		Dick Maddux
				 Posted: Sun Dec 28, 2008 6:20 am    Post subject: Tach: 582 RPM question. |
				I had a Cermark tach checker. It wouldn't work,they sent me another and it  wouldn't work either. Finally after the third time and much arguing they sent a  third. It was their new plus version and it works fine. I have a warp drive  prop and it would not register nor would any other prop on the field.  (Cherokees,Cessna,etc) The tach did work well for indicating the frequency of a  fluorescent light though
                                                              Dick Maddux
                                                              Pensacola,Fl
 Don't be the last to know> for the latest news that will have people talking.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Roger Lee
				 Posted: Sun Dec 28, 2008 7:08 am    Post subject: Re: Tach: 582 RPM question. |
				Hi Dick,
 I couple of things come to mind that may influence your tach.
 If you need to use a piece of reflective tape then make it a little larger. One style of tach I use calls for a 1" wide by 2"-3" long piece of tape.
 You may be too close or too far away.
 The angle of the outside light may be affecting the sensor, try turning the plane around so light hits your target in a different spot.
 Just a couple of ideas.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
		aerobatics(at)aol.com Guest
				 Posted: Sun Dec 28, 2008 8:49 am    Post subject: Tach: 582 RPM question. |
				hmmm  I have both versions  and work great  but I found positioning
 the plane so the sun in in the general area on the opposite of the tach
 ..  I didn't need reflective tape....  but sounds like a good idea...
  Mine even worked from the cockpit with the door open.
 glad u  got it working
 Dave
