Timandmeli
Joined: 31 Dec 2008 Posts: 1 Location: Southeast Alabama
Posted: Wed Dec 31, 2008 1:48 pm Post subject: Always Hot Battery Bus |
I'm wiring my rv-8 using bob nuckolls simple vfr day night wiring diagram. Provisions are for a always hot battery bus. He indicates the length of wire should be six inches or less. However I would like to mount this fuse block next to the main bus which is one bulkhead forward of the instrument panel requiring a 5 foot length of wire. Should I fuse protect this wire with in-line fuse or maybe a current limiter. I'm planning on one electronic ignition and one conventional magneto. Thanks Tim
_________________ Tim Pethel
RV-8A
Wiring Fuse |
Posted: Wed Dec 31, 2008 2:41 pm Post subject: Always Hot Battery Bus |
At 03:48 PM 12/31/2008, you wrote:
<timandmeli(at)roadrunner.com>
The 6" rule including the maximum size of fuse (7A)
for the hot-battery bus is a convention adopted for
post crash fire risk reduction. It's not possible
to offer advice based on any analysis of your
proposed changes. If you mount it that far away
from the battery, you've got an always hot feeder
rated for considerable current capability. This
is not done in the certified world. I would
recommend you leave the battery bus fuse block
co-located with the battery contactor and
run individual feeders from fuses of no more
than 7A from that location.
( -Thomas Paine 1776- )
pwmac(at)sisna.com Guest
Posted: Wed Dec 31, 2008 4:19 pm Post subject: Always Hot Battery Bus |
Long hot wires bother me as well.
However in the world of off road truck racing there is no room for a
battery located near the panel or engine. We frequently use 10'+ #2
always hot unprotected leads from 2 big AH batteries located in the
back where the weight does some good. Its very rare to have any
issues after a major crash that involves shorted battery leads. You
better believe the leads are carefully routed and protected.
Typically protected with the convoluted split plastic stuff. Sure it
burns but it is good for abrasion protection and cheap. The best lead
wire is welding wire with double elastomer insulation. Pretty
durable. I cannot source the stuff for you all but a day of shopping
at the weld & battery shops will turn up a good product. I use a
west marine source 4 position switch to turn the power off if need be
and for storage to reduce the drain from all the parasite
electronics. Yes the switch is where the driver can reach it and it
is a long ways from the batts.
The bottom line is there are many more high risk things in a plane or
a race truck to be concerned about than a long hot batt lead.
Regards, Paul
At 03:39 PM 12/31/2008, you wrote:
<nuckolls.bob(at)aeroelectric.com>
