Comm & Nav audio with SPA 400
Gilles.Thesee(at)ac-greno
PostPosted: Mon May 11, 2009 11:24 am    Post subject: Comm & Nav audio with SPA 400 Reply with quote
Hi all,
A buddy is trying to install a KX 155 with a Sigtronics SPA 400 in a two
seater.
He is trying to devise a way to hook up the Nav audio output.
Any suggestions as to how to mix or hook up Comm AND Nav audio ?
Thanks in advance
Best regards,
Gilles
http://contrails.free.fr
equinav(at)interbaun.com
PostPosted: Mon May 11, 2009 12:09 pm    Post subject: Comm & Nav audio with SPA 400 Reply with quote
Usually, there is a audio input or "aux" input for the coms. This is
designed to mix the audio for a variety of devices.
You could try hooking pins 10 and L of connector A1 (Nav high and low) to
Pins H and F of connector A2 (Aux high and low in). This would mix the Nav
audio output into the comm audio input.
Probably accomplish what you need to mix the audio prior to the SAP400.
Patrick
PostPosted: Mon May 11, 2009 12:12 pm    Post subject: Comm & Nav audio with SPA 400 Reply with quote
This would probably accomplish what you need to mix the audio prior to the
SAP400.
Patrick
