jfgilmore
Posted: Sat Dec 27, 2008 2:32 pm Post subject: Drilling Control Stick |
Holy Moley! Â What kind of drill bit does it take to drill the control stick/base assembly?? Â It's killing my bits -- I've had to re-sharpen more than 6 times, and I'm not completely thru even the first assembly!
Jim Gilmore #40317
Legacy fuse complete/installing systems
Get a free MP3 every day with the Spinner.com Toolbar. Get it Now.
carl.froehlich(at)cox.net Guest
Posted: Sat Dec 27, 2008 2:41 pm Post subject: Drilling Control Stick |
Try some Boelube or cutting oil on the drill bit.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jfg(at)aol.com
Sent: Saturday, December 27, 2008 5:30 PM
Subject: Drilling Control Stick
Holy Moley! What kind of drill bit does it take to drill the control stick/base assembly?? It's killing my bits -- I've had to re-sharpen more than 6 times, and I'm not completely thru even the first assembly!
Jim Gilmore #40317
| Quote: | | http://www.matronics.com/contribution | 01234567890123
n223rv(at)wolflakeairport Guest
Posted: Sat Dec 27, 2008 2:58 pm Post subject: Drilling Control Stick |
I used the standard carbide drills, starting with a #30 and working my way up...
-M
Subject: RV10-List: Drilling Control Stick
Jim Gilmore #40317
jim(at)CombsFive.Com Guest
Posted: Sat Dec 27, 2008 6:39 pm Post subject: Drilling Control Stick |
Get some Boelube. It make drilling the steel MUCH easier. I got a small container of the paste and it has been used by myself and four other builders. Still have a bunch left.I don't remember where I bought it, but it really does the trick. Cool Tool also works well. It is a product used by machinists. A little of either product goes a long way. Use it on taps too. Jim Combs40192N312F > Holy Moley! Â What kind of drill bit does it take to drill the control> stick/base assembly?? Â It's killing my bits -- I've had to re-sharpen> more than 6 times, and I'm not completely thru even the first assembly!> > > Jim Gilmore #40317> > Legacy fuse complete/installing systems> [quote][b]
avu1(at)md.metrocast.net Guest
Posted: Sat Dec 27, 2008 9:02 pm Post subject: Drilling Control Stick |
Remember too that low rpm works better on steel.
Anh
N591VU
I don't remember
A little
Jim Combs
40192
N312F
> Holy Moley!
to re-sharpen
> Jim Gilmore
#40317
jfgilmore
Posted: Sun Dec 28, 2008 1:45 am Post subject: Drilling Control Stick |
Thanks to all who chimed in.  I had been using standard machine oil to lube the drilling process, which did not seem to help much.  Where can the Boelube be purchased?   I did realize the speed of my drill press was too high, and reducing it seemed to finally do the trick.  Both sticks are now drilled, but it took much longer than I would have ever dreamed.
Jim Gilmore, #40317
Wings & legacy fuse complete/installing systems/almost to fiberglass hell
N520TX
