		Roland Smith
				 Posted: Tue Dec 30, 2008 6:39 am    Post subject: Dzus Grommets |
				I'm using Dzus fasteners for my cowl.  They  came with the Skyshop firewall forward package for the 701.  Do I need  grommets to protect the fiberglass where the studs go through or can  the studs be attached without grommets ?   Grommets were not  included in the FWF kit.
  Roland Smith  N701AA
  |  | - The Matronics Zenith701801-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ 701 kit,  Rotax 912 ULS, SensorNetics EFIS,  Flying. |
		klondike(at)megalink.net Guest
				 Posted: Tue Dec 30, 2008 8:47 am    Post subject: Dzus Grommets |
				I recommend grommets and also to make sure you have the correct length, so  you have a nice tight fit.  Many years ago on my 701, the Dzus fasteners  didn't fit tight (I thought they did).  The chaffing and vibration caused  the holes to enlarge.  On one flight, the left side of my top cowling came  "undone" and popped up at about a 45 degree angle.   I made an  uneventful landing, actually looking "under the top left side of  the cowling" it was so high up.
  I was lucky it stayed with the airplane and that it didn't come off and hit  something or someone on the ground.------ Looking back on the situation----- I  should have used an aluminum backing "plate" where the grommet went through the  fiberglass.
  Hope this helps.
  Fritz
  [quote]   ---
		lgold(at)quantum-associat Guest
				 Posted: Tue Dec 30, 2008 10:37 am    Post subject: Dzus Grommets |
				Roland,
 I think that the grommets look really nice and probably protect the fiberglass. However, I didn’t know how to install them properly and so I left them out.
 My 701 plane has been flying for over a year. I have not noticed any damage to the un-grommeted fiberglass even though I take the cowl off about once a week. If I start to see wear, I will try to install grommets but it does not look like I will need them.
 Les
 From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of docponds
  Sent: Tuesday, December 30, 2008 6:38 AM
  Subject: Dzus Grommets
 Roland Smith  N701AA
    	  | Quote: | 	 		  |   http://www.matronics.com/contribution  | 	  01234567890123
				 Posted: Tue Dec 30, 2008 12:26 pm    Post subject: Dzus Grommets |
				Roland,
 Also consider using thermoplastic grommets type GP rather than the
 aluminum kind as they will secure the Dzus fasteners and you don't need
 any special tools to
 put them on or replace them. Important is the gap that accrues for grip
 when turning the Dzus to secure the lid. The grommets can be helpful in
 this as well.
 Aircraft Spruce part number GP5B is likely but size your grommets to fit
 the Dzus diameter. About .06 each.
 Larry McFarland
 fritz wrote:
 [quote] I recommend grommets and also to make sure you have the correct
  Hope this helps.
  Fritz
				 Posted: Tue Dec 30, 2008 12:34 pm    Post subject: Dzus Grommets |
				Les and Roland,
 I should mention that you can make Dzus grommets from milk jug material
 if you're careful to punch out the correct inside diameter
 and trim the outside diameter to less than the Dzus head. These work
 well too so long as the inside diameter is snug to the Dzus stem.
 The object is, of course to keep the Dzus from becoming loose parts and
 being floppy in the hole. Insert Dzus thru the fiberglass and add
 the plastic washer, that's it.
 Les Goldner wrote:
  Roland,
  I left them out.
  Les
  *From:* owner-zenith701801-list-server(at)matronics.com
  [mailto:owner-zenith701801-list-server(at)matronics.com] *On Behalf Of
  *docponds
  *Sent:* Tuesday, December 30, 2008 6:38 AM
  *To:* zenith701801-list(at)matronics.com
  *Subject:* Dzus Grommets
  Roland Smith N701AA
		NYTerminat(at)aol.com Guest
				 Posted: Tue Dec 30, 2008 5:11 pm    Post subject: Dzus Grommets |
				Roland,
  Grommets would help protect the fiberglass. I did not use them and I am  starting to see some wear after 160 hrs.on my SkyShop cowl.
  Bob Spudis
  N701ZX
  In a message dated 12/30/2008 9:39:38 A.M. Eastern Standard Time,  docponds(at)sover.net writes:
   	  | Quote: | 	 		     I'm using Dzus fasteners for my cowl.  They    came with the Skyshop firewall forward package for the 701.  Do I    need grommets to protect the fiberglass where the studs go    through or can the studs be attached without grommets ?      Grommets were not included in the FWF kit.
    Roland Smith  N701AA
 One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mail. Try it now.
