wooburnaviation(at)google Guest
Posted: Mon Jan 05, 2009 12:55 pm Post subject: Silicone Radiator Hose |
Tesy message - I cant remember my usedr name!
2009/1/4 Erich Trombley <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)>
[quote]--> Europa-List message posted by: "Erich Trombley" <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)>
Paul,
I have been using the blue silicone heater hose for several years now without issue. While I do not have the spring type clamps I found that slipping heat shrink tubing over the standard worm drive hose clamps works a treat. Without the shrink tubing you will run the risk of the clamp cutting into the silicone. Additionally, I used heat shrink tubing over the end of the silicone hose to minimize any chance of chaffing from the clamp. Finally, as I concerned about the hose kinking as it came up and over the top of the engine I wrapped the outside of hose in that location with safety wire in a loose spiral then covered it with shrink wrap to keep it in place.
Also, I know of one other builder that used silicone vacuum line with great success. Both items are available at:
http://www.paragonperformance.com
Erich Trombley
N28ET Classic Mono 914
____________________________________________________________
Click here for free information on nursing degrees, up to $150/hour
http://thirdpartyoffers.juno.com/TGL2131/fc/PnY6rbu0vDKdYORnAPlOjhWoO5WAOiEiV1nHPreLv1T2gtxsdsBbR/
