		peterson(at)orbitec.com.a Guest
				 Posted: Mon Dec 15, 2008 7:09 pm    Post subject: Garmin 430 WX protocol |
				Hi all,
 I'm new to the list and I  have a question (sorry if it's a bit off-
 topic) - does anybody know where I can find out more about the
 protocol for weather display that is used on the Garmin series of GPS
 receivers? For example, I know it is possible to display satellite
 weather that has been received by a Garmin GDL-69 (satellite receiver)
 on the display of Garmin 430.
 Does anyone happen to know the protocol / format for the communication
 between the GDL-69 and the Garmin 430? Is it documented anywhere, or
 perhaps an open standard (e.g. ARINC?). I have done a bit of google
 searching but didn't turn anything up.
 Thanks very much in advance.
 Regs,
 Dave
		Lenny Iszak
				 Posted: Mon Dec 15, 2008 9:18 pm    Post subject: Re: Garmin 430 WX protocol |
				Dave,
 I don't think they would publish that. But we could hook up a port monitor between the two devices and document the protocol. We could then emulate the GDL-69 using a much cheaper WxWorks receiver.
 Then again, we could emulate the Garmin with a much cheaper computer, and then...    oh, never mind...
 Lenny
				 Posted: Tue Dec 16, 2008 9:14 am    Post subject: Garmin 430 WX protocol |
				The 430 and 530 will not display many of the weather options that are
 offered.  I think it will show Nexrad and maybe one other thing on the
 map and it will give text metars and tafs, I think.  The people I've
 talked to who have flown behind it much rather use a 496.  I know this
 doesn't answer your question, and you may already know it, but thought
 I would throw that out.  If I was putting in another WX receiver, I
 would not pipe it through the 430.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 On Dec 16, 2008, at 12:18 AM, Lenny Iszak wrote:
  Dave,
  Lenny
  http://forums.matronics.com/viewtopic.php?p 19553#219553
		billderou(at)yahoo.com Guest
				 Posted: Tue Dec 16, 2008 10:53 am    Post subject: Garmin 430 WX protocol |
				David-
 What did you have in mind? I have interfaced the $825 Spruce WX Receiver to my computer and display Nexrad, Metar, and TFR's and know this protocol.
 If you prefer email me directly at billderou(at)yahoo.com
 Bill DeRouchey
 N939SB, Flying
 --- On Tue, 12/16/08, Jesse Saint <jesse(at)saintaviation.com> wrote:
 [quote]From: Jesse Saint <jesse(at)saintaviation.com>
 Subject: Re: Re: Garmin 430 WX protocol
 Date: Tuesday, December 16, 2008, 9:13 AM
 [quote]--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com>
 The 430 and 530 will not display many of the weather options that are offered.
 I think it will show Nexrad and maybe one  other thing on the map and it will
 give text metars and tafs, I think.  The people I've talked to who have
 flown behind it much rather use a 496.  I know this doesn't answer your
 question, and you may already know it, but thought I would throw that out.  If I
 was putting in another WX receiver, I would not pipe it through the 430.
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
  	  | Quote: | 	 		   --> RV10-List message posted by: "Lenny Iszak"
 <lenard(at)rapiddecision.com>
  Dave,
  Then again, we could emulate the Garmin with a much cheaper [quote][b]
				 Posted: Tue Dec 16, 2008 3:37 pm    Post subject: Garmin 430 WX protocol |
				Hi Lenny,
 Thanks for your feedback. I was beginning to suspect that it would be a proprietary protocol.
 Putting a protocol analyser onto the traffic and documenting the messages sounds like the only way forward. I am disappointed that there are no standardised protocols (e.g. an ARINC standard) for the exchange of WX data between receivers and MFD displays. Oh well. I presume this is also the case for traffic data, etc?
 Next question: do you happen to know the nature of the electrical interface between the GDL-69 and the 430? Is it a serial line protocol (RS-232 etc?)
 Dave
 On 16/12/2008, at 6:58 PM, RV10-List Digest Server wrote:
 Time: 09:18:41 PM PST US
 Subject: Re: Garmin 430 WX protocol
 From: "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
 Dave,
   oh, never mind...
 Lenny
 http://forums.matronics.com/viewtopic.php?p=219553#219553
 Orbitec Pty Ltd
 Suite 1-11, 460 Pacific Hwy
 St. Leonards NSW 2065
 AUSTRALIA
 Phone:  +61 (0)2 8002 4780
 Mobile: +61 (0)415 943 940
 Email:  support(at)orbitec.com.au (support(at)orbitec.com.au)
 Web:    http://www.orbitec.com.au
 This email may contain CONFIDENTIAL information intended solely for
 the use of the intended recipient. If you receive this email in error,
 we ask that you notify us by email of our error and then delete the
 email as soon as possible. We ask that you do not copy, store or
 distribute any message that you have received in error and we thank you
 for your assistance.
		Lenny Iszak
				 Posted: Tue Dec 16, 2008 9:31 pm    Post subject: Re: Garmin 430 WX protocol |
				Dave,
 I have the install manual for a discontinued GDL-49 unit, which talks to the 400/500 series panel mounts via RS-232, so I think it's safe to assume that the 69 uses the same thing.
 If that's the case it's very easy to sniff the data from it. Assuming that it's coming from the same source as the WxWorks data, it won't be hard to guess the protocol unless they encrypted the data. Bill may be able to help you with that.
 The problem with the protocol hack would be that if you sent a bad packet  to your Garmin screen during flight, you could possibly lock it up in flight. Not very desirable.
 I'm going to display WxWorks data on my own screen. It's much safer that way and allows for other interesting tricks...
 Lenny
 #40803
 just opened the door to "door hell"
				 Posted: Wed Dec 17, 2008 4:04 pm    Post subject: Garmin 430 WX protocol |
				Thanks Lenny, and to everyone else who responded.  I think the best bet is obviously a protocol analyser and a lot of spare time
 Dave
 On 17/12/2008, at 6:59 PM, RV10-List Digest Server wrote:
 [quote]Time: 09:32:17 PM PST US
 Dave,
 very desirable.
 Lenny
 #40803[b]
