		Arty Trost
  Joined: 25 May 2006 Posts: 206 Location: Sandy, Oregon
				 Posted: Fri Dec 19, 2008 1:54 pm    Post subject: From Lockwood Aviation re: oil and fuel |
				Hi Kolbers,
 This was posted today on the FlyChallenger list, and I thought it would be of interest.
 Arty Trost
 Sandy, Oregon
  	  | Quote: | 	 		  From Richard on the FlyChallenger list:
 I had an interesting talk with Dean from Lockwood Aviation today
 about my concerns for the best products to put through the 503 DCDI.
 I know it's been discussed at nausium, but time is drawing near for
 the crank to start turning.
 About oil:
 As spoken about on the list many times, Shell has bought out Penzoil.
 He stated that with the supply of Penzoil 2 stroke oil for air cooled
 engines drawing near extinction, Shell will be coming out with an oil
 especially formulated for the Rotax engine. Great news!
 It has been blind bench tested with three other brands and has
 prooved its worth. It will be out soon but he doesn't know exactly
 when or what the new product name will be. Stay tuned.
 Fuel:
 When asked what he would burn in a 503 if he was the owner.
 He stated that if your concerned about legalities and need to keep
 your fuel at the Rotax reccomended 5% or less of Ethenol then he
 would mix, as some on the list have mentioned, 50% 100LL avgas with
 50% auto gas, 87 octane or higher that contains 10% of Ethenol.
 On the other hand he stated that there have been no ENGINE problems
 with running the auto gas with 10% ethenol.
 The POSSIBLE problems coud include deterioration of O-rings, Poly
 fuel tanks, fuel lines if not Ethenol rated, and other rubberized
 parts.
 He stated that he would keep a close eye on these parts if running
 straight auto fuel.
 Fuel filters:
 He doesn't encourage the use of paper element fuel filters when
 running Ethenol tainted fuel. Dean states that over time, I don't
 know how long, the paper absorbes the water from the Ethenol and
 swells, which can cause a fuel starvation problem.
 He suggest using a metal mesh fuel filter of 60 to 70 microns. The
 Rotax manual suggest a metal mesh also.
 These are his suggestions and I know there are vairables, but I
 thought I'd put it out there.
 I'm going to change my paper fuel filter to the metal mesh but
 haven't decided what fuel or fuel mix I may use. I'm on the fence but
 leaning towards the auto fuel with a higher octane.
 I'm not sure but I think the higher octane fuel burns more completely
 and may leave less deposits. I'd like your suggestions on the octane
 rating?
 Richard
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Dana
				 Posted: Fri Dec 19, 2008 5:11 pm    Post subject: From Lockwood Aviation re: oil and fuel |
				At 04:53 PM 12/19/2008, TheWanderingWench wrote:
  	  | Quote: | 	 		  ...I'm on the fence but
 rating?
 No difference there.  Higher octane fuel has one purpose only:  It resists
 detonation, or "pinging".  This is typically a problem on higher
 compression engines.  There is no advantage to using higher octane fuel
 than the manufacturer calls for... it doesn't burn cleaner, or make more
 power, or leave less deposits.
 However... some auto fuel manufacturers may put more or different detergent
 or other additives in their "premium" higher octane fuel.  This may reduce
 deposits; I don't know... but it's not the octane rating that's making any
 difference.
 -Dana
   Software isn't released, it's allowed to escape.
				 Posted: Fri Dec 19, 2008 6:04 pm    Post subject: From Lockwood Aviation re: oil and fuel |
				If you are using a porous bronze filter with an oil mix you may have
 a problem.  Aside from blowing through them there
 is no visual method to inspect. After some use, especially during
 storage, they can gum up and reduce flow.
 I did have one of those glass cylinder type on a VW and it was easy
 to take apart to clean the plastic mesh sleeve
 inside but wouldn't care to have the pot metal parts of that thing on
 an airplane.
 I will continue to use the "paper" filter and throw it away after
 each season.  They are resin impregnated and
 reasonably waterproof.  Cheap too.
 BB
 On 19, Dec 2008, at 4:53 PM, TheWanderingWench wrote:
  <thewanderingwench(at)yahoo.com>
  Hi Kolbers,
  Arty Trost
  Sandy, Oregon
  About oil:
  Fuel:
  parts.
  straight auto fuel.
  Fuel filters:
  rating?
  Richard
