		alex_001
				 Posted: Sun Jan 04, 2009 10:09 am    Post subject: W&B envelope CH601XL |
				Hello,
 i am a bit confused as I have a W&B sheet from ZENAIR with a max 30% of MAC (or max 450mm rearward CG) and I have from CZAW max 35% of MAC (or max 525mm rearward CG).
 The strange thing is on my 1st 601xl from CZAW it was like the W&B from Zenair.
 anyone any clues???
 thanks
 CH601xl  (RTF from CZAW)
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rans6andrew
				 Posted: Sun Jan 04, 2009 10:37 am    Post subject: Re: W&B envelope CH601XL |
				The LAA, who usually go OTT with approvals and testing, publish a document called a TAD for all amateur built aircraft.  This document has some useful info regarding weights, CoG limits, operating speeds etc.  Generally the info within the TAD will have been checked by a thorough flight test program performed on the first completed example of the type to be completed.
 For the 601XL see
 http://www.lightaircraftassociation.co.uk/engineering/TADs/162B%20ZENAIR%20CH601-XL.pdf
 where theCoG range is given as 300 to 520 mm aft of datum (datum is leading edge).
 I hope that this is useful info.
 Andrew.
  _________________ A good way through building a 601UL with 912UL.
Still flying Rans S6 with 503. |
