help with actual engine performance
luckymacy(at)comcast.net
PostPosted: Fri Mar 24, 2006 3:36 pm    Post subject: help with actual engine performance Reply with quote
My EFIS isn't quite dialed in yet but I recorded the following numbers today and want a second opinion on whether or not these are close.
I have a 200hp angle valved engine.
My max full throttle highest fuel flow was ~20 gph and my highest MP was 22.95 but that last number is the one I think is way off and I need to figure out how to tweak my settings to compute correctly. Take off altitude was 440 feet and I forgot the barometric pressure but it was around 30.0
What would angle engine owners expect to see for MP given this approximate scenario?
thx,
lucky
My max full throttle highest fuel flow was ~20 gph and my highest MP was 22.95 but that last number is the one I think is way off and I need to figure out how to tweak my settings to compute correctly.Take off altitude was 440 feet and I forgot the barometric pressure but it was around 30.0
thx,
lucky
kboatright1(at)comcast.ne
PostPosted: Fri Mar 24, 2006 3:57 pm    Post subject: help with actual engine performance Reply with quote
What does your MP gauge read when the engine is stopped? It should read 29
or inches, depending on field elevation. On takeoff, it should read
slightly lower than that - maybe 1/2 or 1 inch due to induction system
losses.
KB
khorton01(at)rogers.com
PostPosted: Fri Mar 24, 2006 3:59 pm    Post subject: help with actual engine performance Reply with quote
close.
Lucky,
As you suspect, something is fouled up somewhere. At 440 ft ASL,
with an altimeter setting of 30.00, the actual atmospheric pressure
would be about 29.5 in HG. The manifold pressure at full throttle at
low speed should be around an inch less than the atmospheric
pressure, plus or minus.
So, you either have a false MP indication, or a very significant
restriction in your induction system, or your throttle is not getting
full open.
Are you sure that your throttle plate is getting full open?
Which MP gauge or engine indication system do you have?
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
PostPosted: Fri Mar 24, 2006 4:58 pm    Post subject: help with actual engine performance Reply with quote
forget the MP part. That's just me talking out loud. I have to figure out how to make my spreadsheet algorithm match reality. It displays "right" in the cockpit but the GRT recorded data for MP is 'raw' data and not the processed value that's displayed.
Really my question is does the 20 gallons per hour seem right for a 200 hp engine making full power near sea level?
-------------- Original message --------------
> close.
Lucky,
full open.
Ottawa, Canada
Really my question is does the 20 gallons per hour seem right for a 200 hp engine making full powernear sea level?
-- RV-List message posted by: Kevin Horton <KHORTON01(at)ROGERS.COM>
-- RV-List message posted by: luckymacy(at)comcast.net (lucky)
close.
barometric pressure
Lucky,
full open.
Ottawa, Canada
Kellym
PostPosted: Fri Mar 24, 2006 6:36 pm    Post subject: help with actual engine performance Reply with quote
Yes, 20gph is close, perhaps a hair rich, but a good number. I've heard
of as low as 17gph, but that is on the lean side.
>> close.
> Lucky,
> full open.
> Ottawa, Canada
close.
barometric pressure
Lucky,
full open.
Ottawa, Canada
Kelly McMullen
KCHD
Charles Heathco
PostPosted: Sat Mar 25, 2006 7:28 pm    Post subject: help with actual engine performance Reply with quote
Holy toledo! 20gph is considered normal?? No wander the glaciers are melting. Chas
