		Tom Jones
				 Posted: Sun Dec 28, 2008 2:25 pm    Post subject: 503 Engine Fogging-OOP-Update, got it. |
				Today I was going to fog the crankcase on my 503 like Rotax recommends for more than a few weeks storage.  I aimed the extension tube in the throat of the front carb and pressed the nozzle down.  You wouldn't believe it but the extension tube on the fogging oil can came off and shot straight into the basement of the crankcase.  The engine wasn't running.
 I took the carb off to get a better look but can't see it.  Any ideas how to get it out?  Only way I can think of is to take the cylinder off.
 To add insult to injury I got stung by a dormant hornet between two fingers when I picked up a wrench.  Its been zero degrees for two weeks here.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Tom Jones
Classic IV
Ellensburg, WA
		Paul A. Franz, P.E.
				 Posted: Sun Dec 28, 2008 3:03 pm    Post subject: 503 Engine Fogging-OOPS |
				On Sun, December 28, 2008 2:25 pm, Tom Jones wrote:
 With luck like that, only the worst could be expected. What would that be? Well, I'd
 say, taking the jug off and not finding the extension tube inside because when it blew
 off, it actually went somewhere else.
  	  | Quote: | 	 		   I took the carb off to get a better look but can't see it.  Any ideas how to get it
 There certainly isn't a lot of space inside there for an object to hide. When the
 crank throw is at the bottom there's not enough room for anything to hide under it.
 But of course when it is at the bottom the piston is blocking your view. If the little
 extension has iron content, maybe a magnet on a flex would find it. I might also try
 some balled up masking tape on a flex which might stick to a small piece.
 Given that it is so cold there and everything might be oil coated getting something to
 stick might be a waste of time.
 Maybe a blast of compressed air could flip it into view?
 Not worth spending much time trying unsuccessfully to retrieve it before proceeding to
 disassembly.
  	  | Quote: | 	 		   To add insult to injury I got stung by a dormant hornet between two fingers when I
 Yipes, that can produce some painful swelling.
 Paul A. Franz
 Registration/Aircraft - N14UW/Merlin GT
 Engine/Prop - Rotax 914/NSI CAP
 Bellevue WA
 425.241.1618 Cell
  _________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
		Tom Jones
				 Posted: Mon Dec 29, 2008 2:08 pm    Post subject: Re: 503 Engine Fogging-OOP-Update, got it. |
				I used a small mechanic's mirror to look around in there and could see the little red bugger but managed to push it down out of sight trying to grab it with a flex claw.  Ended up taking the cylinder off to get it out.  Just ordered the gaskets to put the engine back together.
 It was an expensive lesson from the school of hard knocks.
Classic IV
Ellensburg, WA |
