challgren(at)mac.com Guest
				 Posted: Mon Mar 27, 2006 9:16 am    Post subject: Rotax Suppoort |
				Fellow builders:
 Paul wrote in response to my question on Rotax support:
 "You mention concern about cooling on the Jabiru engine while doing
 landings.  Do you have any information that this is a problem?  Or,
 is this just a theory that it might be a problem?"
 We had a problem with our early Jabiru 3300 that would run hotter
 when flying below 100 mph.  Essentially we were restricted from doing
 so without modifying our air intake to the engine.  Since my 701
 would always be in that realm, the repeated power changes might
 present a challenge to good cooling.  There was a learned treatise on
 the subject of shock cooling recently that should be in the
 archives.  I believe it qualifies as scientific evidence and is not
 just a theory.  It was a reason for my concern.  Pete has indicated
 very recently that the latest 3300 will again have bigger cooling
 fins which should be a fix to the problem.
 I am very open to experience that indicates the 3300 is reliable when
 operated a significant portion of the time in the landing pattern.
 Stan
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
