woxofswa
Posted: Fri Dec 26, 2008 7:27 pm Post subject: Brake system questions. |
A couple of questions for the brain trust.
I am about to begin the chapter on the brake system.
My first question concerns the pros/cons of a sealant whilst mating the connectors. Van's says okay, but not necessary, and to never use teflon tape. They say they don't use any sealant for the connections in their shop.
Any comments/advice appreciated.
My second question is wondering if anyone has any comment/experience in using the stainless steel braided lines versus the plastic tubing, for the actuators. Anyone have experience with the www.nonstopaviation.com brake line kit?
Thanks in advance.
_________________ Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse in progress |
coop85(at)cableone.net Guest
Posted: Fri Dec 26, 2008 8:41 pm Post subject: Brake system questions. |
Myron,
I have the nylon tubing going from the passenger brakes to the pilot
brakes per the plans. It's absolutely appalling to many folks, but I've
never had a failure. What it has done for me that is positive, is to
recognize a leak sooner than feeling squishy brakes. I just noticed the
lack of red fluid in the line recently and had I used stainless lines the
first I would have noticed is when the brakes didn't work so well. That is
very disconcerting with an airplane without a steerable nosewheel. Overall
the stainless braided lines are probably the way to go, but just a thought
as you mull over what to do with your machine.
Marcus
Do not archive.
Lenny Iszak
Posted: Sat Dec 27, 2008 1:23 am Post subject: Re: Brake system questions. |
Myron,
I got the braided stainless brake line kit from Bonaco Inc. It includes the blue fittings and the brake lines for the gear legs too. If I remember correctly the total cost was $160 + shipping. Couple of weeks before that I paid $120 for a single brake line for my Katana. Gotta love experimental airplanes...
If you search the archives you'll find a few posts about thread sealants. Using that information I decided to use teflon paste, making sure not to get it on the first thread.
Lenny
#40803
Posted: Sat Dec 27, 2008 5:44 am Post subject: Brake system questions. |
Standard practice is to use something like Seal Lube on the pipe
thread (tapered thread) fittings which lets you get them tighter with
less torque while helping to seal the threads as well. Flare fittings
don't need sealant because they don't seal on the threads, but rather
on the flared portion.
I have never used other than the plastic lines as the plans call for.
As mentioned, it helps detect a leak and also greatly helps bleading
them in the first place because you can see air in the lines as fluid
pumps through them.
On the gear legs I have used the plans way and the Bonaco lines.
IMHO, the solid lines will last longer if you keep them from chafing.
The Bonaco lines have a rubber outer coating to b prevent chafing.
Jesse Saint
Saint Aviation
jesse(at)saintaviation.com
352-427-0285
On Dec 26, 2008, at 10:27 PM, "woxofswa" <woxof(at)aol.com> wrote:
brake line kit?
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, legacy build fuse in progress
http://forums.matronics.com/viewtopic.php?p 21303#221303
msausen
Joined: 25 Oct 2007 Posts: 480 Location: Appleton, WI USA
Posted: Sat Dec 27, 2008 4:11 pm Post subject: Brake system questions. |
I'll second the vote for the Bonaco kit. Back in May I paid $185 for them shipped and it came with new lines and fittings to replace the plastic lines. They also came with lines to run down the gear legs to replace those hard lines. They are SS Teflon lines with an anti chafe clear plastic sleeve. I was really impressed with how small they were as I've seen others that were quite bulky. Contact Brett for more info, brett(at)bonacoinc.com. Great stuff and great people to work with.
Michael
Phil.Perry(at)netapp.com Guest
msausen
Posted: Mon Dec 29, 2008 6:05 am Post subject: Brake system questions. |
Take note that that one does NOT come with the AN fittings. For those you will need:
http://www.nonstopaviation.com/rv10-brake-lines-p-14589.html
Why not just go with the Bonaco lines which are less expensive ($20 less with shipping when I got them), and come with all the fittings, in addition to the lines to run down the legs, and a anti chafe sleeve on all the lines? Not to mention Bonaco does lines for a living. If you don't want the gear leg runs you can let Brett know and that will knock another $45 off the price. I would also find out what the core of those lines are, I believe Bonaco's are Teflon. If you don't get lines with an anti chafe on them, make sure you protect any locations that the brake lines touch. Stainless braid will act like a hacksaw if it moves against another material.
Michael
Deems Davis
Posted: Mon Dec 29, 2008 6:56 am Post subject: Brake system questions. |
Another little known fact is that Brett (Bonaco) has a variety of colors
for the teflon sleves. I ordered black for the brake cylinders
themselves. (They even have Hot Pink, to satisfy your wildest interior
design plans!
Deems
Michael
Posted: Mon Dec 29, 2008 8:50 am Post subject: Brake system questions. |
Does anyone have a complete list of Bonaco part numbers for a full RV-10
installation???
pascal(at)rv10builder.net Guest
Posted: Mon Dec 29, 2008 9:09 am Post subject: Brake system questions. |
call Brett at Bonaco and he'll explain the current pricing for what you're
looking for.
1-866-239-6442
www.bonacoinc.com
Pascal
Sent: Monday, December 29, 2008 8:47 AM
Subject: RE: Re: Brake system questions.
installation???
ricksked(at)embarqmail.co Guest
Posted: Mon Dec 29, 2008 9:20 am Post subject: Brake system questions. |
Call Brett....they have a complete kit with all the fittings for the .RV 10. Calling him is much better service and easier ordering
Rick Sked
40185
Sent via BlackBerry by AT&T
Posted: Tue Dec 30, 2008 11:29 am Post subject: Brake system questions. |
I got the info from Brett... Here it is if others would like it.
Phil,
Our brake line kit for the RV-10 consists of the following:
2psc -3 Hose assemblies w/Clear (at) 42-1/2" OLV -3 St to -3 ST from Pilot to Passenger Pedals.
1 pcs -3 Hose assemblies w/Clear (at) 18-1/4" OVL -3 St to -3 ST from Passenger to Brake Fluid Reservoir.
1 pcs -3 Hose assemblies w/Clear (at) 18-1/2" OVL -3 St to -3 90° from Passenger to Brake Fluid Reservoir.
2 pcs -3 Hose assemblies w/Clear (at) 19-1/8" OVL -3 St to -4 St Pilot to Fire Wall Bulkheads.
2 pcs -3 Hose assemblies w/Clear (at) 31-1/2" OVL -3 (With -4 Nuts Each End) St to St Gear Left and Right.
8 psc 822-3D 1/8NPT Male to -3 Male 90°
1 pc 826-3D This will replace the stock plastic "T" at the brake fluid reservoir
The P/N is RV10DBL, cost is $175.00 USD (taxes and shipping not included).
We also have lengths for fuel lines and can make your firewall forward lines to your specifications.
If you have any questions at all please feel free to give me a call.
Brett
Bonaco, Inc.
1-909-608-1106
woxofswa
Posted: Tue Dec 30, 2008 11:36 am Post subject: Re: Brake system questions. |
Thanks to all for the help.
I ordered a brake kit and fuel line kit from Brett.
This forum is sure handy and quite expensive!
Mesa, AZ
ThisOne
Joined: 18 Jun 2008 Posts: 20 Location: High Desert, So Calif USA
Posted: Tue Jan 06, 2009 1:02 pm Post subject: Re: Brake system questions. |
Just a fast note:
"Thank you all for the great comments on our lines."
Brett
Bonaco, Inc.
n8zg(at)mchsi.com Guest
Posted: Tue Jan 06, 2009 2:24 pm Post subject: Brake system questions. |
Attach it to a funnel and add beer.
neal
Now if I can only figure out a use for that little brake line you gave me at OSH!!!
Rick sked
40185
msausen
Posted: Tue Jan 06, 2009 4:08 pm Post subject: Brake system questions. |
It's a bit small. Might need to change that to a shot glass and tequila.
Michael
Posted: Tue Jan 06, 2009 4:36 pm Post subject: Brake system questions. |
Neal,
I would expect that kind of answer from a fellow USAF brother...but you are giving away the fact you're an officer. With all due respect Sir, No NCO (like me) would ever let an officer use such a silly tiny beer bong as you suggest. I thought after all these years you college boys would have learned to support and take care of yourselves...but then when you drink you play that game of pool with no cues..what's it called??? Crud??
Rick Sked
40185
Fill, sand, repeat, fill, sand, repeat
Paint prep
speckter(at)comcast.net Guest
Posted: Tue Jan 06, 2009 4:46 pm Post subject: Brake system questions. |
I think it is Miller time!!!!
Gary Specketer
ThisOne
Posted: Tue Jan 06, 2009 4:53 pm Post subject: Re: Brake system questions. |
| ricksked(at)embarqmail.co wrote: | Neal,
Rick Sked
40185
Paint prep
Rick,
I wish I had known that you were on active duty....I give 10% off for those who are.
And may I say "Thank You" for your duty.
Brett
Bonaco, Inc.
