bouguy
Posted: Sat Jan 03, 2009 8:41 am Post subject: Cessna Flaps motor |
Hi ,
i am looking for the current draw of a 24v/28v flap motor
of a Cessna 172 and not able to find it .
thanks for help ,
Boullu guy .
skywagon
Posted: Sat Jan 03, 2009 9:09 am Post subject: Cessna Flaps motor |
Probably best to use the flaps circuit breaker rating, amps, in case the
flap mechanism gets stiff or worn and the elect. motor goes to max
current...
D
Posted: Sat Jan 03, 2009 10:28 am Post subject: Cessna Flaps motor |
At 10:41 AM 1/3/2009, you wrote:
Hi ,
thanks for help ,
Boullu guy .
How do you need to use the information? If for
a load analysis, know that flaps are very low
duty cycle (hence low energy) systems that are
not big players in sizing an electrical system.
If for circuit protection and wiring decisions,
I think you'll find that this critter seldom
draws more than 7 amps (extension during max
allowable IAS for full flaps). You can check the
size of a breaker in any of the 28v s.e. airplanes
and go with that. It's probably a 10 or 15A breaker.
You can wire with 14AWG and go with smaller breaker
and upsize the breaker to and including 20A if
you're getting nuisance trips. Assuming you're
installing this motor/actuator in a OBAM aircraft,
it could be that your flap geometry and air-loads
are decidedly different that for the Cessna
installation.
Wire it with "too-big" wire and leave yourself
room for resizing the breaker/fuse after you've
had some time to acquire real-life experience
with it.
( -Thomas Paine 1776- )
bouguy
Posted: Sun Jan 04, 2009 1:20 am Post subject: Re: Cessna Flaps motor |
Hi Bob ,
thanks for your reply ;
it is not for a bus load analysis , as it is an intermittent load ;
seen a 10A breaker on a 24Volts Cessna 172 but as i am
building a faster aircraft with more flaps surfaces i thought it
was not correctly sized for me .
i am going to follow your indications : wiring with 14awg with
a 15 Amp breaker , and if it pops up , i will change for a 20 Amp.
i have a similar question for a Prestolite Power Pack rebuilt
AƩroelectic 28volts HYH-5001ECH ; what would be the correct
wire sizing and breaker ?
thanks again for help ,
Boullu guy .
Posted: Sun Jan 04, 2009 8:21 am Post subject: Cessna Flaps motor |
At 03:20 AM 1/4/2009, you wrote:
Hi Bob ,
"faster", "more" etc. are poor quantifiers of design.
The air-loads on a flap system are directly related to
area and IAS . . . but FORCE on the actuator is also
a function of rates and mechanism.
| Quote: | i am going to follow your indications : wiring with 14awg with
It's a WAG. Without specific engineering data for
using this component in the proposed system, the
conservative approach is duplicate what was in the
original system and then take measurements during
your fly-off to deduce whether or not modifications
are called for. It's not likely that you're going
to experience any big surprises. Even if you do,
the worst thing that happens is an adjustment of
wire size and protection.
I get a lot of emails on this and similar topics.
Many folks think that from first flight on a new
airplane until s/n 100 rolls of the assembly line,
few if any changes happen to the design. Our
OBAM aircraft are no different with respect to
verifying achievement of design goals . . .
The potential for risk in sizing wire and fuses
is very low. WAG it, verify it, then modify as
necessary.
