Posted: Fri Jan 09, 2009 2:37 pm Post subject: cowl hinge pins |
In previous emails it was discussed that the hinge pinsthe come with the SS hinges used for the cowls need to be replaced with a different pin. WHich pin needs to be used C it is not stated on the plans and is this smaller pin only used on the top hinges or the side hinges also??? There is not enough provided in the kit for both if it is the SSP-120 which is smaller than the one inside the hinges. There is one long length which is of much smaller diameter but that seems too narrow.
JOhn
rene(at)felker.com Guest
Posted: Fri Jan 09, 2009 2:59 pm Post subject: cowl hinge pins |
Just from memory…..small pins on top, it is a sizeable diameter difference. You will need that to be able to make the turn. Larger pins on the side and bottom. Do not use the AL pins….they will gall the hinge if you try to pull them in and out with the hinge under stress…..ask me how I know.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
Sent: Friday, January 09, 2009 3:36 PM
To: RV 10 group
Subject: cowl hinge pins
In previous emails it was discussed that the hinge pinsthe come with the SS hinges used for the cowls need to be replaced with a different pin. WHich pin needs to be used, it is not stated on the plans and is this smaller pin only used on the top hinges or the side hinges also??? There is not enough provided in the kit for both if it is the SSP-120 which is smaller than the one inside the hinges. There is one long length which is of much smaller diameter but that seems too narrow.
JOhn
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
