2008 2:43 pm Post subject: Static System Assembly |
There are numerous paintable sealant/adhesives that can do the same kind of job as the silicone-based ones. Proseal-like tank sealants, Lexel and Sikaflex come to mind.
Greg Young
[quote] From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of SteinAir, Inc.
Sent: Wednesday, December 17, 2008 3:47 PM
Stein
| Quote: | -----Original Message-----
Subject: Re: RV-List: Static System Assembly
Jim
RV9a
| [b]
Posted: Wed Dec 17, 2008 2:45 pm Post subject: Static System Assembly |
Well ...... depends. Some silicone caulk smells like vinegar ....
acetic acid ..... which surely isn't friendly to aluminum ..... but
unlike the lead pencil/aluminum corrosion I haven't heard of any real
problems with using silicone on aluminum. In fact, I see it used quite
a lot. I know I didn't answer your question, but it is something to
think about.
Linn
Jim Fogarty at Lakes & Leisure Realty wrote:
[quote] RV's Builders, I used a silicone and the rivets in the kit from
Jim
RV9a
Posted: Wed Dec 17, 2008 3:01 pm Post subject: Static System Assembly |
Stein, Thanks for the info. I appreciate your knowledge, I'm sorry I didn't get to your shop last Saturday. I hope you had a good turn out and that your business is busy. Good luck in 2009.
Jim
RV9a
mikerv6a(at)ao.com Guest
Posted: Wed Dec 17, 2008 4:02 pm Post subject: Static System Assembly |
I came up with a way to make a back-side fitting for
Van's static port. This permits use of a removable
fitting for plastic tubing to connect the static vent
plumbing. It's described in the EAA chapter 105
newsletter for April 2005, page 2:
http://www.eaa105.org/Newsletter/nl-200504.pdf
Mike Linse
Corvallis, OR
RV-6A (canopy, in the winter...)
Jerry Grimmonpre'
Posted: Wed Dec 17, 2008 6:40 pm Post subject: Static System Assembly |
Hi Mike,
You have won the prize for an elegant solution to the static system plumbing
challenge. That's a clever approach. If it's OK I am going to use it for
my static hook-up. It also seems possible to drill a close fitting hole in
a light weight pipe cap, and expand the rivet into that cap then drive out
the center stem. Back it up with a little tank sealant.
Thanks, Jerry
bsavage22(at)hotmail.com Guest
Posted: Wed Dec 17, 2008 8:18 pm Post subject: Static System Assembly |
I had the same trouble with the rivet tail being to short. I went to the hardware store and bought some aluminum tubing that would just fit over the rivet tail before it was installed. I cut about a 1 inch length and had someone hold the tubing over the rivet on the inside of the fuselage while I pulled the rivet from the out side. As the pop rivet expanded it did the same to the tubing and the tubing made a nice little nipple to connect van's plastic tubing to on the inside. I sealed it with a couple of turns of safety wire.
Bob Savage
RV7A
Firewall Forward
[quote] From: jerry(at)mc.net
Dear List ...
suggestions.
Specifically:
Glue C RTV or ... ?
short rivet tail?
inspections?
Tha=============
Suspicious message? There’s an alert for that. Get your Hotmail® account now.
Posted: Wed Dec 17, 2008 11:04 pm Post subject: Static System Assembly |
Hi Jerry
That's a good idea: It eliminates the tapping operation.
Also, one complication of my use of round bar is that
there are not features for use of a wrench. Vise grip
pliers solved that, but I made later versions from 1/2"
hex aluminum bar. Pipe caps generally have features
that make them compatible with some kind of wrench or
pliers. McMaster sells an aluminum cap that's threaded
for 1/8 pipe, their part number 44705K372, $2.18.
Mike Linse
Corvallis, OR
RV-6A
Hi Mike,
[snip] It also seems possible to drill a close fitting hole
in a light weight pipe cap, and expand the rivet into that
cap then drive out the center stem. Back it up with a little
tank sealant.
Thanks, Jerry
> Van's static port... It's described in the EAA chapter 105
Jerry Grimmonpre'
Posted: Thu Dec 18, 2008 1:17 pm Post subject: Static System Assembly |
Mike,
Thanks for the McMaster part number on the cap. I just ordered two of them
along with enough "push to connect" parts to assemble the static plumbing.
You are right, Mike, these parts will make rebuilding the system far easier
and the sealing of small parts is now going to be a non-issue.
One other thing to add: If a push to connect T is installed in the static
line leading to the instruments, the transponder check will be simple to do.
This T could be permanently installed in the line passing through the rear
cockpit which makes it accessible while standing on the ground and reaching
over the canopy rail.
Thanks, Jerry
