paul.the.aviator(at)gmail Guest
Posted: Fri Dec 26, 2008 4:16 pm Post subject: Coolant leak |
Hi All,
It has been miserably cold here for the past month and I haven't flown
my aircraft. I ventured out to my hanger today (unheated) to be
greeted by the sight of coolant on the floor. It is dripping from the
radiator area.
I haven't investigated further, I'll have to move my airplane to the
heated workshop area of my hanger first, but I had a few questions for
the folks on the forum.
I have a 50:50 mix of water/glycol in my aircraft. The coldest it has
been in the last 30 days is zero degrees Fahrenheit, -18 centigrade.
Has anyone had experience of 50:50 mix of water/glycol would freeze
at this temperature ?. My quick research suggests it freezes at -36F
For people living nearer to the Arctic circle than me, has anyone had
a similar experience ?
Thanks, Paul
kheindl(at)msn.com Guest
Posted: Fri Dec 26, 2008 4:46 pm Post subject: Coolant leak |
Paul C
I think you will find a faulty connection. We get temps down to -25C C with my Europa in the garage. I also use 50/50 coolant.
Karl
[quote] Date: Fri C 26 Dec 2008 18:15:33 -0600
Subject: Coolant leak
--> Europa-List message posted by: "Paul McAllister" <paul.the.aviator(at)gmail.com>
Hi All C
radiator area.
I haven't investigated further C I'll have to move my airplane to the
heated workshop area of my hanger first C but I had a few questions for
been in the last 30 days is zero degrees Fahrenheit C -18 centigrade.
For people living nearer to the Arctic circle than me C has anyone had
a similar ==================
Posted: Fri Dec 26, 2008 5:40 pm Post subject: Coolant leak |
Hi Karl,
Thanks for sharing your experience. Maybe I will get to move the
airplane tomorrow to take a look. Have you had leakage do to cold
fittings ?
Thanks, Paul
Paul,
I think you will find a faulty connection. We get temps down to -25C, with
Karl
rampil
Posted: Fri Dec 26, 2008 6:18 pm Post subject: Re: Coolant leak |
Hi Paul,
My money is on a leaking connector also, hopefully easier to repair than a
split hose
Best Regards for a new year,
josok-e(at)ukolo.fi Guest
Posted: Fri Dec 26, 2008 10:59 pm Post subject: Coolant leak |
Hi Paul,
The 50-50 mix does not freeze. You have been careful of course and not added water to pre-mixed antifeeze. I had leaks when cold. It seems that the fittings shrink faster then the srew type hose clamps. I aquired spring type clamps to get rid of the problem, but got never time to instasll them. They are yours if you send me your address of forum.
Jos Okhuijsen
Visit - www.EuropaOwners.org
Trevpond(at)aol.com Guest
Posted: Sat Dec 27, 2008 4:08 am Post subject: Coolant leak |
Hi Paul,
I had similar problems with my aircraft - sorted it with Nev's help by fitting double jubilee clips on radiator connections.
regards
Trev Pond
G-LINN
