CBarber(at)TexasAttorney. Guest
Posted: Fri Jan 02, 2009 12:02 pm Post subject: Z-14 v Z-14Fadec question |
Last week I asked about C/B's tripping in the NON crossover mode and received a thoughtful answer. Thanks. Due to my growing but limited knowledge in this area it took a EE buddy of mine to figure out I had the crossover switch wired in a "mirrored" manner on my switch. Now, no more C/B tripping AND my alternators are charging properly. So, my initial calculations seemed to be ok as to wires etc....just not my translation as to switch connections. Ahhhhhh, non-the-less, it now feels nice.
Now, I have a general question regarding the Z-14 schemes. For the crossover switch, up is to engage the starter with both batteries, center is non-crossover, normal mode with batteries working to power their bus independently and down is both batteries working together on both busses......If I understand correctly. So, in the Z-14 Fadec scheme, the start button engages the starter, then one position on the switch is independent alt to each bus and the other switch to have the systems work together? Or, is on position Off and the other switch position engaging both alternators to work together? If it is the second scenario, does that mean the two systems ALWAYS work together? If so, is there any reason not to have both systems always working together in the standard Z-14 scheme. I assume the FADEC label is since it is always engaged there is no pilot intervention. Just looking for a better understanding. Thanks.
All the best,
Chris Barber
Houston
Velocity SE with all electric Mazda 13b rotary
klehman(at)albedo.net Guest
Posted: Fri Jan 02, 2009 6:26 pm Post subject: Z-14 v Z-14Fadec question |
Chris
On my Z14 I have a two position crossfeed switch. In the normal OFF
position the two systems run isolated from each other. That way a fault
in one system can't affect the other. In the ON position the crossfeed
contactor closes and parallels the batteries. I would only do that if
one alternator went dead and I wished to continue flying for sometime or
to get to a repair facility. In addition since I run very small
batteries on my system, the crossfeed contactor is wired to close
automatically any time I crank the engine to start it.
Ken
ej22 and dual EFI
Christopher Barber wrote:
Quote: | Last week I asked about C/B's tripping in the NON crossover mode and
feels nice.
All the best,
Chris Barber
Houston
Posted: Sat Jan 03, 2009 11:12 am Post subject: Z-14 v Z-14Fadec question |
Quote: |
Now, I have a general question regarding the Z-14 schemes. For the crossover switch, up is to engage the starter with both batteries, center is non-crossover, normal mode with batteries working to power their bus independently and down is both batteries working together on both busses......If I understand correctly. So, in the Z-14 Fadec scheme, the start button engages the starter, then one position on the switch is independent alt to each bus and the other switch to have the systems work together? Or, is on position Off and the other switch position engaging both alternators to work together? If it is the second scenario, does that mean the two systems ALWAYS work together? If so, is there any reason not to have both systems always working together in the standard Z-14 scheme. I assume the FADEC label is since it is always engaged there is no pilot intervention. Just looking for a better understanding. Thanks. |
Two ideas drove the crafting the first iteration of of Z-14
many moons ago.
(1) For operators that plan a highly
redundant electrical and instrumentation system
for flight in marginal to adverse conditions,
two independent systems is desirable/
practical by teaming a conventional main alternator
with a vacuum pump pad driven alternator.
(2) Both systems need their own battery. With fully
redundant systems having cross-feed capability, one
may strive for smallest practical batteries with the
notion that battery-only flight is exceedingly
improbable. However, small batteries don't crank
engines well . . . so auto-crossfeed or paralleling
small batteries during engine cranking is a useful
thing to consider.
The two systems are never cross-connected for normal
operations. Each system receives the benefit of
a load analysis. Pairs of redundant electronics
are distributed between the two systems.
Some years later we were offered electro-whizzies
with desirable performance characteristics
under normal operating conditions but not designed
to live in the real-world of vehicular DC power systems.
During starter motor inrush time, system voltage can
sag sufficiently low, sufficiently long . . .
http://tinyurl.com/6tbry6
that some appliances wander off into the weeds or
take an untimely interval to reboot.
These appliances include but are not limited to
electronic ignitions, electronic fuel injection,
EFIS systems, FADECs, etc.
This prompted the addition of two Band-Aids to
the Z-figures. The FADEC version of Z-14 suggested
elimination of the auto-crossfeed feature during
cranking.
Another version of Z-13/8 was crafted to add
a brownout protection battery and auto-disconnect
relay to support e-bus loads during engine-cranking
http://tinyurl.com/7q2usj
The supposition you offered at the end of your post
is not correct. The cross-feed switch in the FADEC
version of Z-14 is never closed except to allow
ONE working alternator to support both sides of the
system (within that alternator's limitations). The
switch is left open all other times. Recalcitrant
systems are operated from the Aux Battery which is
NOT loaded during engine cranking.
( -Thomas Paine 1776- )
